Error-9 in sector 17152 with Click'N Burn Pro 2.0
Postby ramaflore on Thu Feb 20, 2003 1:46 pm
Hello,
This is the error message when doing a test before writing a data cd I get;
I tried
Os: W98SE
cd-writer: Phillips Jackrabbit 24x12x40
Others soft installed: CloneCD, Isobuster, WInIso
Thanks for your help
ramaflore
Postby dodecahedron on Fri Feb 21, 2003 12:09 am
did you try other media?
Postby ramaflore on Fri Feb 21, 2003 6:56 am
No, I have not tried because it was only a test !
I will try and I will let you know.
Do I need to uninstall the Aspi layer 4.61 ??
ramaflore
Postby ramaflore on Fri Feb 21, 2003 2:39 pm
The same troubles.
Please, if you have others suggestions let me know, thanks.
ramaflore
Postby dodecahedron on Fri Feb 21, 2003 8:51 pm
what software do you use for burning?
try a different program maybe? try Nero?
i don't know if you should remove ASPI, b/c i don't know if the program you use need it - IsoBuster, WinIso. check up their info/websites. if they don't need APSI, maybe try removing it see if that helps.
what media did you use? try using quality media: Taiyo Yuden, Mitsubishi/Verbatim.
Postby ramaflore on Sat Feb 22, 2003 5:37 pm
I'm using Click'N Burning Pro 2.0
No problem with CLoneCD. I have tried Nero last version, but I had an unsolved problem. I had "SCSI targert error". I have not SCSI cd-writer.
The same brandname as my cd writer Phillips cd-r 80 700 Mb
Thanks .
ramaflore
Postby dodecahedron on Sat Feb 22, 2003 7:51 pm
Phillips is made by CMC, and it's not very good.
try other media.
if you can get it, try Fuji media, or Verbatim DataLifePlus.
if you can't get these try some other: TDK, Memorex or other branded media.
you can have a SCSI error even if you don't have a SCSI drive...some SCSI stuff is general to all CDRW drives.
if you give more info maybe someone can help you out with the Nero problems you've had.
Postby KCK on Sat Feb 22, 2003 11:09 pm
dodecahedron:
Apparently the problem is more complicated; see
http://club.cdfreaks.com/showthread.php ... adid=63944
KCK
Postby ramaflore on Sun Feb 23, 2003 3:44 pm
For now, I don't have Nero in my computer.
I want only to run Click'N Burn Pro. This program is the same than Prassi Primo CD Pro.
ramaflore
