Hey there, annoying little problem I have come across here. EAC appears to not be able to detect a matching read command. I have scrolled through all of them that are available on the drop down menu, but none seem to work. I have the latest ASPI layer so I know that doesn't appear to be the problem, but for some reason I just can't seem to get EAC to spin up to start extracting. It lists all the tracks available and see's them there so I'm not sure what is going on.
If I use Plextools to create .wavs it all works fine. Same for CDEX as well. Has anyone else encountered this problem with the new Plextor 716A?
One thing that I have noticed though is that I run the drive feature detector, it comes back and says:
Caching: YES
Accurate Stream: YES
C2 Error Info: NO
Is this a defective drive? I noticed in the review from Ian that all three should come back with yes? If i shut off the C2 option in EAC then everything appears to work normally as it did before. But I'm guessing that I don't want to have this option off. In fact, I know I don't. Should I be seeing all three YES's?
Thanks for the heads up.
Dinger
