Benq DW1610 Read Problems
Postby quark on Sun Aug 22, 2004 5:30 pm
I just purchased this drive yesterday, and I've tried burning two DVD-R data discs, one multisession and one regular, and neither of them read in the drive. I've tried a DVD movie and it works most of the time and I've tried burning a CD-R and it works fine. I have yet to try a DVD+R since I don't have any with me right now. Does anyone know what the problem could be? The media I'm using is Interaxia AG max speed 4X. I have this Benq drive set to secondary slave, and my HD is set to primary master, and my DVD-ROM is set to primary slave. I'm running win xp pro on a p4 2.0ghz with 512mb ddr33 ram. Any help would be appreciated
quark
Postby alien7 on Sun Aug 22, 2004 6:32 pm
BenQ drives don't work well with DVD-R media, better use DVD+R media only (Maxell DVD+R works great with BenQ).
alien7
Postby Vanderlow on Sun Aug 22, 2004 10:53 pm
and I aslo thought I ran across something about the via drivers, if you're using them. Maybe try and and reapply. I believe I ran across at the firmware site and it wasn't a Benq , but after they delete some via driver he had better results.
Vanderlow
Postby shimman on Thu Aug 26, 2004 7:42 pm
i have 1600 & it had strange behaviors.....one of them is the requiring 80 conductor ide cable. i returned two drives & i found out from the winxp's event logs(under system logs) that there were many cdrom controller errors, so i replaced the 40 conductor cable with the 80 conductor cable...worked
the itself were not damaged because other ultra33 optical drives were working fine with that cable...even 712a worked
so far i am disappointed with benq 1600 (now updated to 1620)
shimman
Postby Vanderlow on Fri Aug 27, 2004 6:00 pm
Shiman your disappointed? Outside of getting the cable change is it not burning well? Do you have the offical firmware on now? Are you burning mainly + or -s? BenQ do +s quite well. I say an exception Prodisc 8x +burned at 12x that had a max of 11 PI.
Vanderlow
Users browsing this forum: No registered users and 13 guests
