Philips PCRW1208 firmware.
Postby CDRecorder on Thu May 15, 2003 9:15 am
Does anyone know where I could get the 1.2 version of the Philips PCRW1208 firmware? Thanks! :)
Edit: Does anyone have the P3.1 firmware, either? I can find many links to it on many web sites, but they're all broken.
Postby TheWizard on Thu May 15, 2003 9:50 pm
The newer firmwares (v3.8 and v4.0) didn't work? Look here...
http://forum.rpc1.org/dl_firmware.php?download_id=598
No, I like women.
Postby CDRecorder on Thu May 15, 2003 11:36 pm
Thank you TheWizard. I have tried both P3.8 and V4.0, but I have some packet-writing issues and some recording software speed issues. My drive came with V1.2, and I was wondering if the newer firmware was causing a problem, so I want to try older firmware. Thanks for your help!
I also did find a copy of the P3.1 firmware on http://www.driverguide.com. They actually store the files as opposed to linking to the manufacturer's web site, so they will have the files even if the manufacturer deletes them.
Postby TheWizard on Thu May 15, 2003 11:39 pm
Did 3.1 from driverguide.com work better for you than 3.8 and 4.0?
No, I like women.
Postby CDRecorder on Fri May 16, 2003 12:13 am
I just finished downloading 3.1, and I am flashing right now. I'll let you know how it works!
Postby CDRecorder on Fri May 16, 2003 12:22 am
So far, so good... The drive erased a CD-RW disc properly just now; this was something it used to have trouble with (on firmwares 3.8 and 4). I'm now formatting a CD-RW for packet writing. Interestingly, the information in Nero InfoTool looks a lot more like the info for the drive's original firmware than did 3.8 or 4. Maybe it'll work better with CD-RW discs, now.
In case you're wondering, I updated from the drive's original firmware because I wanted the added Seamless Link support. 3.1 is still new enough to have Seamless Link support, so I'll be happy with it if it works right.
Postby CDRecorder on Fri May 16, 2003 1:48 am
Well, the firmware version 3.1 seems to work better; the drive will erase CD-RW discs properly. :)
But, it still is acting up when packet writing. What it does is when it's "verifying" the disc, it keeps on going, for nearly an hour. I let it go for about 55 minutes this time (it should only take about 20), and then I gave it the three-fingered-salute and erased the disc. I wonder if it just doesn't like the discs I have. They are 12x Philips CD-RWs made by CMC. But, I do use the same discs problem-free in my LTR-12101B, my LTR-32123S, and my Matshita UJDA340.
Postby CDRecorder on Fri May 16, 2003 2:07 am
I'm running some tests; I think the problem is just poor media. :evil: I guess my Lite-On probably just handles this poor media better. I'll post more conclusive results later.
Postby CDRecorder on Fri May 16, 2003 2:29 am
OK, here are some results of testing with KProbe 1.1.10 on my LTR-32123S with FW XS0Z. Both discs were burned on the PCRW1208 from a 74-min ISO image.
The disc with which I tried to packet write:
C1 Max = 3587, Total = 7401755, Average = 2001.015
C2 Max = 19, Total = 1817, Average = 0.491
A terrible result; no wonder the drive slowed down so much in the verification stage when packet writing!
A new disc from the same package:
C1 Max = 71, Total = 54581, Average = 13.316
C2 Max = 0, Total = 0, Average = 0.000
A much better result, but far from wonderful.
I'll try some software compatibilty tests later. Thanks for the help and interest, TheWizard. :D
Postby TheWizard on Fri May 16, 2003 5:23 am
Hey, no problem. :) Definitely try other discs. I know someone with the PCRW800 and it's very picky with media; perhaps all Philips drives are picky.
No, I like women.
Postby CDRecorder on Fri May 16, 2003 10:57 am
I certainly will try other media. I haven't known my PCRW1208 to be picky with CD-R media; maybe it just has a harder time with CD-RW.
Postby CDRecorder on Sun May 18, 2003 4:00 pm
I'm sorry I took so long to post my results. I've been really busy.
Anyhow, the drive seems to be working better with the P3.1 firmware. The CD-R writing quality seems fine, and the drive formatted a new CD-RW disc just fine. I guess it just is a little picky with CD-RW discs, although it seems to be able to write any CD-R I can put in it. I still haven't gotten a chance to try out other CD-RW media, though.
Thanks for your help, TheWizard!
Postby CDRecorder on Tue May 20, 2003 3:13 pm
Actually, I flashed the drive back to 4.0 just to do some more tests, and now, it seems to work just as well as it did with P3.1. Maybe my only problem has been a media problem all along.
Postby TheWizard on Wed May 21, 2003 4:45 am
Media compatibility (or incompatibility) is to blame for a lot of CD burner problems. Only one way to find out, buy a different brand/manufacturer of CD-RW's and run the same tests. :)
No, I like women.
Postby CDRecorder on Wed May 21, 2003 11:09 am
Thanks TheWizard! I really didn't understand how much media compatibility mattered.
I checked some of these CD-RWs in my other drives. My other burners burn the bad CD-RWs better than the Philips, but the results aren't good.
One other thing I learned about the PCRW1208 is that it actually checks media quality before burning to determine the proper speed and laser power. The only bad thing about this is that it only does this with CD-R discs. Maybe that's why it's picky about CD-RW discs, but it seems better than my Lite-On LTR-12101B with CD-Rs.
Postby banzibaby on Wed May 21, 2003 12:02 pm
Hi LiteOnGuy :D
If U are using InCd as the packet writing soft, then disable the safe mode/verify data by right clicking INCD & select properties
This feature just don't seem 2 work right :(
Hopefully that should solve the verify prob :D
BaNzI :lol:
banzibaby
Postby CDRecorder on Wed May 21, 2003 3:21 pm
Thanks, banzibaby. That's good advice, but I'm not using InCD. Anyway, I am now 100% certain was that the 12x Philips CD-RWs that I was using were just poor quality. :( Now, I just need to get some better discs (like Verbatims).
Postby TheWizard on Thu May 22, 2003 11:23 am
Mmmmmm...Verbatim. Ooooh! I get a tingle in my spine everytime I hear that name! A good tingle, that is! Suffice it to say, Verbatim discs...arouse me.
No, I like women.
Postby CDRecorder on Thu May 22, 2003 8:34 pm
So, I take it the Verbatim discs have worked well for you?
Postby TheWizard on Sat May 24, 2003 5:04 am
Ohhh yeahhh! Actually, all Mitsubishi CD-RW discs have worked well for me, with Verbatim leading the pack. Other branded Mitsubishi-manufactured discs I have used include Maxell and LG.
No, I like women.
