LG GCC-4480B burn problem
Postby RMGreen on Fri Jun 27, 2003 10:20 pm
I just got my LG GCC-4480B, but all I've managed to do so far with it is make coasters. Any time I try to do any burning, Nero Express gets a "Communication Error" and the burn fails. I'm using Memorex CD-R 48X multispeed discs.
I'll post a log below in case anyone can use it to decypher my problem. I've tried doing various types of burns (data discs, audio discs, burns from an image), and using different speeds, but I get the same problem.
Please help.
Thanks,
RMGreen
Log follows:
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 4/23/99 10:22:00 PM
Nero Version: 5.5.9.9 (Nero Express)
Recorder: <HL-DT-ST RW/DVD GCC-4480B>Version: 1.00 - HA 0 TA 1 - 5.5.9.9
Adapter driver: <ESDI_506> HA 0
Drive buffer : 2048kB
CD-ROM: <HL-DT-ST RW/DVD GCC-4480B>Version: 1.00 - HA 0 TA 1 - 5.5.9.9
ASUS CD-S520/A (Target 0, H:): Autoinsert On, DMA On, Disconnect ?, SyncDataXfer ?
HL-DT-ST RW/DVD GCC-4480B (Target 1, I:): Autoinsert On, DMA On, Disconnect ?, SyncDataXfer ?
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523720kB)
Free physical memory: 208MB (213988kB)
Memory in use : 38 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: On
27.6.2003
Audio CD
9:55:00 PM #1 CDADOC -1 File Cdadoc.cpp, Line 1616
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 05:36.59, Pause frames: 150, Filters: 1, Name: 'Soul Coughing- Super Bon Bon.mp3'.
Track 02: Length: 04:20.46, Pause frames: 150, Filters: 1, Name: 'Tranceparent - existance.mp3'.
Track 03: Length: 03:01.02, Pause frames: 150, Filters: 1, Name: 'TotalAudio - Halo.mp3'.
Track 04: Length: 04:59.09, Pause frames: 150, Filters: 1, Name: 'Tranceparent - daybreak.mp3'.
Track 05: Length: 06:39.34, Pause frames: 150, Filters: 1, Name: 'velvet acid christ - slut.mp3'.
Track 06: Length: 07:26.16, Pause frames: 150, Filters: 1, Name: 'Rob D - Clubbed To Death.mp3'.
Track 07: Length: 04:49.22, Pause frames: 150, Filters: 1, Name: 'Nine Inch Nails - Into the Void.mp3'.
Track 08: Length: 04:00.71, Pause frames: 150, Filters: 1, Name: 'Moby - Porcelain.mp3'.
Track 09: Length: 04:13.46, Pause frames: 150, Filters: 1, Name: 'Melanie C - I Turn To You.mp3'.
Track 10: Length: 05:23.21, Pause frames: 150, Filters: 1, Name: 'Fatboy Slim - Praise You.mp3'.
Track 11: Length: 04:39.55, Pause frames: 150, Filters: 1, Name: 'Fantasy - Whispering.mp3'.
Track 12: Length: 05:05.14, Pause frames: 150, Filters: 1, Name: 'Benny Goodman Band - Sing Sing Sing.mp3'.
Track 13: Length: 06:52.55, Pause frames: 150, Filters: 1, Name: 'Alice Deejay - Better Off Alone.mp3'.
