LiteOn can read but not copy DVDs
How fast is too fast?
Postby kotrtim on Wed Feb 01, 2006 10:59 am
http://www.cdrlabs.com/phpBB/viewtopic.php?t=18800
Things became worst now, I don't know what's wrong...
My LiteOn can play DVD without a problem, smooth, but when I try to copy the vob files, it hangs... scan with CDSpeed, many damaged and bad sectors..
Can play but cannot copy????
Tried a scratched DVD data disc no problem, I can copy the files
Tried data CDs, no problem too
WHat's the difference between DVD-video disc and data disc, are data discs more resilient to errors?
I can't figure out what's wrong, is the drive dying?
kotrtim
Postby redk9258 on Thu Feb 02, 2006 7:43 am
Are you using somthing to decrypt the video files? Are these recorded or store bought DVDs you are having trouble with? If they are recorded, what recorder / disc is it?
redk9258
Postby kotrtim on Thu Feb 02, 2006 8:42 am
All pressed DVDs.. It can play smoothly, it just never want to copy the files
Besides, the DVD that can be copied previously can't be copied now
kotrtim
Postby redk9258 on Fri Feb 03, 2006 8:08 am
kotrtim wrote:All pressed DVDs.. It can play smoothly, it just never want to copy the files
What software are you trying to copy with?
redk9258
Postby kotrtim on Fri Feb 03, 2006 11:41 am
1. drag n drop, windows explorer
if fail, isobuster,.....still fail
kotrtim
Postby redk9258 on Sat Feb 04, 2006 10:09 am
kotrtim wrote:1. drag n drop, windows explorer
Commercial DVDs are copy protected. You need to extract the files with something like DVD Decryptor or DVD Shrink. Then if necessary, you use a recompression program to fit the movie on the blank DVD you are going to use. Then Finally burn it. Take a look at http://www.doom9.org/.
redk9258
Postby kotrtim on Wed Feb 08, 2006 6:31 am
dvd decrypter = fail
isobuster = fail
the problem when the copy halt, it halts forever
Well I found a solution, it sounds stupid, Linux KDE explorer drag n drop worked, there are pause here and there but it can struggle through it....
This is a LiteOn windows curse???
kotrtim
