Hello all,
After hearing so much about Nero, I decided to purchase a copy. Several months later I've yet to burn a single CD! The install was a nightmare put on the bottom of my To Do list, and now after getting that done, I can't make any CDs. This is my last effort before junking this software.
The Write Speed setting is set at 2x and cannot be altered. The box is greyed out. I attempted to burn at that speed and received an error. Below is the log (thank you in advance):
lts
Windows 2000 5.0
IA32
WinAspi: -
ahead WinASPI: File 'D:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 7:18:06 PM
Nero version: 6.3.0.3 (Nero Express)
Recorder: <SAMSUNG CD-R/RW SW-224B> Version: R205 - HA 2 TA 1 - 6.3.0.3
Adapter driver: <atapi> HA 2
Drive buffer : 2048kB
CD-ROM: <SAMSUNG CD-R/RW SW-224B >Version: R205 - HA 2 TA 1 - 6.3.0.3
=== Scsi-Device-Map ===
DiskPeripheral : MAXTOR 4K080H4 A08. Pnp680 Port 0 ID 0 DMA: Off
CdRomPeripheral : E-IDE CD-ROM 52X/AKH A62 Pnp680 Port 0 ID 1 DMA: Off
DiskPeripheral : Maxtor NOVA UDMA 66 Pnp680 Port 0 ID 0 DMA: Off
DiskPeripheral : Maxtor 6Y080P0 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CD-R/RW SW-224B atapi Port 2 ID 1 DMA: On
DiskPeripheral : Maxtor 34098H4 YAH8 Hpt3xxNT Port 3 ID 0 DMA: Off
DiskPeripheral : MAXTOR 4K040H2 A08. Hpt3xxNT Port 3 ID 0 DMA: Off
OtherPeripheral : HPT RCM DEVICE Hpt3xxNT Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
E-IDE CD-ROM 52X/AKH E: CDRom2
SAMSUNG CD-R/RW SW-224B F: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 169MB (173376kB)
Memory in use : 66 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 1
Use Inquiry : 1
Global Bus Type: default (0)
1.3.2004
Audio CD
1:16:19 AM #1 CDADOC -1 File Cdadoc.cpp, Line 1508
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 01:24.61, Pause frames: 150, Filters: 0, Name: '01 - Nuyorican Soul Intro.wav'.
Track 02: Length: 05:19.55, Pause frames: 150, Filters: 0, Name: '02 - I Am The Black Gold Of The Sun.wav'.
Track 03: Length: 03:18.51, Pause frames: 150, Filters: 0, Name: '03 - It's Alright, I Feel It!.wav'.
Track 04: Length: 06:19.61, Pause frames: 150, Filters: 0, Name: '04 - MAW Latin Blues.wav'.
Track 05: Length: 04:26.53, Pause frames: 150, Filters: 0, Name: '05 - Gotta New Life.wav'.
Track 06: Length: 07:12.28, Pause frames: 150, Filters: 0, Name: '06 - Nautilus (Mawtilus).wav'.
Track 07: Length: 04:59.07, Pause frames: 150, Filters: 0, Name: '07 - Taita Cañeme.wav'.
Track 08: Length: 06:08.61, Pause frames: 150, Filters: 0, Name: '08 - Habriendo El Dominante.wav'.
Track 09: Length: 03:07.30, Pause frames: 150, Filters: 0, Name: '09 - Roy's Scat.wav'.
Track 10: Length: 05:10.58, Pause frames: 150, Filters: 0, Name: '10 - Sweet Tears.wav'.
Track 11: Length: 07:53.52, Pause frames: 150, Filters: 0, Name: '11 - Runaway.wav'.
Track 12: Length: 07:12.63, Pause frames: 150, Filters: 0, Name: '12 - Shoshana.wav'.
Track 13: Length: 02:53.22, Pause frames: 150, Filters: 0, Name: '13 - Jazzy Jeff's Theme.wav'.
Track 14: Length: 08:43.19, Pause frames: 150, Filters: 0, Name: '14 - You Can Do It (Baby).wav'.
Total size: 74:39.21
1:16:19 AM #2 Phase 75 File dlgbrnst.cpp, Line 1800
JustLink activated
1:16:19 AM #3 Text 0 File Reader.cpp, Line 118
Reader running
1:16:19 AM #4 Text 0 File Writer.cpp, Line 124
Writer SAMSUNG CD-R/RW SW-224B running
1:16:19 AM #5 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using CD-R/RW media
1:16:20 AM #6 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 359847 ( 79:59.72)
Last address to be written: 335795 ( 74:39.20)
1:16:20 AM #7 Text 0 File DlgWaitCD.cpp, Line 245
1:16:20 AM #8 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: SAMSUNG CD-R/RW SW-224B;
CDRW code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data: ?
