Nero CD-DVD Speed V3.61 released
Postby Joker on Tue Dec 28, 2004 10:21 pm
Last Updated: 28 December 2004
Changes
Create Data Disc: added option to burn Nero image files instead of predefined data
Added color selection/themes
Disc Quality test
added QuickScan function
improved support for Asus DVD burners
improved support for AOpen DUW1608/ARR
improved support for AOpen DVD1648/AAP
added 12x and 16x speed settings for BenQ DW1620
added elapsed time in summary screen
Bitsetting: added DVD+R DL bitsetting for QSI drives
Small improvements and bug fixes
Go to http://www.cdspeed2000.com/
Joker
Joker
Postby hoxlund on Tue Dec 28, 2004 11:47 pm
with 1.18 firmware on the pioneer 108, it doesn't do disc quality check
Thermaltake Core X5 Snow Edition TG Case
Corsair RM1000 Power Supply
MSI X399 Gaming Pro Carbon AC
AMD Threadripper 1950x @ 4.1GHz
Custom Loop w/ EK MSI x399 Monoblock
G.Skill 4x8GB DDR4 3200 RGB Memory
MSI 1080Ti Lightning X Video Card
Postby eric93se on Wed Dec 29, 2004 4:42 pm
version 3.55 and 3.61 don't work in my LG combo drive :( all of the previous versions worked. So I'm stuck with 3.50 for now.
Benq DW-1640
eric93se
Postby Noua on Wed Dec 29, 2004 9:58 pm
hoxlund wrote:with 1.18 firmware on the pioneer 108, it doesn't do disc quality check
The same here on my Pioneer 106.. :cry
"We don't want to to put mankind on the moon but to bring mankind back to earth..."
Noua
Postby hoxlund on Thu Dec 30, 2004 1:30 am
ehhh its no biggy, I just continue to test with dvdinfopro
Postby Noua on Thu Dec 30, 2004 2:57 pm
hoxlund wrote:ehhh its no biggy, I just continue to test with dvdinfopro
i haven't used that one yet. Guess I'll follow the leader...
Noua
Postby carl on Thu Dec 30, 2004 8:42 pm
Works fine with the Piodata 1.18.. :D
carl
Postby hoxlund on Fri Dec 31, 2004 12:56 am
thats great to hear, but i only trust my burns to true pioneer drives
Postby Jim on Fri Dec 31, 2004 1:07 am
hoxlund wrote:thats great to hear, but i only trust my burns to true pioneer drives
My understanding is that the Piodata kernal and firmware is developed in house by Pioneer and released for their Piodata line. The BIOS updates and change logs for the Pioneer and Piodata lines appear to be identical.
Following your posts for awhile it appears you don't use DVD+R so I guess the only benefit to you would be the scanning.
Jim
Postby hoxlund on Fri Dec 31, 2004 11:53 am
your correct
Postby carl on Fri Dec 31, 2004 3:41 pm
Besides the faceplate I see no differences between a Piodata 108DX and Pioneer 108. I have examined the hardware and it's the same. The firmware is all developed by Pioneer so this is all "true" Pioneer. The error reporting is just disabled in CD/DVD Speed for "Pioneer".
carl
Postby hoxlund on Fri Dec 31, 2004 9:47 pm
can you use piodata firmware with pioneer drives?
Postby carl on Sat Jan 01, 2005 1:22 am
hoxlund wrote:can you use piodata firmware with pioneer drives?
Sure can. You just need the Piodata kernel and the Piodata firmware of your choosing. I would suggest the latest Piodata 1.18 or the RPC1/rip-lock removed Piodata 1.18. Really is the best of both worlds. Pioneer quality burns with +R bitsetting. I guess the only downside is the bitsetting for +R is automatic and can't be changed, but for me I never change it anyway. All of my other drives are set for -ROM by default. I don't see a reason to not set a +R to -ROM.
This is only for the 108/A08 drives. Don't try this on a XL. There is not a Piodata XL drive so XL owners are out of luck on this one. It is also reversible. Then using the latest CD/DVD Speed you get quality scans that actually look reasonably accurate on the Pio drive. Give it a try... :D
carl
