LG GCE-8520B 1.04 Flashing problem
Postby studiovpc on Wed Mar 19, 2003 3:48 pm
I've had a problem while flashing with new f/w. Suddenly all of my cd drives were disabled and they won't enable now, anyone know what's wrong? Only GCE-8520B is enabled all other cd drives won't enable?
studiovpc
Postby cfitz on Wed Mar 19, 2003 3:55 pm
What do you mean by "won't enable?"
Try deleteing the drives from device manager and allowing Windwos to reinstall them. You might want to follow the steps in the DMA problems FAQ, even though this isn't necessarily a DMA problem:
Also, you might want to try physically disconnecting the LG and seeing if that changes the status of the other drives.
What's your OS, waht's your motherboard/IDE controller chipset, what are all your drives, and how are they configured on the IDE controller?
Postby studiovpc on Wed Mar 19, 2003 4:12 pm
cfitz wrote:What do you mean by "won't enable?"
Deleting helped and it works now, thnx. Reading speed is 52.11x in Nero CDSpeed!
studiovpc
Postby cfitz on Wed Mar 19, 2003 4:40 pm
You're welcome. Glad to hear it's working well for you now.
