Nero having problems burning with CD-RW's
Postby zombiebob on Wed Apr 14, 2004 12:33 am
I'm trying to burn a bin file to a cd-rw. Nero burns the bin file to cd-rw, but when its finshed burning. I check the cd-rw and nothing is written on it. I tryed burning a audio cd and that didn't show anything on the cd-rw too. I started having this problem a week ago.
Any help would be apperchated
zombiebob
Postby dodecahedron on Wed Apr 14, 2004 1:05 am
what media are you using?
try a different brand CD-RW.
can you successfully burn the same .bin to a CD-R disc?
Postby zombiebob on Wed Apr 14, 2004 4:39 pm
I'm using Melody CD-RW's and i've tried Maxwell CD-RW, they didn't work either. I haven't tried burning the .bin on a CD-R.
zombiebob
Postby dodecahedron on Wed Apr 14, 2004 4:42 pm
i can only recommend Verbatim CDRW media. the best CDRW media IMO.
try burning the files to CDR (to make sure the problem isn't with the actual files).
Postby zombiebob on Thu Apr 15, 2004 4:12 pm
When i test one of the Bad CD-RW's in Nero Cd Speed. I got this:
Disc information
Error reading TOC (code 052400)
CD-R(W) information
Manufacturer : CMC Magnetics
Media code : 97m26s65f
Dye type : 5
Disc Type : CD-RW (4 X compatible)
Capacity : 79:59.74
Is Error reading TOC (code 052400) causing the files not to be burned on the CD-RW?
zombiebob
Postby dodecahedron on Fri Apr 16, 2004 5:48 am
could very well be. seems quite a reasonable assumption.
