Was wondering which recordable discs are best for the BenQ 1620 Pro. Specifically, im looking for 8x discs that the BenQ will write at 16x.......
Thanks in advance.
cbboy777 wrote:dolphinius_rex.....thanks much for the heads up on the BenQ 1620. Burned 4 discs with crappy ESA dvd+r 8x and the quality was much much better than my old crappy Samsung/TSSTCorp H552B on TDK 8x.
P.S. hey give heads up on any good deals on those Taiyo Yuden 8x discs too. Much obliged.
cbboy777 wrote:Orange County, CAlifornia, U.S.
dolphinius_rex wrote:cbboy777 wrote:Orange County, CAlifornia, U.S.
Deffinately go to Rima.com then!
dolphinius_rex wrote:Then go to Precision Sound Corp. in Toronto, and tell Bruce "The Dolphin" sent you
traian2003 wrote:dolphinius_rex wrote:Then go to Precision Sound Corp. in Toronto, and tell Bruce "The Dolphin" sent you
Do they have a site or a number? Any prices?
dolphinius_rex wrote:Acro Circle 8x DVD-Rs (with OPTODISCR008 code) burn quite well at 8x on the DW1620 Pro. Taiyo Yuden 8x DVD+Rs burn very well at 16x as well. Stay away from all Prodisc DVD-Rs. Verbatim is a crap shoot.
All Content is Copyright (c) 2001-2021 CDRLabs Inc. |
