LTC-48161H problem. Major problem, actually.
Postby StarKnightGoku on Sun Nov 09, 2003 1:01 am
Well, I just got the LiteON LTC-48161H from NewEgg, and I have a rather interesting problem.
Whenever it's connected to the computer, and I attempt to boot, it starts loading Windows, and then I get one of two blue screens of death.
The first one is "An exception 0E has occured at 0028:00000004 in VxD ---. THis was called from 0028:C187F5D7 in VxD ---."
And the second is "A fatal exception 0E has occured in 0147:00006637"
The first doesn't always occur, but the second does.
At the moment, I have my four year old generic drives from Compaq connected, and other than the CD-RW not working well anymore, both are functional. Actually, I just got the CD-ROM working again after a year of not working, but that's another story.
Any advice on what I should do? Money's rather tight at the moment, and my warranty expired awhile ago, so I can't take it in to be looked at.
Thanks in advance.
StarKnightGoku
Postby StarKnightGoku on Mon Nov 10, 2003 8:47 am
...Anyone?
StarKnightGoku
Postby sgegreen on Mon Nov 10, 2003 11:10 am
You appear to be running Windows 98, 98SE or ME.
First check that the LTC-48161H is set to master and the CD-Rom drive is set to slave on the secondary IDE cable. Try not to connect the CD-RW on the same cable as the hard disk.
If this still doesn't help, apply the updates from http://members.tripod.com/erpman1/w98meupd.html, in particular the 274370 cdvsd.vxd update about half way down the page in the Other Updates section. Note that there are different versions of the update for W98/SE and WME.
sgegreen
Postby StarKnightGoku on Mon Nov 10, 2003 1:15 pm
Well, I'm at school right now, but if that works, you become my new hero.
StarKnightGoku
Postby StarKnightGoku on Tue Nov 11, 2003 9:21 am
The 274370 link doesn't work on that site, at least not for me.
StarKnightGoku
Postby StarKnightGoku on Tue Nov 11, 2003 5:55 pm
Problem resolved. Beautifully. I hadn't thought to delete everything in the Device Manager before plugging it in, then rebooting.
StarKnightGoku
