Error deleting an .avi from my system....
Postby Spazmogen on Wed Mar 31, 2004 10:56 am
I made a DivX.avi with NanDub. It's a monster: 1.65GB.
The audio is screwed up (out of sync). I'm trying to remove it from my system, rather than just over write it. And the error above appears.
There is no other user set up on my system, Nero Showtime is the registered viewer.
To make it worse, I've saved it on 3 seperate drives (everytime I made a change to the audio offset).
I can't delete any of them!
Any ideas ?
Yes, I've tried to open it in NanDub and overwrite it. It makes no difference. There is no other software open that I can think of that would be causing this.
I can't even remove it in Safe Mode. :evil:
Postby Ian on Wed Mar 31, 2004 1:23 pm
Check the properties to see if its read only.
Postby Spazmogen on Wed Mar 31, 2004 1:40 pm
Ian wrote:Check the properties to see if its read only.
It's not Read Only. Also checked the advanced properties, nothing in there is checked off either.
It seems normal. I just can't delete it.
I tried regedit. I removed entries for it in there.
It still won't go away.
It's like an S.T.D. I can't cure.
Postby Spazmogen on Wed Mar 31, 2004 2:18 pm
I got it.
Nero's File Browser window let me delete it, when everything else would not.
Thanks for the help Ian. :wink:
