is BTC 52X24X52 BETTER THAN BENQ 52X24X52
Postby liteonrules on Mon May 12, 2003 1:36 pm
I WAS GOING TO BUY A MICRO ADVANTAGE (BTC)52X SPEED FOR 50.00 W/ 30.00 REBATE= 19.99 AT OFFICE MAX BUT BEST BUY HAS THE DIGITAL RESEARCH 52X(BENQ) FOR 19.99 AFTER TWO REBATES. I DON'T MIND THE REBATES, I JUST WANT THE BETTER ONE
BTC OR BENQ? THANK U
NEC 2500A $20 10/04
NEC 3500AG for $47 4/05
NEC 3540 for $35 9/05
BENQ 1620 for $36 9//05
liteonrules
Postby Inertia on Mon May 12, 2003 1:51 pm
This may not address your question, but frankly I wouldn't buy either one. Neither matches a LiteOn for quality, features and web support.
P.S. Your CAPS key is stuck. All caps is akin to shouting and is not a good style for forums.
Inertia
Postby CDRecorder on Mon May 12, 2003 2:31 pm
I'd go with the Benq. I have a Benq 4824P and it's not as good as a Lite-On, but I think that it's probably better than the BTC. I bought the 4824P because it was free after MIR, and it's much better than I had expected, considering Benq's reputation.
Postby jase on Mon May 12, 2003 5:45 pm
Disagree completely.
Barring support (firmware updates are a bit thin on the ground) the BTC is a MUCH better writer than the Benq. I have a BTC 48x here and have had the dubious pleasure of using the Benq 52x and can safely say the BTC is a joy next to the Benq.
The BTC is media friendly, SD2 compliant, reads protected audio, produces discs of good quality (not as good as LiteOn but for example 0.5 ave C1 on Ritek 48x media vs 0.3 for LiteOn on average) and is stable and well built.
BTC are very underrated these days IMHO.
jase
Postby jedimc on Tue May 13, 2003 4:31 am
doesn't Acer make benQ :lol:
and Samsung CD-ROM SC-148T
jedimc
Postby cfitz on Tue May 13, 2003 9:24 am
Yes, BenQ is the new brand name for Acer.
