best program for .bin and .cue images?
Postby otak on Sat Jun 19, 2004 7:21 am
I am using Nero 5 but I have problem with writing .bin and .cue images. Sorri 4 a newbi question , but do I need some other file except .bin or .cue
image..? Thank you and have a nice day... :D
otak
Postby Ian on Sat Jun 19, 2004 1:00 pm
What kind of problems? You might want to upgrade to Nero 6. It has better bin/cue support. Otherwise there's good old CDRWIN.
Postby TheCDBurner on Sat Jun 19, 2004 5:55 pm
You can use Daemon Tools (free!) to mount the BIN/CUE image files, then use Nero to copy from the virtual drive to the CD-R.
CopyToDVD has no problem with BIN/CUE, either...
TheCDBurner
Postby Boba_Fett on Sat Jun 19, 2004 7:04 pm
Nero 5 & 6 both give me very weird errors whe I try to burn a cue/bin image (ironically I just got one today). I prefer fireburner for burning all my cue/bin stuff, but unfortunately, the guy behind that cool program seems to have lost the will to make it compatable with todays burners (Last updated in 2003, luckily my 48x Lite-on combo DVD drive works with it).
eVGA NF4 SLI mobo
2GB Mushkin DDR PC4000
Pioneer 111D 16x DVD burner
Onboard Sound :(
Boba_Fett
Postby TheWizard on Mon Jun 21, 2004 9:08 am
Nero, baby, Nero. But if that gives you problems, try Alcohol 120%.
No, I like women.
I have heard Alcohol is great.
Postby AmanO on Sat Jun 26, 2004 12:18 pm
topic.
AmanO
