New problem with Nero 6.0.0.11
Postby msilano on Sun Aug 03, 2003 11:52 am
Hi all. Just got my new copy of Nero 6 and tried to burn a DVD copy of some files on my drive. Nero 6 failed with a "Read Error". I tried it again using the Nero Backup module; same error. I tried a new DVD+R/W disk. Same error.... Drive is a Sony DRU-500UXL.
So, I uninstalled 6.x and reinstalled Nero 5.x. Added the same files to the compilation and used the original DVD+RW disk. Success - the DVD burned successfully.
Any ideas on how I can a) better research this so that b) I may file a better bug report with Ahead so that it may be fixed?
Thanks,
Mike
msilano
Postby msilano on Sun Aug 03, 2003 12:09 pm
Update:
Nero 5 did burn the disk correctly, but was able to identify and skip a bad file on the disk. Apparently, I have a bad block on my disk.
So, to summarize for this issue:
Nero 5 is able to properly identify and skip a bad file.
Nero 6 simply says "Read error" and fails the backup.
Is this expected behavior?
Thanks,
Mike
NERO 5 LOG:
11:58:35 AM #18 WINPFILE 23 File winpfile.cpp, Line 342
Data error (cyclic redundancy check).
C:\Documents and Settings\Mike\My Documents\My Pictures\Honeymoon Photos\9-cassis.jpg
11:58:35 AM #19 TRANSFER 4 File TransferWriteFileItem.h, Line 329
Error reading file
msilano
Postby dodecahedron on Sun Aug 03, 2003 2:58 pm
msilano wrote:C:\Documents and Settings\Mike\My Documents\My Pictures\Honeymoon Photos\9-cassis.jpg
hi msilano.
welcome to CDRLabs, and congratulations on your honeymoon! :D
Postby melsmed on Sun Aug 03, 2003 3:35 pm
I bumped into another weird error, Nero 6 say " Cannot write in DAO mode", when I was trying to make an Audio CD. Then I used Roxio 6 PLT and it did the same CD with no problems. I'm losing faith in Ahead.
melsmed
Postby dimitri on Thu Aug 07, 2003 4:59 pm
I'm glad you guys are brave enough to run this buggy program.
Me? I'll sit and wait a couple of months till ahead irons away most of the bugs you so kindly find. When ver 6.1 or 6.2 are out I might reconsider.
In the meantime I'll stick to something reliable and solid, namely RecordNowMax. 8)
All the best, dimitri (a.k.a digi, mango)
digi.rpc1.org | digidvd.tk
LiteOn/Jlms dvd drives: info, firmware, regional freedom :cool:
dimitri
Postby cfitz on Thu Aug 07, 2003 5:11 pm
What makes you think we are actually running it? I am just testing, and have no intention of actually using Nero 6 to burn real discs until at least a few more releases come out and they get all the bugs under control. Right now, in my opinion, it is too unstable to be trusted.
Postby dodecahedron on Thu Aug 07, 2003 5:12 pm
or Nero 5.5.10.42! :wink:
hi dimitri, long time no see! :D
Postby cfitz on Thu Aug 07, 2003 6:10 pm
dodecahedron wrote:or Nero 5.5.10.42! :wink:
Anyone for 5.5.9.17? :oops:
Postby dodecahedron on Thu Aug 07, 2003 6:13 pm
why?
are you having problems with 5.5.10.42?
Postby cfitz on Thu Aug 07, 2003 6:18 pm
No, I just never bothered to update to 5.5.10.42. :oops: 5.5.9.17 was working fine for what I use it for, later versions didn't fix any bugs or add any features that were relevant to me, and I tend to follow the motto "If it ain't broke, don't fix it."
Postby Bhairav on Fri Aug 08, 2003 12:04 am
cfitz wrote:No, I just never bothered to update to 5.5.10.42. :oops: 5.5.9.17 was working fine for what I use it for, later versions didn't fix any bugs or add any features that were relevant to me, and I tend to follow the motto "If it ain't broke, don't fix it."
And that's a good motto too.. safest option!
Postby sherif_shaaban on Sat Aug 09, 2003 7:02 pm
That's bad news for me, guys. I'm currently downloading nero60011.exe on a dial-up connection, and it would be so bad if it turns out that this huge (20 MB) piece of software was not worth the downloading time :cry: I use version 5.5.10.20 and it runs fine, but I was attracted to ver. 6 by the hype on the Net. Is the available Nero 6 that bad? because it's so depressing for me to lose some blank CDs :roll:
sherif_shaaban
Postby dhc014 on Sat Aug 09, 2003 7:32 pm
Nero 6 isn't that bad... Not currently worth uninstalling a perfectly good 5.5 installation just for a trial of Nero 6 though.
dhc014
Postby kaikow on Sat Aug 09, 2003 7:39 pm
sherif_shaaban wrote:That's bad news for me, guys. I'm currently downloading nero60011.exe on a dial-up connection, and it would be so bad if it turns out that this huge (20 MB) piece of software was not worth the downloading time :cry: I use version 5.5.10.20 and it runs fine, but I was attracted to ver. 6 by the hype on the Net. Is the available Nero 6 that bad? because it's so depressing for me to lose some blank CDs :roll:
I'm not using Nero 6, other than to try it, due to the date bug in InCD 4.* and the failure of the recently released multimounter.
Until InCD and multimounter are fixed, I have no reason to use other than Nero 5.5.10.42, InCD 3.5.24.0 and EWR 1.0.1.0 (or is it 3.3.2.0?).
kaikow
Postby dodecahedron on Sat Aug 09, 2003 8:16 pm
kaikow wrote:EWR 1.0.1.0 (or is it 3.3.2.0?).
who knows ??? :o
