Firmware for Nu Tech DDW-081
Postby psy84 on Wed Jul 07, 2004 7:59 am
Tomorrow I'll get the Nu Tech DDW-081. Now my question, which is the best firmware at the moment? I know there is a firmware that supports DVD-R. But it isn't the best I have heard or is there a new one? Who has this burner and is able to tell me which is the best firmware?
Next question: The firmware for the Nu Tech DDW-082 I can't use, or?
psy84
Postby klumy on Wed Jul 07, 2004 12:01 pm
you can use the B373 firmware from the DDW-082 without any problems
klumy
Postby psy84 on Wed Jul 07, 2004 2:23 pm
Are there any more errors in comparison to the original firmware?
Is the B373 firmware better than the B375?
I herad the rumor that it would possibly be able to burn double layer DVDs with this burner in the future, but there isn't any firmware there, yet. But the laser should be strong enough. Who had herad anything about that?
psy84
Postby klumy on Wed Jul 07, 2004 3:22 pm
time will show us, if this rumour is true or not. At the moment there is no such a firmware. at the moment I use B373 without any problems.
klumy
Postby aristottle on Wed Jul 07, 2004 5:22 pm
I use B375, I burn lots of different media.....what ever I find on sale, and no problems at all! :lol:
aristottle
Postby psy84 on Thu Jul 08, 2004 4:30 pm
So, now I got my Nu Tech. It's realy good. Just in the moment I burned a 4x Ricoh DVD+R with 8x which works. Is this normal? Does this work or should I burn only witch 4x when the DVD is 4x?
Next question. Could it be, that the burner needs a lot of energy? Because when I built in the burner in my pc and startet them, my pc rebooted by using the drive. As I removed my other DVD drive I had no problems anymore. Do I use more than 300W?
psy84
Postby klumy on Fri Jul 09, 2004 12:23 pm
you can burn your ricoh 4x without any problems at 8x speed.
to your 2nd question:
you need to install an hardware energy monitor to see how much power you really consume.
klumy
Postby psy84 on Fri Jul 09, 2004 12:29 pm
It's a good Idea to check my pc with an hardware energy monitor.
But in the moment I have no problems anymore.
Today I added my normal DVD drive again and now there are no problems.
psy84
Postby klumy on Fri Jul 09, 2004 1:55 pm
Cool, i'm glad to hear ;)
klumy
Postby KenW on Sat Jul 10, 2004 12:38 am
I also use B375 and used B373 before that its great with +R media and so so on -R media , i have not made coaster with any +R yet ricohR01 and mcc002 4x both burn wonderfully at 8x . I have not had whole lot lot of luck with -R i did try a ritek G05 nero gave me the 8x option nu tech burned it at 6x and it was coaster. I burned a optodisc R004 4x at 4x and it was not coaster. I have some tyg01 4x but i have not tested it yet.
oh also , I have liteon 832s i just burned mkm001 2.4x DL disk and set the booktype to DVD-ROM the nu tech 082 could not read this or even detect it.
KenW
Postby psy84 on Fri Sep 10, 2004 4:56 am
Ok, today I`ll test firmware B375 because I'll burn CD-RW 24x. Has anybody experience about burning CD-RW 24x?
psy84
Postby klumy on Fri Sep 10, 2004 5:27 am
if you have a cd-rw 24x medium it should work. but these medium are hard to get. most cd-rw medias are 12x
klumy
Postby psy84 on Fri Sep 10, 2004 5:41 am
I work in a computer company, so I ordered 10 pieces yesterday. There we get everything. Today I'll get them. Hope they will go.
psy84
Postby Ciryadin on Fri Sep 10, 2004 11:12 am
The B373 is more stable then the B375 but less media support.
There's a B376 in the works, no release date yet.
-= Looking Into The Abyss, Do You Feel Torture Or Bliss=-
NU-Europe
Field Application Engineer
Ciryadin
Postby OC-Freak on Sun Sep 12, 2004 4:03 pm
Ciryadin wrote:The B373 is more stable then the B375 but less media support.
To my experience:
B375 is better as long as you do not write DVD-R discs at 6x or 8x.
www.cdfreaks.com reviewer and forum administrator.
OC-Freak
Postby psy84 on Mon Sep 13, 2004 4:14 am
Now I have firmware B375 and it works. I can burn CD-RW 24x. DVD-R I dont want to burn, only DVD+R, i like them more. :D
psy84
