7.0.1.4b Issue
7.0.1.4b Issue
Postby tazdevl on Fri Dec 23, 2005 6:29 pm
Installed 7.0.1.4b over 7.0.1.4, rebooted and got an error that there was another touch pad driver identified so the synaptics driver disabled itself.
Only thing that's changed on my system is Nero 7.0.1.4b.
Craig, gotta be honest... WTH are your engineers doing?
RIG:
tazdevl
Postby bigblu91 on Sat Dec 24, 2005 3:59 am
I installed right over the top of 7.0.1.4 also. I didn't get an error but I can't find the reference to it being 7.0.1.4b. Where are you seeing it changed to the "b" release? I'm just curious to know for sure if the update made any changes. Maybe I need to uninstall altogether and reinstall the "b" release.
Maybe we should all ask for a refund and try Roxio out to see if they got their stuff together. So much for the Premier burning solution.
bigblu91
Postby dodecahedron on Sat Dec 24, 2005 4:01 am
bigblu91 wrote:Where are you seeing it changed to the "b" release?
in "Help ->About" it should say the version number. it sould say the 'b'.
Postby bigblu91 on Sat Dec 24, 2005 12:22 pm
Ya, I looked at the about screens in Nero Express and Nero Burning Rom before and they both showed 7.0.1.4. That's why I was asking. Of course if I look at the other apps they have a totally different number anyway. So I guess the version I downloaded wasn't the "b" release or the update didn't take. I'll have to try it again. Maybe that's why I got such a good d/l speed because I didn't d/l the newest version.
bigblu91
Postby dodecahedron on Sat Dec 24, 2005 12:41 pm
bigblu91 wrote:So I guess the version I downloaded wasn't the "b" release or the update didn't take. I'll have to try it again. Maybe that's why I got such a good d/l speed because I didn't d/l the newest version.
you can check if you downloaded the 'b' version by looking at the MD5 hash, it's written on the download page, and you can compare it with the MD5 of the file you have already downloaded to your computer.
http://www.nero.com/nero6/en/Nero_MD5_Verifier.html
i highly doubt that if you mistakenly downloaded the not-newest version it was faster, i'm sure the difference in size is insignificant.
most likely you have downloaded the newest 'b' version, but the spalsh screen doesn't show the difference.
i would try the demo out just to check this, but i don't have a Nero 7 serial and don't want to mess up my Nero 6 :x
Postby bigblu91 on Sat Dec 24, 2005 1:00 pm
Well, I uninstalled the Nero 7 version I believed was the latest. I redownloaded the installer that stated it was the "b" version and then installed it. I got a statement that the version I had was newer even though I had uninstalled Nero 7 from add/remove AND rebooted. Nero 7 SUCKS! I then clicked through several screens telling me to uninstall the version I had already removed, even to the point of just trying to click close. Finally it just rebooted and continued with the installer. ?????
It's now installed I guess but the version in the "about " window still doesn't show "b".
Does anyone that installed the "b" version show the "b" after the 7.0.1.4? I guess it doesn't really matter because it still is crap!!!! I want my money including tax back!! :evil:
bigblu91
Postby tazdevl on Sat Dec 24, 2005 5:48 pm
Another issue that I previously reported. At the end of the install routine, where the file associations, install options, autorun etc... are set. Uncheck the box for Nero Scout and it still gets installed.
Have to edit the registry to get it to go away.
FYI mine doesn't say b either.
RIG:
tazdevl
Postby eric93se on Sat Dec 24, 2005 10:32 pm
I dl'd the latest version and its not showing up as 'b' !!
I bet 'b' already has problems :lol: so they're re-issuing the version with the least amount of trouble. :x
Benq DW-1640
eric93se
Postby eric93se on Sun Dec 25, 2005 10:44 pm
After installing nero 7 and comparing results to nero 6, I've found that my PIF's have decreased, hower PIE's and jitter have increased to unaccepatble levels. This is burning with all the same setting and temporary folder/drive settings. So it seems that neros burning engine is different in version 7 but not necessarily better.
