Nero Burning Problem - Erorr log posted
Postby timeslip on Tue Oct 12, 2004 12:33 pm
All of a sudden, Nero stopped working. I tried to upgrade to the latest version, uninstall/reinstall. It acts as if it burns correctly, but the cd is corrupt and inaccessible.
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 10:03:20 AM
ahead WinASPI: File 'D:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/22/2004 5:33:44 PM
Nero version: 6.3.1.25
Recorder: <PIONEER DVD-RW DVR-105> Version: 1.33 - HA 3 TA 0 - 6.3.1.25
Adapter driver: <atapi> HA 3
Drive buffer : 2000kB
CD-ROM: <PIONEER DVD-RW DVR-105 >Version: 1.33 - HA 3 TA 0 - 6.3.1.25
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD360GD-00FNA0 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-105 atapi Port 3 ID 0 DMA: On
DiskPeripheral : Promise 1X2 Mirror/RAID11.10 fasttx2k Port 4 ID 0 DMA: Off
OtherPeripheral : Promise RAID Console 1.00 fasttx2k Port 4 ID 4 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-105 F: CDRom0
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1022MB (1047264kB)
Free physical memory: 646MB (662464kB)
Memory in use : 36 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
11.10.2004
CD-ROM (UDF)
5:11:16 PM #1 Text 0 File Isodoc.cpp, Line 6083
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
5:11:16 PM #2 Phase 90 File dlgbrnst.cpp, Line 1855
5:11:17 PM #3 Text 0 File Reader.cpp, Line 126
Reader running
5:11:17 PM #4 Text 0 File Writer.cpp, Line 124
Writer PIONEER DVD-RW DVR-105 running
5:11:17 PM #5 Text 0 File Burncd.cpp, Line 3152
Turn on Track-at-once, using CD-R/RW media
5:11:18 PM #6 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 4623 ( 1:03.48)
5:11:18 PM #7 Text 0 File DlgWaitCD.cpp, Line 259
5:11:18 PM #8 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: PIONEER DVD-RW DVR-105;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
5:11:18 PM #9 Text 0 File DlgWaitCD.cpp, Line 420
5:11:18 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 813
original disc pos #0 + 4624 (4624) = #4624/1:1.49
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 4622 blocks [PIONEER DVD-RW DVR-105 ]
5:11:18 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [PIONEER DVD-RW DVR-105 ] for write in TAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 9777152, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
4624 | lead-out | 1 | 0x00 | 0x41
5:11:18 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1030
Removed 2 run-out blocks from end of track 1. Length: 4624 -> 4622.
5:11:19 PM #13 Phase 24 File dlgbrnst.cpp, Line 1855
Caching of files started
5:11:19 PM #14 Text 0 File Burncd.cpp, Line 4163
Cache writing successful.
5:11:19 PM #15 Phase 25 File dlgbrnst.cpp, Line 1855
Caching of files completed
5:11:19 PM #16 Phase 36 File dlgbrnst.cpp, Line 1855
Burn process started at 16x (2,400 KB/s)
5:11:21 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2344
5:11:22 PM #18 Text 0 File Mmc.cpp, Line 20660
Set BUFE: supported -> ON
5:11:22 PM #19 Text 0 File Cdrdrv.cpp, Line 1297
17:11:22.578 - PIONEER DVD-RW DVR-105\H3 T0 : Queue again later
5:11:25 PM #20 Text 0 File Cdrdrv.cpp, Line 1297
17:11:25.312 - PIONEER DVD-RW DVR-105\H3 T0 : Queue again later
5:11:25 PM #21 Text 0 File Cdrdrv.cpp, Line 1297
17:11:25.562 - PIONEER DVD-RW DVR-105\H3 T0 : Queue again later
5:11:28 PM #22 Text 0 File ThreadedTransfer.cpp, Line 229
5:11:30 PM #23 Text 0 File Mmc.cpp, Line 15480
<PIONEER DVD-RW DVR-105 > start Close Session
5:11:36 PM #24 Text 0 File Mmc.cpp, Line 15508
Fixation : Second step for unclosed Sessions
5:11:36 PM #25 Phase 37 File dlgbrnst.cpp, Line 1855
Burn process completed successfully at 16x (2,400 KB/s)
5:11:36 PM #26 Phase 78 File dlgbrnst.cpp, Line 1855
Data verification started
5:11:46 PM #27 SCSI -1183 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x039F6000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Key: 0x08 (KEY_BLANK_CHECK)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x00 0x11 0xEE 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x08 0x00 0x00 0x11 0xEE 0x0E
