can't flash LTR-52246S firmware 6SOF from 6SOD? WTF?
Postby SkaarjMaster on Sat Apr 03, 2004 1:05 am
I have this Lite-On burner on my Win98SE computer and just checked tonight and noticed new firmware, so I thought I'd update it. Well, it didn't work with 2 reboots and kept saying "program error, if problem persists...."
Is this new firmware for XP only? It just says Windows at the Lite-On site. What could be wrong? No big deal, but would be nice to have the latest firmware. Thank you.
SkaarjMaster
Postby dhc014 on Sat Apr 03, 2004 1:31 am
If using Windows 98/ME, then you need to have ASPI installed properly. ForceASPI is the best version to use for Liteon Windows Flashers.
dhc014
Postby SkaarjMaster on Sat Apr 03, 2004 2:11 am
Nope, installed the new ASPI layer and it still didn't work.
SkaarjMaster
Postby SkaarjMaster on Mon Apr 05, 2004 11:59 am
Anyone have any idea why I still can't flash it? I also can't flash on old 4.8X Toshiba DVD-ROM either (SD-M1202 I think).
SkaarjMaster
Postby Centrilium on Tue Apr 06, 2004 2:43 pm
Have you tried using Flashfix on the firmware you downloaded?
Centrilium
Postby SkaarjMaster on Fri Apr 09, 2004 10:36 pm
Yep, just tried it just now and it didn't work. I still get the "This program has performed an illegal operation......." error. :(
Is this Flashfix only for Lite-On drives or can it work for my Toshiba DVD-ROM as well?
SkaarjMaster
Postby wicked1 on Fri Apr 09, 2004 11:21 pm
try using mtkflash or mtkwinflash. You might wanna try a boot disk and flash in dos.
2 gb ddr2 1066 mhz ram
geforce 7600GT
sb audigy 2 zs platnum
hardware mpeg2 encoder card
wicked1
Postby SkaarjMaster on Sat Apr 10, 2004 1:00 am
Well, I used LtnFW and DLed the Bin file from a site mentioned in the forum thread mentioned at the Mtkflash site. The Control Panel/System/CD-ROM section shows the firmware as the latest 6SOF, so I guess I'm all right.
I'm not going to worry about the Toshiba DVD-ROM; it's about 5 years old anyway. Thanks!
SkaarjMaster
