Help pls DVD+R/DL Burn trouble with Nero/Memorex/NEC 2510A
Postby Rudy on Sun Oct 16, 2005 10:12 am
Need help please.
I am getting the following error when trying to burn (dvd copy on the fly) my non-copy protectted DVD onto a Memorex DVD+R DL disc. I am using Nero 6.6.0.16 and a Maddog 8X DVD+R DL Drive (NEC 2510A) with the latest firmware found in the Maddog site for this drive. NEC firmware does not recognize the drive.
Here is part of the Nero log. The errors displayed in the Nero Window are the lines # 16, 17, and 18:
8:26:13 AM #12 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 2.4x (3,324 KB/s)
8:26:13 AM #13 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
8:26:15 AM #14 SCSI -1093 File Cdrdrv.cpp, Line 1180
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x04AB0800
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0xBF 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x0C 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x02 0x00
8:26:15 AM #15 Text 0 File DVDPlusDualLayer.cpp, Line 625
L0 Data Zone Capacity not set.
Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
8:26:15 AM #16 CDR -1093 File ThreadedTransferInterface.cpp, Line 1771
No seek complete
8:26:15 AM #17 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1771
Could not perform start of Disc-at-once
8:26:15 AM #18 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 2.4x (3,324 KB/s)
Have you seen this error before? How to solve it?
. This is the first time I attempt to burn DL on this setup. Otherwise it did not give any problems for more than 1 year already.
Rudy
Postby dodecahedron on Sun Oct 16, 2005 11:09 am
i would guess it's bad media.
can you provide more info on it? specifically MID code.
Postby Rudy on Sun Oct 16, 2005 11:21 am
dodecahedron wrote:i would guess it's bad media.
Thank you for your prompt response. Here is the MID info:
Nero CD-DVD Speed: Disc Info
Basic Information
Disc Type: : DVD+R DL
Book Type : DVD+R DL
Manufacturer: : Ritek
MID : RITEK D01 (001)
Write speeds:
Blank Capacity : 7.96 GB
: 8152 MB
: 8547993600 bytes
Extended Information
Layers : 2
Layer break : 3.98 GB
Write strategies : n/a
Disc Status : Empty
Raw Data
ADIP Information (11h)
0000 - 01 01 01 20 00 00 00 00 00 00 00 00 00 00 00 00 - ................
0010 - 00 3F B0 00 00 00 00 00 00 00 00 00 58 00 00 00 - .?..........X...
0020 - 2C DD 05 00 A8 FB 17 00 98 DD 05 00 18 EE 90 7C - ,..............|
0030 - 78 FB 90 7C FF FF FF FF 71 FB 90 7C 18 6A DD 77 - x..|....q..|.j.w
Please also notice that when I click on START on the Benchmark tab of Nero CD-DVD Speed, I get the error: "ILLEGAL MODE FOR THIS TRACK (056400)".
Rudy
Postby dodecahedron on Sun Oct 16, 2005 11:28 am
this is where my knowledge (and help) ends.
but i think others more knowledgeable than me will tell you that that media is not very good (mildly put).
look here: http://www.cdrlabs.com/phpBB/viewtopic.php?t=20457
Postby Dartman on Sun Oct 16, 2005 12:35 pm
That media is horrible, my 1640 wont write it very well, my 1620 barely makes a working copy, and my 3500 did OK and it worked but the error rates were higher then I'd like. If you have high compatibility mode turned on, turn it off and try again. My first try died at the layer change becuase of that.
Verbatim DL media works well in almost any drive so you might want to try that when you get some more.
Postby CowboySlim on Sun Oct 16, 2005 12:54 pm
FWIW:
I never "copy on the fly."
I always copy to image and then back to media.
I've tried the Memorex DVD+R DL now on sale at Best Buy with good results.
YMMV. Other Terms and Conditions Apply.
Slim
Postby Rudy on Sun Oct 16, 2005 11:15 pm
Thank you for your answers.
Yes, I suspect a problem between the Magdog version of the 2510A and the Memorex media. I guess this is why Memorex DL is on sale at Best Buy, and it was on sale last week at Compusa.
Note: I get the same error if I copy to hard drive first and then I try to burn, so it is not the copy on the fly the cause of this problem.
Rudy
Postby CowboySlim on Sun Oct 16, 2005 11:54 pm
Actually, I had good luck with that media.
NECs are good drives.
My guess is the MadDog firmware.
Get some Verbatim media at buy.com. Get the three pack.
If that doesn't work, it is the firmware.
Postby Rudy on Tue Oct 18, 2005 10:34 pm
CowboySlim wrote:Actually, I had good luck with that media.
You are right.
I actually did not have the latest maddog firmware. They had 2 posted.
Loaded new firmware and solved the problem with Memorex DL media. Thank you.
Rudy
Postby CowboySlim on Tue Oct 18, 2005 11:44 pm
Well, with that bit of good (luck) advice on my part,
time to put on my winter hat. :lol:
Slim