0x00 0x00 0x00 0x00 0x00 0x00
5:11:46 PM #28 Text 0 File DriveFileSystemBlockReader.cpp, Line 231
Error during reading the sector: 4590
5:11:47 PM #29 SCSI -1183 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x03A06000
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x08 0x00 0x00 0x00 0x00 0x0E
5:11:47 PM #30 Text 0 File DriveFileSystemBlockReader.cpp, Line 231
Error during reading the sector: 0
5:11:47 PM #31 SCSI -1183 File Cdrdrv.cpp, Line 1445
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x00 0x01 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x08 0x00 0x00 0x01 0x00 0x0E
5:11:47 PM #32 Text 0 File DriveFileSystemBlockReader.cpp, Line 231
Error during reading the sector: 256
5:11:48 PM #33 SCSI -1183 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x03A16000
Sense Code: 0x00
Sense Qual: 0x00
5:11:48 PM #34 Text 0 File DriveFileSystemBlockReader.cpp, Line 231
5:11:48 PM #35 SCSI -1183 File Cdrdrv.cpp, Line 1445
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x08 0x00 0x00 0x00 0x20 0x0E
5:11:48 PM #36 Text 0 File DriveFileSystemBlockReader.cpp, Line 231
Error during reading the sector: 32
5:11:48 PM #37 SCSI -1047 File Cdrdrv.cpp, Line 1445
Sense Code: 0x64
Sense Qual: 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x20 0x0E
0x00 0x00 0x00 0x00 0x64 0x00
5:11:48 PM #38 Text 0 File DriveFileSystemBlockReader.cpp, Line 231
5:11:48 PM #39 SCSI -1047 File Cdrdrv.cpp, Line 1445
Sense Code: 0x64
Sense Qual: 0x00
5:11:48 PM #40 Text 0 File DriveFileSystemBlockReader.cpp, Line 231
5:11:48 PM #41 SCSI -1047 File Cdrdrv.cpp, Line 1445
Sense Code: 0x64
Sense Qual: 0x00
5:11:48 PM #42 Text 0 File DriveFileSystemBlockReader.cpp, Line 231
5:11:48 PM #43 VERIFYERR 10 File UDFCompilationImpl.cpp, Line 1287
Cannot mount the written CD
"PIONEER DVD-RW DVR-105 " (H:3, T:0)
5:11:48 PM #44 VERIFYERR 13 File UDFCompilationImpl.cpp, Line 1385
Status summary
Total files=0, identical=0, different=0, inaccessible=0, skipped=0.
5:11:48 PM #45 Phase 81 File dlgbrnst.cpp, Line 1855
Data verification failed
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 9:05:10 AM
File 'WNASPINT.DLL': Ver=V1.18, size=57344 bytes, created 1/10/2003 1:00:00 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 10/28/2003 3:02:00 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 10:59:42 PM (Adapter driver for rec)
Registry Keys:
--=timeslip=--
timeslip
Postby timeslip on Thu Oct 14, 2004 4:42 pm
Does anyone have any idea what might be wrong? I would like to continue using Nero.
Thanks!
--=timeslip=--
timeslip
Postby dodecahedron on Thu Oct 14, 2004 5:02 pm
some suggestions:
burn in Disc-At-Once mode, not Track-At-Once.
use ISO Level 2 instead of 1.
use different (better) media.
it appears that you're using CMC CDRW. CMC aren't always that good. use different media, good media if you can find it.
try burning with different software.
i'm no expert, but from scanning the log it seems to me as if the drive might be dead.
does it function as a CD-ROM?
does it burn or read DVD discs?
Postby timeslip on Thu Oct 14, 2004 5:50 pm
1) The Disc At Once fixed my problem. Why is that? On my laptop, it was also set to Track At Once, but it works fine.
2) I had already tried a different burning software, and it works fine.
3) Currently using Memorex blank CD's, what do you recommend?
--=timeslip=--
timeslip
Postby dodecahedron on Fri Oct 15, 2004 12:03 am
i don't know why DAO solved the probelm, but what's important is that it's solved, you can burn :)
maybe it has do to with what you were burning...?
maybe your Pioneer 105 doesn't like TAO ?
Memorex don't make the CDs, they buy them from maufacturers and sell them under their own name.
good manufacturers are Taiyo Yuden, Mitsubishi.
for Mitsubishi you can try the brand Verbatim DataLifePlus CDs, usually they're good CDs.
TY are harder to find. you usually have to buy them online in bulk.