Total size: 67:34.00
9:55:00 PM #2 Phase 90 File dlgbrnst.cpp, Line 1566
9:55:00 PM #3 Text 0 File Reader.cpp, Line 118
Reader running
9:55:00 PM #4 Text 0 File Writer.cpp, Line 134
Writer HL-DT-ST RW/DVD GCC-4480B running
9:55:00 PM #5 Text 0 File Burncd.cpp, Line 3542
Turn on Disc-At-Once, using CD-R/RW media
9:55:00 PM #6 Text 0 File ThreadedTransferInterface.cpp, Line 663
0: TRM_AUDIO_NOPRE (Soul Coughing- Super Bon Bon.mp3)
original CD pos #0 + 25259 (25259) = #25259/5:36.59
relocatable, CD pos for caching/writing not required/not required, no patch infos
1: TRM_AUDIO_NOPRE (Tranceparent - existance.mp3)
original CD pos #0 + 19546 (19546) = #19546/4:20.46
2: TRM_AUDIO_NOPRE (TotalAudio - Halo.mp3)
original CD pos #0 + 13577 (13577) = #13577/3:1.2
3: TRM_AUDIO_NOPRE (Tranceparent - daybreak.mp3)
original CD pos #0 + 22434 (22434) = #22434/4:59.9
4: TRM_AUDIO_NOPRE (velvet acid christ - slut.mp3)
original CD pos #0 + 29959 (29959) = #29959/6:39.34
5: TRM_AUDIO_NOPRE (Rob D - Clubbed To Death.mp3)
original CD pos #0 + 33466 (33466) = #33466/7:26.16
6: TRM_AUDIO_NOPRE (Nine Inch Nails - Into the Void.mp3)
original CD pos #0 + 21697 (21697) = #21697/4:49.22
7: TRM_AUDIO_NOPRE (Moby - Porcelain.mp3)
original CD pos #0 + 18071 (18071) = #18071/4:0.71
8: TRM_AUDIO_NOPRE (Melanie C - I Turn To You.mp3)
original CD pos #0 + 19021 (19021) = #19021/4:13.46
9: TRM_AUDIO_NOPRE (Fatboy Slim - Praise You.mp3)
original CD pos #0 + 24246 (24246) = #24246/5:23.21
10: TRM_AUDIO_NOPRE (Fantasy - Whispering.mp3)
original CD pos #0 + 20980 (20980) = #20980/4:39.55
11: TRM_AUDIO_NOPRE (Benny Goodman Band - Sing Sing Sing.mp3)
original CD pos #0 + 22889 (22889) = #22889/5:5.14
12: TRM_AUDIO_NOPRE (Alice Deejay - Better Off Alone.mp3)
original CD pos #0 + 30955 (30955) = #30955/6:52.55
9:55:00 PM #7 Text 0 File DlgWaitCD.cpp, Line 199
Last possible write address on media: 359845 (79:59.70)
Last address to be written: 303899 (67:33.74)
9:55:00 PM #8 Text 0 File DlgWaitCD.cpp, Line 204
9:55:00 PM #9 Text 0 File DlgWaitCD.cpp, Line 1403
Recorder: HL-DT-ST RW/DVD GCC-4480B;
CDRW code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
9:55:00 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 815
Prepare recorder HL-DT-ST RW/DVD GCC-4480B for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close CD
Tracks 1 to 13:
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 0 352800 59761968
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 59761968 60114768 106086960
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 106086960 106439760 138372864
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 138372864 138725664 191490432
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 191490432 191843232 262306800
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 262306800 262659600 341371632
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 341371632 341724432 392755776
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 392755776 393108576 435611568
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 435611568 435964368 480701760
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 480701760 481054560 538081152
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 538081152 538433952 587778912
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 587778912 588131712 641966640
TRM_AUDIO_NOPRE, 2352/0x0, ISRC "", FilePos 641966640 642319440 715125600
9:55:54 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 663
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25259 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19546 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13577 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22434 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 29959 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 33466 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21697 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18071 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19021 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24246 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20980 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22889 blocks [HL-DT-ST RW/DVD GCC-4480B]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 30955 blocks [HL-DT-ST RW/DVD GCC-4480B]
9:55:54 PM #12 Phase 36 File dlgbrnst.cpp, Line 1566