Benq DW-1640
eric93se
Postby CCampbell on Thu Jan 19, 2006 1:54 pm
We have never showed the B, C, D, etc in any Nero 5, Nero 6, or Nero 7 release versions.
We've done this as in 90% of the cases, when there is just a minor bug fix or if it only affects a specific drive, we'll come out with a 'B' or 'D' release so that we do not have a complete new version.
For Example: Let's say we just released Nero 7.0.1.4, and then the very next day we find there is a problem with say a Specific model Memorex drive. We need to post a fix for this ASAP, but we do not want to come out with a complete new version of say Nero 7.0.1.5 that has only one fix and nothing else associated with it. So we come out with Nero 7.0.1.4b
But we have never displayed the 'B' in the 'About Nero' box. We did this for all previous versions of Nero as well.
Hi Tazdevl,
Can you give me more specifics about your issue with the Touch Pad? I have the Logitech diNovo Meida Desktop set that comes with a BlueTooth MediaPad but I am not able to duplicate this issue on that system.
Postby tazdevl on Thu Jan 26, 2006 3:49 am
CCampbell wrote:Hi Tazdevl,
Craig, HPDV1000 laptop. XP Pro SP2, 2GHZ Pentium M, 1GB RAM, 5400 RPM 80GB HD... standard Synaptics Touchpad Drivers from Synaptics site.
1) Installed 7.0.1.4b
2) Rebooted
3) At windows desktop popup was displayed that indicated that due to a change in the registry windows was using default MS drivers instead of Synaptics drivers.
4) Only thing that changed in my system the last 2 months was installing Nero 7.
Also have another issue to report with 7.0.1.4b. Desktop, 3.6GHZ P4 w/HT, 1GB RAM, XP Pro SP2, Plextor rev 1 708A FW 1.11.... burning audio discs, haven't tried others
1) First audio disc burns fine
2) Try to burn second audio disc via normal process i.e. new disc dialog
3) Write process starts... then get a failure message due to invalid drive state
4) Can't eject disc but can close app
5) Have to reboot to get disc out of drive
6) Have to reboot another time to be able to burn another disc
I should mention that I burned 8 data discs and backed up 2 movies with Recode, no issues.
Log from error
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 12:54:32 PM
NT-SPTI used
Nero Version: 7.0.1.4
Internal Version: 7, 0, 1, 4
Recorder: <PLEXTOR DVDR PX-708A> Version: 1.11 - HA 1 TA 0 - 7.0.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
CD-ROM: <PLEXTOR DVDR PX-708A >Version: 1.11 - HA 1 TA 0 - 7.0.1.4
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD2500JB-00FUA0 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : PLEXTOR DVDR PX-708A atapi Port 1 ID 1 DMA: On
DiskPeripheral : Raid 0 Volume iaStor Port 2 ID 0 DMA: On
=== CDRom-Device-Map ===
PLEXTOR DVDR PX-708A D: CDRom0
AutoRun : 0
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048036kB)
Free physical memory: 495MB (507320kB)
Memory in use : 51 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
26.1.2006
Audio CD
12:38:54 AM #1 CDADOC -1 File Cdadoc.cpp, Line 1507
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 07:02.31, Pause frames: 150, Filters: 0, Name: 'Dave Matthews Band - Live At Luther College (Disc 2) - 01 - Typical Situation.mp3'.
Track 02: Length: 05:49.50, Pause frames: 150, Filters: 0, Name: 'Dave Matthews Band - Live At Luther College (Disc 2) - 02 - Stream.mp3'.
Track 03: Length: 09:17.08, Pause frames: 150, Filters: 0, Name: 'Dave Matthews Band - Live At Luther College (Disc 2) - 03 - Warehouse.mp3'.
