DVD ripping speed
DVD ripping speed
Postby perdomot on Sat Feb 12, 2005 12:50 pm
My new NEC 3520 only gets around 4 X when ripping a dvd to the hard drive and I was wondering if this is a normal. Would a regular 16X DVD ROM rip DVDs any faster? I'm using Smartripper to rip the dvds. Thanks.
perdomot
Postby Bhairav on Sat Feb 12, 2005 1:07 pm
You need a riplock removed version of the 3500 firmware, go to http://tdb.rpc1.org and take your pick.
Postby perdomot on Sat Feb 12, 2005 2:18 pm
Whats "riplock"? I'm kinda new to this stuff and that page doesn't explain much. Thanks.
perdomot
Postby burninfool on Sun Feb 13, 2005 12:45 am
NEC writers are locked at 4x,you need to use a hacked firmware or buy a DVD-ROM.
Postby hoxlund on Sun Feb 13, 2005 3:14 am
im likin my new litey that has rip locked removed, rips at full 16x on single layer
Postby ETP on Sun Feb 13, 2005 7:08 am
Hot off the hack line!
3520=
http://club.cdfreaks.com/showthread.php?t=124886
3500=
http://club.cdfreaks.com/showthread.php?t=125855&page=1
You will need bin flash for windows and you are ready to go.
BINFLASH wipes your FW clean and allows cheese and anything else to be inserted.
BQ 1640 BSOB
NEC 4550 1.6T
Plextor 716a 1.09
Pioneer 109/A09 158
Pioneer 110/A10 1.39
Liteon 5005
Sony 875P & 333ES
Liteon 5005
HK7200
Hitachi 61SDX
ETP
Postby perdomot on Sun Feb 13, 2005 11:23 am
Well, I flashed the drive and am testing now. Would a 16X DVD Rom drive actually rip a dvd at or near 16X? If so, is there a prefered brand to use? Thanks.
perdomot
Postby hoxlund on Sun Feb 13, 2005 11:32 am
single layer rips at 16x towards the end
Postby perdomot on Sun Feb 13, 2005 11:38 am
I just finished testing the flashed drive and the highest speed it got was 6.2X but then it suddenly dropped back down. I'm thinking a 16X DVD Rom would be much faster, even if it only read the data at 12X. Is anyone using a 16X to read their DVDs when they are backing them up? Thanks.
perdomot
Postby ETP on Sun Feb 13, 2005 5:27 pm
6.2x is about right to read a DL disk! Yes there are faster ones out there. I asked the same question a while back and decided to go with two 16X burners. 8x is about max for any DL. Single layer can only read 16X on a perfect day.
BQ 1640 BSOB
NEC 4550 1.6T
Plextor 716a 1.09
Pioneer 109/A09 158
Liteon 5005
Sony 875P & 333ES
Liteon 5005
HK7200
Hitachi 61SDX
ETP
Postby hoxlund on Sun Feb 13, 2005 9:59 pm
im using my hacked litey drive that is in my sig, and yes its full 16x on single layer
and ive never tested the rip speed of DL movies with dvd decrypter, but i can if you want me to
they should add that to dvdshrink, a rip speed read out while its ripping
Postby perdomot on Sun Feb 13, 2005 10:05 pm
How do I know if I'm ripping a dvd that's DL? Can I assume most movies on DVD for sale are DL?
perdomot
Postby hoxlund on Sun Feb 13, 2005 10:23 pm
to know for sure you can use dvd decrypter to check, but if its over 4.3GB or whatever it is then yes its DL
Postby TCAS on Mon Feb 14, 2005 4:29 am
perdomot wrote:I just finished testing the flashed drive and the highest speed it got was 6.2X but then it suddenly dropped back down. I'm thinking a 16X DVD Rom would be much faster, even if it only read the data at 12X. Is anyone using a 16X to read their DVDs when they are backing them up? Thanks.
ripping speed on NEC 3500 (or any writer) depends to :
1) The Disk is D/L or S/L?.
2) The Disk is protected disc or unprotected?.
3) The disk being ripped from protected video disk has to be shrink or just ripped or has to be encoded also?.
4) Also depends the Video movie that being ripped how the recording was formated or on what polatform?.
5) Finally the quality of video disk you are trying to rip?.