1:16:20 AM #9 Text 0 File DlgWaitCD.cpp, Line 406
1:16:20 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 779
0: TRM_AUDIO_NOPRE (01 - Nuyorican Soul Intro.wav)
original disc pos #0 + 6361 (6361) = #6361/1:24.61
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 6361 blocks [SAMSUNG CD-R/RW SW-224B ]
1: TRM_AUDIO_NOPRE (02 - I Am The Black Gold Of The Sun.wav)
original disc pos #0 + 23980 (23980) = #23980/5:19.55
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23980 blocks [SAMSUNG CD-R/RW SW-224B ]
2: TRM_AUDIO_NOPRE (03 - It's Alright, I Feel It!.wav)
original disc pos #0 + 14901 (14901) = #14901/3:18.51
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14901 blocks [SAMSUNG CD-R/RW SW-224B ]
3: TRM_AUDIO_NOPRE (04 - MAW Latin Blues.wav)
original disc pos #0 + 28486 (28486) = #28486/6:19.61
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 28486 blocks [SAMSUNG CD-R/RW SW-224B ]
4: TRM_AUDIO_NOPRE (05 - Gotta New Life.wav)
original disc pos #0 + 20003 (20003) = #20003/4:26.53
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20003 blocks [SAMSUNG CD-R/RW SW-224B ]
5: TRM_AUDIO_NOPRE (06 - Nautilus (Mawtilus).wav)
original disc pos #0 + 32428 (32428) = #32428/7:12.28
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 32428 blocks [SAMSUNG CD-R/RW SW-224B ]
6: TRM_AUDIO_NOPRE (07 - Taita Cañeme.wav)
original disc pos #0 + 22432 (22432) = #22432/4:59.7
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22432 blocks [SAMSUNG CD-R/RW SW-224B ]
7: TRM_AUDIO_NOPRE (08 - Habriendo El Dominante.wav)
original disc pos #0 + 27661 (27661) = #27661/6:8.61
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 27661 blocks [SAMSUNG CD-R/RW SW-224B ]
8: TRM_AUDIO_NOPRE (09 - Roy's Scat.wav)
original disc pos #0 + 14055 (14055) = #14055/3:7.30
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14055 blocks [SAMSUNG CD-R/RW SW-224B ]
9: TRM_AUDIO_NOPRE (10 - Sweet Tears.wav)
original disc pos #0 + 23308 (23308) = #23308/5:10.58
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23308 blocks [SAMSUNG CD-R/RW SW-224B ]
10: TRM_AUDIO_NOPRE (11 - Runaway.wav)
original disc pos #0 + 35527 (35527) = #35527/7:53.52
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 35527 blocks [SAMSUNG CD-R/RW SW-224B ]
11: TRM_AUDIO_NOPRE (12 - Shoshana.wav)
original disc pos #0 + 32463 (32463) = #32463/7:12.63
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 32463 blocks [SAMSUNG CD-R/RW SW-224B ]
12: TRM_AUDIO_NOPRE (13 - Jazzy Jeff's Theme.wav)
original disc pos #0 + 12997 (12997) = #12997/2:53.22
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12997 blocks [SAMSUNG CD-R/RW SW-224B ]
13: TRM_AUDIO_NOPRE (14 - You Can Do It (Baby).wav)
original disc pos #0 + 39244 (39244) = #39244/8:43.19
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 39244 blocks [SAMSUNG CD-R/RW SW-224B ]
1:16:20 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [SAMSUNG CD-R/RW SW-224B ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 14:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 15313872, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 15313872 15666672 72067632, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 72067632 72420432 107467584, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 107467584 107820384 174819456, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 174819456 175172256 222219312, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 222219312 222572112 298842768, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 298842768 299195568 351955632, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 351955632 352308432 417367104, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 417367104 417719904 450777264, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 450777264 451130064 505950480, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 505950480 506303280 589862784, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 589862784 590215584 666568560, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 666568560 666921360 697490304, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 697490304 697843104 790144992, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x01
-150 | 1 | 0 | 0x00 | 0x21
0 | 1 | 1 | 0x00 | 0x21
6361 | 2 | 0 | 0x00 | 0x21
6511 | 2 | 1 | 0x00 | 0x21
30491 | 3 | 0 | 0x00 | 0x21
30641 | 3 | 1 | 0x00 | 0x21
45542 | 4 | 0 | 0x00 | 0x21
45692 | 4 | 1 | 0x00 | 0x21
74178 | 5 | 0 | 0x00 | 0x21
74328 | 5 | 1 | 0x00 | 0x21
94331 | 6 | 0 | 0x00 | 0x21
94481 | 6 | 1 | 0x00 | 0x21
126909 | 7 | 0 | 0x00 | 0x21
127059 | 7 | 1 | 0x00 | 0x21
