Ask for problem clarification
Postby Yuppi on Fri Jul 11, 2003 5:50 am
Hi,
I have a Samsung SW-252B CD writer and I'm copying files from my hard disk to a CD. I'm using two methods:
1) drag and drop files from the Windows Explorer and writing them to the CD.
2) using Nero Burning ROM.
The problem is that, after these files are copied and I try to execute them from the newly created CD, the applications always crashes.
Just to note that my OS is WinXP. Is it a problem from the CD drive?
Thanks,
Yuppi
Yuppi
Postby Justin42 on Fri Jul 11, 2003 10:35 am
I am a little confused, you're trying *both* drag & drop and Nero and neither works? (or are you dragging and dropping from Explorer into Nero?)
What type of files are you using? Maybe the application is choking on "read-only" files?