Track 04: Length: 05:24.50, Pause frames: 150, Filters: 0, Name: 'Dave Matthews Band - Live At Luther College (Disc 2) - 04 - Christmas Song.mp3'.
Track 05: Length: 07:43.27, Pause frames: 150, Filters: 0, Name: 'Dave Matthews Band - Live At Luther College (Disc 2) - 05 - Seek Up.mp3'.
Track 06: Length: 05:19.71, Pause frames: 150, Filters: 0, Name: 'Dave Matthews Band - Live At Luther College (Disc 2) - 06 - Say Goodbye.mp3'.
Track 07: Length: 05:26.45, Pause frames: 150, Filters: 0, Name: 'Dave Matthews Band - Live At Luther College (Disc 2) - 07 - Ants Marching.mp3'.
Track 08: Length: 06:18.44, Pause frames: 150, Filters: 0, Name: 'Dave Matthews Band - Live At Luther College (Disc 2) - 08 - Little Thing.mp3'.
Track 09: Length: 03:00.30, Pause frames: 150, Filters: 0, Name: 'Dave Matthews Band - Live At Luther College (Disc 2) - 09 - Halloween.mp3'.
Track 10: Length: 03:22.25, Pause frames: 150, Filters: 0, Name: 'Dave Matthews Band - Live At Luther College (Disc 2) - 10 - Granny.mp3'.
Track 11: Length: 06:34.66, Pause frames: 150, Filters: 0, Name: 'Dave Matthews Band - Live At Luther College (Disc 2) - 11 - Two Step.mp3'.
Total size: 65:41.72
12:38:54 AM #2 Text 0 File Burncd.cpp, Line 3048
BURN-Proof activated
12:38:54 AM #3 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 81920KB of Memory
12:38:54 AM #4 Text 0 File Reader.cpp, Line 124
Reader running
12:38:54 AM #5 Text 0 File Writer.cpp, Line 113
Writer D: PLEXTOR DVDR PX-708A running
12:38:54 AM #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
12:38:54 AM #7 Text 0 File Burncd.cpp, Line 3342
Turn on Disc-At-Once, using CD-R/RW media
12:38:54 AM #8 Text 0 File DlgWaitCD.cpp, Line 279
Last possible write address on media: 359846 ( 79:59.71)
Last address to be written: 295496 ( 65:41.71)
12:38:54 AM #9 Text 0 File DlgWaitCD.cpp, Line 291
12:38:54 AM #10 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: PLEXTOR DVDR PX-708A
12:38:54 AM #11 Text 0 File DlgWaitCD.cpp, Line 458
12:38:54 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
0: TRM_AUDIO_NOPRE (Dave Matthews Band - Live At Luther College (Disc 2) - 01 - Typical Situation.mp3)
original disc pos #0 + 31681 (31681) = #31681/7:2.31
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 31681 blocks [D: PLEXTOR DVDR PX-708A]
1: TRM_AUDIO_NOPRE (Dave Matthews Band - Live At Luther College (Disc 2) - 02 - Stream.mp3)
original disc pos #0 + 26225 (26225) = #26225/5:49.50
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26225 blocks [D: PLEXTOR DVDR PX-708A]
2: TRM_AUDIO_NOPRE (Dave Matthews Band - Live At Luther College (Disc 2) - 03 - Warehouse.mp3)
original disc pos #0 + 41783 (41783) = #41783/9:17.8
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 41783 blocks [D: PLEXTOR DVDR PX-708A]
3: TRM_AUDIO_NOPRE (Dave Matthews Band - Live At Luther College (Disc 2) - 04 - Christmas Song.mp3)
original disc pos #0 + 24350 (24350) = #24350/5:24.50
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24350 blocks [D: PLEXTOR DVDR PX-708A]
4: TRM_AUDIO_NOPRE (Dave Matthews Band - Live At Luther College (Disc 2) - 05 - Seek Up.mp3)
original disc pos #0 + 34752 (34752) = #34752/7:43.27
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 34752 blocks [D: PLEXTOR DVDR PX-708A]
5: TRM_AUDIO_NOPRE (Dave Matthews Band - Live At Luther College (Disc 2) - 06 - Say Goodbye.mp3)
original disc pos #0 + 23996 (23996) = #23996/5:19.71
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23996 blocks [D: PLEXTOR DVDR PX-708A]
6: TRM_AUDIO_NOPRE (Dave Matthews Band - Live At Luther College (Disc 2) - 07 - Ants Marching.mp3)
