"Could not perform Fixation" w/PX-504A???
Postby BurninMan921 on Tue Jun 10, 2003 1:52 pm
Alright, 4 CD's in a row and this error at the very end of the burn.
"Session fixation error
The burner is a PX-504A, firmware 1.01.
Using Nero 5.5.10.35. DMA is enable across the board. All the latest drivers, etc. The CD's are Verbatim DataLifePlus SuperAzo 48x rated discs. Burn speed is 16x (max for the Plextor).
Any ideas? I've burned about 60 of these same discs before.
EDIT:
Make it four discs, including Fuji Film 48x now. Burning to a DVD+RW disc worked. I have not tried CD-RW discs yet; I will when I get home from work. Nero's settings are the same that I've always used (mostly default), and am using the Wizard (setting to no multisession, though).
If I put the disc back into the burner, Nero registers it as being blank.
BurninMan921
