Can I directly watch *.VOB files with PowerDVD?
Postby pranav81 on Sun May 16, 2004 3:03 pm
Hi guys.I want to know if I can play the *.VOB files copied from a DVD directly in a player like PowerDVD?A friend of mine has a collection of some movies,but he says that the movies are first to be converted into MPEG or AVI format and then I can watch them.
So is there any chance so that I may play the files directly in any software?
::Pranav::
pranav81
Postby CignaXI on Sun May 16, 2004 3:29 pm
Yes. just open the vob with the player
Still burning with my LTR-16101B.
CignaXI
Postby pranav81 on Mon May 17, 2004 3:08 am
Thanks CignaXI,
I checked the help file after I posted and found that PowerDVD plays the files copied.
Also which software should I use to convert the VOB files to MPEG?I would like to copy the DVD movie to play on a normal VCD player on a CD-R/W.
See ya later,
::Pranav::
pranav81
Postby CignaXI on Mon May 17, 2004 9:44 am
Well, you really aren't in the right place go to this site:
http://www.doom9.org/
For VOb to vcd o svcd I use DVD2SVCD, you will find it in that website, plus all the other software necesary for this to be done. Please remember that there are copyright laws......
CignaXI
Postby pranav81 on Tue May 18, 2004 11:20 am
Thanks a lot for the link.I will check it out rightway.
::Pranav::
pranav81
