DVD Burn Failure: NeroVision Express 3.0.1.14 (need help)
Postby fatmonkey10 on Sun Dec 26, 2004 4:38 pm
Any thoughts appreciated. I have been trying to burn a slideshow to DVD on various formats but have been receiving burnfailure or lockup. I "burned" the file to a C: directory to ensure the problem was not with the DVD burner with similar results. Attached please find examples from two burn logs:
EXAMPLE 1
[00:51:53] AMCDocBase EXCEPTION "StartStreaming: Run" (GCMediaStream.cpp, line 339: Ran out of memory (0x8007000e))
[00:51:53] MMTools unable to use cache: 0x80040216 -
[00:51:53] MMTools adding c:\Documents and Settings\All Users\Documents\My Music\From CD\Toad the Wet Sprocket\Acoustic Dance Party\Walk on the Ocean Toad the Wet Sprocket Acoustic Dance Party 192kbps.wma audio/0
[00:51:54] DVDEngine ********END: _VOBS - Process VOB
[00:51:54] DVDEngine ******END: VTSTT_VOBS#15 - Process Create
[00:51:54] DVDEngine ****END: Create - VTSTT_VOBS#15
[00:51:54] DVDEngine **END: _DVDVideo - Create
[00:51:54] DVDEngine ########################################################################################
[00:51:54] DVDEngine ERROR
[00:51:54] DVDEngine cause: 128 (nmc_processing_exception)
[00:51:54] DVDEngine source: StartStreaming
[00:51:54] DVDEngine description: Cannot seek graph to segment start
[00:51:54] DVDEngine **BEGIN: IDVDSessionBaseImpl - Clear
[00:51:54] DVDEngine **END: IDVDSessionBaseImpl - Clear
[00:51:54] DVDEngine END: IDVDVideoSessionImpl - CreateDisc
[00:51:58] NeroAPI Burn process failed at 1x (1,385 KB/s)
[00:52:10] DVDEngine BEGIN: IDVDSessionBaseImpl - EndDiscAccess
[00:52:10] DVDEngine ..Flags=0
[00:52:10] DVDEngine **BEGIN: _MediaAccess::Release ()
[00:52:10] DVDEngine ****BEGIN: _MediaAccess::~_MediaAccess ()
[00:52:10] DVDEngine ****END: _MediaAccess::~_MediaAccess ()
[00:52:10] DVDEngine **END: _MediaAccess::Release ()
[00:52:10] DVDEngine END: IDVDSessionBaseImpl - EndDiscAccess
[00:52:10] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[00:52:10] DVDEngine ..Session callback unregistered...
[00:52:10] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[00:52:13] GCHW Node added: Microsoft Kernel Wave Audio Mixer
[00:59:48] GCHW Node removed: Microsoft Kernel Wave Audio Mixer
EXAMPLE #2
[08:52:40] AMCDocBase EXCEPTION "StartStreaming: Run" (GCMediaStream.cpp, line 339: Ran out of memory (0x8007000e))
[08:52:40] MMTools adding cached c:\Documents and Settings\All Users\Documents\My Music\From CD\Edwin McCain Band\Messenger\I Could Not Ask for More Edwin McCain Messenger 192kbps.wma audio/0
[08:52:40] MMTools unable to use cache: 0x80040216 -
[08:52:40] MMTools adding c:\Documents and Settings\All Users\Documents\My Music\From CD\Edwin McCain Band\Messenger\I Could Not Ask for More Edwin McCain Messenger 192kbps.wma audio/0
[08:52:41] DVDEngine ********END: _VOBS - Process VOB
[08:52:41] DVDEngine ******END: VTSTT_VOBS#1 - Process Create
[08:52:41] DVDEngine ****END: _DVDVideoBase - Prepare VTS#1
[08:52:41] DVDEngine **END: _DVDVideo - Prepare
[08:52:41] DVDEngine ########################################################################################
[08:52:41] DVDEngine ERROR
[08:52:41] DVDEngine cause: 128 (nmc_processing_exception)
[08:52:41] DVDEngine source: StartStreaming
[08:52:41] DVDEngine description: Cannot seek graph to segment start
[08:52:41] DVDEngine **BEGIN: IDVDSessionBaseImpl - Clear
[08:52:41] DVDEngine **END: IDVDSessionBaseImpl - Clear
[08:52:41] DVDEngine END: IDVDVideoSessionImpl - Prepare
[08:52:41] DVDEngine BEGIN: IDVDSessionBaseImpl - EndDiscAccess
[08:52:41] DVDEngine ..Flags=0
[08:52:41] DVDEngine **BEGIN: _MediaAccess::Release ()
[08:52:41] DVDEngine ****BEGIN: _MediaAccess::~_MediaAccess ()
[08:52:41] DVDEngine ****END: _MediaAccess::~_MediaAccess ()
[08:52:41] DVDEngine **END: _MediaAccess::Release ()
[08:52:41] DVDEngine END: IDVDSessionBaseImpl - EndDiscAccess
[08:52:41] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[08:52:41] DVDEngine ..Session callback unregistered...
[08:52:41] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[08:56:29] GCHW Node removed: Microsoft Kernel Wave Audio Mixer
fatmonkey10
Postby HardwareHarry on Tue Dec 28, 2004 1:59 pm
The only thing I can see it hangs on your Microsoft Wave Audio Mixer !
repeating:
HardwareHarry
Users browsing this forum: No registered users and 16 guests