original disc pos #0 + 24495 (24495) = #24495/5:26.45
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24495 blocks [D: PLEXTOR DVDR PX-708A]
7: TRM_AUDIO_NOPRE (Dave Matthews Band - Live At Luther College (Disc 2) - 08 - Little Thing.mp3)
original disc pos #0 + 28394 (28394) = #28394/6:18.44
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 28394 blocks [D: PLEXTOR DVDR PX-708A]
8: TRM_AUDIO_NOPRE (Dave Matthews Band - Live At Luther College (Disc 2) - 09 - Halloween.mp3)
original disc pos #0 + 13530 (13530) = #13530/3:0.30
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13530 blocks [D: PLEXTOR DVDR PX-708A]
9: TRM_AUDIO_NOPRE (Dave Matthews Band - Live At Luther College (Disc 2) - 10 - Granny.mp3)
original disc pos #0 + 15175 (15175) = #15175/3:22.25
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15175 blocks [D: PLEXTOR DVDR PX-708A]
10: TRM_AUDIO_NOPRE (Dave Matthews Band - Live At Luther College (Disc 2) - 11 - Two Step.mp3)
original disc pos #0 + 29616 (29616) = #29616/6:34.66
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 29616 blocks [D: PLEXTOR DVDR PX-708A]
12:38:54 AM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [D: PLEXTOR DVDR PX-708A] for write in CUE-sheet-DAO
DAO infos:
MCN: " "
Tracks 1 to 11:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 74866512, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 74866512 75219312 136900512, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 136900512 137253312 235526928, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 235526928 235879728 293150928, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 293150928 293503728 375240432, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 375240432 375593232 432031824, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 432031824 432384624 489996864, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 489996864 490349664 557132352, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 557132352 557485152 589307712, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 589307712 589660512 625352112, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 625352112 625704912 695361744, ISRC ""
DAO layout:
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
31681 | 2 | 0 | 0x21 | 0x00
31831 | 2 | 1 | 0x21 | 0x00
58056 | 3 | 0 | 0x21 | 0x00
58206 | 3 | 1 | 0x21 | 0x00
99989 | 4 | 0 | 0x21 | 0x00
100139 | 4 | 1 | 0x21 | 0x00
124489 | 5 | 0 | 0x21 | 0x00
124639 | 5 | 1 | 0x21 | 0x00
159391 | 6 | 0 | 0x21 | 0x00
159541 | 6 | 1 | 0x21 | 0x00
183537 | 7 | 0 | 0x21 | 0x00
183687 | 7 | 1 | 0x21 | 0x00
208182 | 8 | 0 | 0x21 | 0x00
208332 | 8 | 1 | 0x21 | 0x00
236726 | 9 | 0 | 0x21 | 0x00
236876 | 9 | 1 | 0x21 | 0x00
250406 | 10 | 0 | 0x21 | 0x00
250556 | 10 | 1 | 0x21 | 0x00
265731 | 11 | 0 | 0x21 | 0x00
265881 | 11 | 1 | 0x21 | 0x00
295497 | lead-out | 1 | 0x01 | 0x00
12:38:54 AM #14 Text 0 File SCSIPassThrough.cpp, Line 36
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
12:38:54 AM #15 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 40x (6,000 KB/s)
12:38:54 AM #16 SPTI -1189 File SCSIPassThrough.cpp, Line 323
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1189)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 02
Buffer x05ab7a00: Len x4000
12:38:54 AM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
12:38:54 AM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #31831
12:38:54 AM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #58206
12:38:54 AM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #100139
