Displaying actual write speed with Nero ?
Postby Wedge Maniac on Fri Mar 07, 2003 11:15 pm
I did a burn of music and the speed stayed constant at 16x (typically my preference for burning audio to CDRs). So I'm not sure if it's working or not. I will do another burn and post back the results.
Just FYI, I use a TDK 4800B, which is a Liteon 48246S, if I'm not mistaken. Also, this version of Nero -5590- came bundled with it.
Wedge Maniac
Postby MediumRare on Sat Mar 08, 2003 2:48 pm
The fix had worked for me (Win XP Home/SP1), but just for kicks, I tried it on my old system (Win95A, just used for communication, not burning anymore) - and it didn't stay fixed. The values in the registry changed when the "burn" button was pressed, but also on exit after simulation. After reading the last few posts in this thread, I did some more tests. Results: on both rigs the fix works and stays put only if the key is set to 1 in HKCU and to 0 in HKLM. However, sometimes only HKCU was reset to 0 (on exit after simulation), sometimes both keys. Don't nail me down on the combination. This seems to jibe with everything else posted recently.
Wedge Maniac wrote:I did a burn of music and the speed stayed constant at 16x (typically my preference for burning audio to CDRs). So I'm not sure if it's working or not. I will do another burn and post back the results.
Just have a look in the registry- if the value is "1", it stayed active.
Postby Wedge Maniac on Sun Mar 09, 2003 12:29 am
Oh yes, it stayed at "1". That value sticks for HKCU, regardless of whether I'm doing a real burn, simulation, closing and reopening Nero...it stays at "1".
Wedge Maniac
Postby eBast on Wed Mar 19, 2003 10:33 am
New version 5.5.10.15a is supposed to have this speed issue fixed..
I have downloaded the update, but havent tried it yet, will post my findings.
eBast
Postby Wedge Maniac on Thu Mar 20, 2003 12:12 am
Cool eBast, thanks for the heads-up :D
Wedge Maniac
Postby Banshee on Thu May 01, 2003 7:34 pm
Craig, can I just post your work cell phone number instead so they can direct call you with their questions? :)
Scott Labrecque
Banshee
Coder - http://www.planetquake.com/alliance and http://www.lrctf.com
Editor-in-Chief - http://www.pcextremist.com
President and Videographer - http://www.velocitymc.org
Banshee
Postby VEFF on Sun Sep 14, 2003 12:21 pm
cfitz wrote:For those who don't want to edit their registry manually, open up a text editor and copy and paste the following:
Code: Select all
REGEDIT4
[HKEY_CURRENT_USER\Software\Ahead\Nero - Burning Rom\Recorder]
"ShowSingleRecorderSpeed"=dword:00000001
Save the file with the name "showspeed.reg", and then double-click the file to enter the information into your registry.
<edit>
Removed erroneous entry that changed the value under the HKEY_LOCAL_MACHINE hive as well, and deleted request to let me know if it works (beacause it does work)
</edit>
Tried it in Nero 6, and it not only worked, but the key's value did NOT keep returning to 0 upon exit of regedit or Nero.
Burners only:
Pioneer DVR-115D
Pioneer DVR-111D
Plextor PX-716A TLA0304
Plextor PX-716A same TLA
LiteOn 52246S 52X CD-RW
LiteOn 52246S (another)
LiteOn 52327S 52X CD-RW
TDK 40X USB 2.0 CD-RW
TEAC CD-W540E 40X CD-RW
VEFF
Postby aviationwiz on Sun Sep 14, 2003 12:29 pm
Bringing back dead threads, eh?
I too have used that little trick and it works great on a new install of Nero 6.
Postby VEFF on Sun Sep 14, 2003 1:43 pm
Yes :)
I was trying to see how fast my 708A was actually burning DVDs, and noticed that the usual registry key didn't exist in Nero 6 anymore, so I looked for threads (from the dead).
Burners only:
Pioneer DVR-115D
Pioneer DVR-111D
VEFF
Postby Dartman on Sat Oct 18, 2003 5:17 pm
If anybody has all their settings right and the patch still doesn't work uninstall Nero and clean out the registry of the Ahaed/Nero stuff and reinstall, then add the thing manualy or with the reg file. I found this comment on CD Freaks and it worked so far for me. My old copy of XP on my old boot drive took it just fine but for whatever reason it wouldn't work on the new boot drive. Nero worked the show speed didn't.
Postby Spazmogen on Sat Oct 18, 2003 9:04 pm
I had this trick working with Nero 5.5x, but it vanished when I upgraded to Nero 6.
I had to manually create the entry, after that it worked fine.
