my new LG GCE-8520B Problems!!! HELP?>!>!?
Postby JustinZ on Fri Feb 28, 2003 10:43 pm
HELP! WHY ISNT IT 52?!?!?
im using nero 5.5.10.15
JustinZ
Postby dhc014 on Fri Feb 28, 2003 10:45 pm
Probably because it doesn't think that the media supports it. Try another kind!
dhc014
Postby JustinZ on Fri Feb 28, 2003 10:45 pm
there isnt any media in it
JustinZ
Postby JustinZ on Fri Feb 28, 2003 10:46 pm
cany i disable that auto spped adjust crap?
JustinZ
Postby Ian on Fri Feb 28, 2003 10:48 pm
JustinZ wrote:cany i disable that auto spped adjust crap?
Nope. Put some media in the drive that you know works at 52x. And no, I can't tell you what kind does.
Postby dhc014 on Fri Feb 28, 2003 10:50 pm
JustinZ wrote:there isnt any media in it
Hehe, put a pressed, non-copy protected disk in there like an AOL Installation CD or something...
dhc014
Postby eliminator on Fri Feb 28, 2003 11:14 pm
I'll install my new LG52x tonite & try some Fuji/TY, bet that 40x/48x media works OK @ 52x
Wake up ATI :-)
eliminator
Postby cfitz on Fri Feb 28, 2003 11:23 pm
You might want to get the latest version of InfoTool as well, so you can see all of the supported reading and writing speeds.
Postby Raz0rX on Fri Feb 28, 2003 11:46 pm
I tried an unbranded disc with new TY DX dye with this burner, still 48x max.
The ATIP is: 97:24:01.
DJ Doboy
There are appoximately 5% male registered nurse in Canada as of 2001!
Raz0rX
Postby eliminator on Sat Mar 01, 2003 3:33 am
Wrong... here's my results for LG52x24x52 ...
All TY Japanese made media ! Avrg/Max. writing :
24xFuji 36.93/48.54x
32xTDK 36.92/48.54x
48xMemorex 36.93/48.54x
48xFuji 36.92/48.53x
Lite-On 52x24x52 burned both 48x media @ 52x but did 32x media only @ 40x & 24 media only @ 16x :roll:
Wake up ATI :-)
eliminator
Postby TheWizard on Sat Mar 01, 2003 4:02 am
I believe RazOrX was referring to the maximum successful burn speed (no errors) with the Fuji/TY media in the LG GCE-8520B. He was not referring to a speed test.
No, I like women.
Postby Raz0rX on Sat Mar 01, 2003 12:21 pm
And yes, I was "referring to the maximum successful burn speed" for the new TY discs.
I saw a Korean review on this drive (same model) but with firmware revision 1.03...
DJ Doboy
Raz0rX
LG 8520b
Postby Advenger on Sat Mar 01, 2003 12:24 pm
I have the same OEM drive and it works great! Reports 52X, Question? What are your system specs? This drive requires a minimum Pentium II 350mhz but 500mhz recommended! 128mb ram but 256mb in Win XP. Many drives will report slower max speeds on underpowered computers.
Advenger
Postby Raz0rX on Sat Mar 01, 2003 1:06 pm
Advenger, are you saying the drive is allowing you to burn @ 52x max with TY discs? What is the firmware of your drive, 1.00 or newer?
I only have success 52x burning with one kind of disc that I have right now, Ritek.
My PC is AMD 1.2 with 768MB RAM, running XP.
DJ Doboy
Raz0rX
Max burning speed
Postby Advenger on Sun Mar 02, 2003 10:27 am
No I have verion 1.0 of the firmware and Imation 48X disk burn at 48X but what I have seen in the past is someone buying a high speed cd burner and putting it in a slow computer, ingnoring the system requirments and then complaining about peformance! This dirve seems to be very picky about media! I would hope a firmware upgrade will help in the near furture.
Advenger