Burn process started at 24x (3,600 KB/s)
9:55:54 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
9:55:54 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 1 (relocatable, no CD pos, no patch infos, orig at #0): write at #25409
9:55:54 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 2 (relocatable, no CD pos, no patch infos, orig at #0): write at #45105
9:55:54 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 3 (relocatable, no CD pos, no patch infos, orig at #0): write at #58832
9:55:54 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 4 (relocatable, no CD pos, no patch infos, orig at #0): write at #81416
9:55:54 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 5 (relocatable, no CD pos, no patch infos, orig at #0): write at #111525
9:55:54 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 6 (relocatable, no CD pos, no patch infos, orig at #0): write at #145141
9:55:54 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 7 (relocatable, no CD pos, no patch infos, orig at #0): write at #166988
9:55:54 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 8 (relocatable, no CD pos, no patch infos, orig at #0): write at #185209
9:55:54 PM #22 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 9 (relocatable, no CD pos, no patch infos, orig at #0): write at #204380
9:55:54 PM #23 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 10 (relocatable, no CD pos, no patch infos, orig at #0): write at #228776
9:55:54 PM #24 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 11 (relocatable, no CD pos, no patch infos, orig at #0): write at #249906
9:55:54 PM #25 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 12 (relocatable, no CD pos, no patch infos, orig at #0): write at #272945
9:55:54 PM #26 Text 0 File Mmc.cpp, Line 12444
StartDAO : CD-Text - On
9:55:54 PM #27 Text 0 File Mmc.cpp, Line 16973
Set BUFE: supported -> ON
9:55:54 PM #28 Text 0 File Mmc.cpp, Line 12704
CueData, Len=224
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 05 26 3b
21 02 01 00 00 05 28 3b
21 03 00 00 00 0a 01 1e
21 03 01 00 00 0a 03 1e
21 04 00 00 00 0d 04 20
21 04 01 00 00 0d 06 20
21 05 00 00 00 12 05 29
21 05 01 00 00 12 07 29
21 06 00 00 00 18 2f 00
21 06 01 00 00 18 31 00
21 07 00 00 00 20 0f 10
21 07 01 00 00 20 11 10
21 08 00 00 00 25 06 26
21 08 01 00 00 25 08 26
21 09 00 00 00 29 09 22
21 09 01 00 00 29 0b 22
21 0a 00 00 00 2d 19 05
21 0a 01 00 00 2d 1b 05
21 0b 00 00 00 32 32 1a
21 0b 01 00 00 32 34 1a
21 0c 00 00 00 37 20 06
21 0c 01 00 00 37 22 06
21 0d 00 00 00 3c 27 14
21 0d 01 00 00 3c 29 14
01 aa 01 01 00 43 22 00
9:56:19 PM #29 SCSI -1024 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02260000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0xFF 0xFF 0xDF 0xE0 0x00 0x02 0xAA 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x08 0x03
9:56:19 PM #30 MMC -1024 File Writer.cpp, Line 335
Communication failure
9:56:19 PM #31 Text 0 File ThreadedTransfer.cpp, Line 222
9:56:19 PM #32 Text 0 File ThreadedTransfer.cpp, Line 216
9:59:57 PM #33 SCSI -1135 File Cdrdrv.cpp, Line 1211
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
9:59:57 PM #34 MMC -1135 File WriterStatus.cpp, Line 157
Write error
9:59:57 PM #35 TRANSFER -24 File WriterStatus.cpp, Line 157
Could not perform end of Disc-At-Once
9:59:57 PM #36 Phase 39 File dlgbrnst.cpp, Line 1566
Burn process aborted
9:59:57 PM #37 Text 0 File Scsicmd.cpp, Line 395
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 3/11/02 11:55:38 AM
File 'IoSubsys\CDR4VSD.VXD': Ver=5.3.2.31, size=101616 bytes, created 4/8/03 9:13:14 AM
File 'IoSubsys\CDRALVSD.VXD': Ver=5.3.2.31, size=20043 bytes, created 4/8/03 9:13:14 AM
File 'IoSubsys\ACBHLPR.VXD': Ver=1.01, size=40508 bytes, created 3/2/01 4:55:54 PM
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 4/23/99 10:22:00 PM
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69570 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 4/23/99 10:22:00 PM
Registry Keys:
RMGreen
Postby DrizztXII on Sat Jun 28, 2003 1:00 am
I had the same prob and fixed it by disabling DMA for the drive in the BIOS.
Keep DMA enabled in Windows, it still works in DMA but only 'Multi-word DMA mode 2' Not 'Ultra DMA..'
Disabling it in the BIOS for my board via kt133 effectively just disables the ULTRA and that error went away.
g'luck
DrizztXII