149491 | 8 | 0 | 0x00 | 0x21
149641 | 8 | 1 | 0x00 | 0x21
177302 | 9 | 0 | 0x00 | 0x21
177452 | 9 | 1 | 0x00 | 0x21
191507 | 10 | 0 | 0x00 | 0x21
191657 | 10 | 1 | 0x00 | 0x21
214965 | 11 | 0 | 0x00 | 0x21
215115 | 11 | 1 | 0x00 | 0x21
250642 | 12 | 0 | 0x00 | 0x21
250792 | 12 | 1 | 0x00 | 0x21
283255 | 13 | 0 | 0x00 | 0x21
283405 | 13 | 1 | 0x00 | 0x21
296402 | 14 | 0 | 0x00 | 0x21
296552 | 14 | 1 | 0x00 | 0x21
335796 | lead-out | 1 | 0x00 | 0x01
1:16:20 AM #12 Phase 28 File dlgbrnst.cpp, Line 1800
Speed measurement started
1:16:20 AM #13 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
1:16:20 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #6511
1:16:20 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #30641
1:16:20 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #45692
1:16:20 AM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #74328
1:16:20 AM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #94481
1:16:20 AM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #127059
1:16:20 AM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #149641
1:16:20 AM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #177452
1:16:20 AM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #191657
1:16:20 AM #23 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #215115
1:16:20 AM #24 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #250792
1:16:20 AM #25 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #283405
1:16:20 AM #26 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #296552
1:17:05 AM #27 Text 0 File WriterStatus.cpp, Line 115
<SAMSUNG CD-R/RW SW-224B > start writing Lead-Out at LBA 335796 (51FB4h), lenght 0 blocks
1:17:05 AM #28 Text 0 File ThreadedTransfer.cpp, Line 229
1:17:06 AM #29 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
1:17:06 AM #30 Phase 29 File dlgbrnst.cpp, Line 1751
Speed measurement completed: 110.7x (16,606 KB/s)
1:17:06 AM #31 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 2x (300 KB/s)
1:17:06 AM #32 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #33 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #34 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #35 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #36 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #37 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #38 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #39 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #40 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #41 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #42 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #43 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #44 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #45 Text 0 File ThreadedTransferInterface.cpp, Line 2264
1:17:06 AM #46 Text 0 File Mmc.cpp, Line 14881
StartDAO : CD-Text - On
1:17:06 AM #47 Text 0 File Mmc.cpp, Line 19487
Set BUFE: JustLink -> ON
1:17:06 AM #48 Text 0 File Mmc.cpp, Line 15170
CueData, Len=240
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 01 1a 3d
21 02 01 00 00 01 1c 3d
21 03 00 00 00 06 30 29
21 03 01 00 00 06 32 29
21 04 00 00 00 0a 09 11
21 04 01 00 00 0a 0b 11
21 05 00 00 00 10 1f 03
21 05 01 00 00 10 21 03
21 06 00 00 00 14 3b 38
21 06 01 00 00 15 01 38
21 07 00 00 00 1c 0e 09
21 07 01 00 00 1c 10 09
21 08 00 00 00 21 0f 10
21 08 01 00 00 21 11 10
21 09 00 00 00 27 1a 02
21 09 01 00 00 27 1c 02
21 0a 00 00 00 2a 23 20
21 0a 01 00 00 2a 25 20
21 0b 00 00 00 2f 30 0f
21 0b 01 00 00 2f 32 0f
21 0c 00 00 00 37 2b 43
21 0c 01 00 00 37 2d 43
21 0d 00 00 00 3e 3a 37
21 0d 01 00 00 3f 00 37
21 0e 00 00 00 41 36 02
21 0e 01 00 00 41 38 02
01 aa 01 01 00 4a 27 15
1:19:29 AM #49 SCSI -1135 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 2, TA 1, LUN 0, buffer 0x0CE60000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x05 0x46 0x00 0x00 0x1B 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
1:19:29 AM #50 CDR -1135 File Writer.cpp, Line 301
Write error
1:19:29 AM #51 Text 0 File ThreadedTransfer.cpp, Line 229
1:19:30 AM #52 Text 0 File ThreadedTransfer.cpp, Line 223
1:19:35 AM #53 Text 0 File dlgbrnst.cpp, Line 1658
1:19:35 AM #54 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 2x (300 KB/s)
Existing drivers:
File 'Drivers\CDR4_2K.SYS': Ver=5.3.2.31, size=58000 bytes, created 9/8/2003 1:38:19 AM
File 'Drivers\CDRALW2K.SYS': Ver=5.3.2.31, size=23420 bytes, created 9/8/2003 1:38:19 AM
File 'Drivers\atapi.sys': Ver=5.00.2195.6699, size=86672 bytes, created 6/19/2003 2:05:04 PM (Adapter driver for rec)
Registry Keys:
