Audio and data burning software ?
Postby miroc on Sat Dec 27, 2003 2:43 pm
What is the best audio and data burning software compatible with Ulead products. I am having problems with my Sonic RecordNow! software after downloading Ulead VideoStudio7 and PhotoExplorer7 trials.
miroc
Postby integspec on Sat Dec 27, 2003 2:54 pm
Many here would recommend either:
Nero http://www.ahead.de/en/nero6.html
Or
Easy CDDVD Creator http://www.roxio.com/en/products/ecdc/index.jhtml
But Nero is the app of choice for most. Btw, if you can explain your current problem, maybe we can find a solution.
HTH / Good Luck.
Nor iron bars a cage;
Minds innocent and quiet take
That for an hermitage;
If I have freedom in my love,
And in my soul am free,
Angels alone that soar above
integspec
Unable to open RecordNow!
Postby miroc on Sat Dec 27, 2003 4:15 pm
Since I installed Ulead VideoStudio7 and Photoexplorer8 trials I can not open Sonic RecordNow!
I realy like those two Ulead products and want to register but I also need and audio and backup software. Nero is very nice but it's to much, I only need the audio and backup part.
If you can help?? tks
miroc
Postby integspec on Mon Dec 29, 2003 5:29 am
Please uninstall and reinstall Sonic. Also you have to tell us why after installing the Ulead products the Sonic is not working (any error messages, weird behaviour, etc...).
At a situation like this, you can try two approaches: First install the Ulead products and then install Sonic. Find out which product is working / not workin. Then try the other way, ie: install Sonic first and Ulead products next. Let us know. btw, if all products are working in the first approach, leave it as it it.
HTH / Good Luck.
integspec
Postby aviationwiz on Mon Dec 29, 2003 6:48 am
miroc,
Did you look at the Nero Express part of Nero? Perhaps you will like that better.
Postby miroc on Mon Dec 29, 2003 10:23 am
Finally I uninstalled Sonic and installed Nero. Everything seems to be ok now.
Tks guys for your help
miroc
Postby integspec on Mon Dec 29, 2003 11:26 am
No problem mate.
Cheers.
integspec