12:38:54 AM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #124639
12:38:54 AM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #159541
12:38:54 AM #23 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #183687
12:38:54 AM #24 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #208332
12:38:54 AM #25 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #236876
12:38:54 AM #26 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #250556
12:38:54 AM #27 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #265881
12:38:54 AM #28 Text 0 File MMC.cpp, Line 16932
StartDAO : CD-Text - On
12:38:55 AM #29 Text 0 File MMC.cpp, Line 17165
CueData, Len=192
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 07 04 1f
21 02 01 00 00 07 06 1f
21 03 00 00 00 0c 38 06
21 03 01 00 00 0c 3a 06
21 04 00 00 00 16 0f 0e
21 04 01 00 00 16 11 0e
21 05 00 00 00 1b 29 40
21 05 01 00 00 1b 2b 40
21 06 00 00 00 23 1b 10
21 06 01 00 00 23 1d 10
21 07 00 00 00 28 31 0c
21 07 01 00 00 28 33 0c
21 08 00 00 00 2e 11 39
21 08 01 00 00 2e 13 39
21 09 00 00 00 34 26 1a
21 09 01 00 00 34 28 1a
21 0a 00 00 00 37 28 38
21 0a 01 00 00 37 2a 38
21 0b 00 00 00 3b 05 06
21 0b 01 00 00 3b 07 06
01 aa 01 01 00 41 29 48
12:41:38 AM #30 Text 0 File WriterStatus.cpp, Line 116
<D: PLEXTOR DVDR PX-708A> start writing Lead-Out at LBA 295497 (48249h), length 0 blocks
12:41:39 AM #31 Text 0 File ThreadedTransfer.cpp, Line 228
12:47:39 AM #32 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1937
Could not perform end of Disc-at-once
12:47:39 AM #33 SPTI -1169 File SCSIPassThrough.cpp, Line 323
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1169)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x08
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 08
12:47:39 AM #34 SPTI -1169 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x04
Sense Qual: 0x08
CDB Data: 0x5A 00 05 00 00 00 00 00 48 00 00 00
Buffer x0337e600: Len x48
12:47:39 AM #35 CDR -201 File WriterStatus.cpp, Line 167
Invalid write state
12:47:39 AM #36 TRANSFER -24 File WriterStatus.cpp, Line 167
12:47:39 AM #37 SPTI -1169 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x04
Sense Qual: 0x08
CDB Data: 0xE9 10 02 00 00 00 00 00 00 00 00 00
12:47:39 AM #38 SPTI -1169 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x04
Sense Qual: 0x08
12:47:39 AM #39 SPTI -1169 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x04
Sense Qual: 0x08
12:47:40 AM #40 CDR -1169 File WriterStatus.cpp, Line 172
Logical unit not ready, operation in progress
12:47:40 AM #41 TRANSFER -39 File WriterStatus.cpp, Line 172
Could not perform EndSession
12:47:40 AM #42 Phase 38 File dlgbrnst.cpp, Line 1725
Burn process failed at 40x (6,000 KB/s)
12:47:40 AM #43 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
12:47:40 AM #44 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
12:47:40 AM #45 SPTI -1169 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x04
Sense Qual: 0x08
CDB Data: 0x1E 00 00 00 00 00 00 00 00 00 00 00
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows
NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
AND... finally when you close a compilation after burning an audio CD, Nero hangs and doesn't close. Have to use the task manager to close it out.
RIG:
tazdevl
Postby CCampbell on Mon Jan 30, 2006 1:33 pm
Did you try and reinstall the drivers for the Touchpad and Keyboard?
If that failed, if you uninstall Nero 7, does it then work again?
As for your second issue, it will have to wait till I can return to the office and test with the Plextor 708 recorder.
