longevity-freak wrote:My room temperature is approx. 31 degrees Celcius and relative humidity in the room is about 88%.
dolphinius_rex wrote:Out of curiousity, do you have any pressed CDs or DVDs that have degraded like your burned media has?
For myself... even my crappiest media usually lasts longer then 4 months, if it doesn't fail during the burn.
Alektron wrote:This is a very interesting and important discussion. Unfortunately, I haven't done much on-line research on this matter, let alone independent tests. Based on Longevity's posts, it appears that the burned DVDs are deteriorating in terms of the die. Is this agreed by everyone? However, I am wondering if the die deterioration is primarily caused by the higher temperature or the humidity? These two variables are independent, but they coincide in regions like Singapore (the author's home). I believe that only one of these variables is the root cause. The chemical mechanism of die breakdown is a chemical process.
If we assume that the cause is moisture, how can the moisture reach inside the plastic layers to the die? Could it be an imprecise plastic seal? If moisture is seeping into the plastic, the H2O could be providing itself as a catalyst to the die breakdown.
On the other hand, if a higher temperature is the cause, the plastic of the disc makes no difference. The temperature would be breaking down the die.
Therefore, I was wondering if you can make a controlled experiment such that the temperature is held in a favorable condition constantly, with an elevated humidity for Test Setup #1. For #2, reverse the variables. Also, I would like to know which DVD+/-R discs (and dies) are failing the most severly and which are the best.
longevity-freak wrote:dolphinius_rex wrote:Out of curiousity, do you have any pressed CDs or DVDs that have degraded like your burned media has?
I have 3 factory pressed DVD movies. I tested one of them last. The PI/PO graph is very good, low error rates. This disc have been around for 2+ years already.
In your opinion, do TDK DVD R 8x "ScratchProof" also belong to this type of media with protective coating ?dolphinius_rex wrote:I wonder how media with protective coatings (I.E. Maxell's BQ media) and Emtec's Gold DVD+Rs (Or MAM's Gold DVD-Rs) would react
frank1 wrote:In your opinion, do TDK DVD R 8x "ScratchProof" also belong to this type of media with protective coating ?dolphinius_rex wrote:I wonder how media with protective coatings (I.E. Maxell's BQ media) and Emtec's Gold DVD+Rs (Or MAM's Gold DVD-Rs) would react
Anyway they got a good rating [Stab +] in "climatic stability"
for the tests recently published by c't magazine
TTH01 - Made in Luxembourg, only ??
However, I am wondering if the die deterioration is primarily caused by the higher temperature or the relative humidity?
Relative Humidity is temperature dependant ! (Psychometry)
So I think we can make the conlcusion humidity is your real problem.
Alektron wrote:By the way, have you posted the chemical breakdown formula for the die? Hey, perhaps you should patent your own die formula and sell it to everyone?
RJW wrote:That's a tricky question.
Normally rewritables are more sensitive.
Verbatim own test results show this (50 year DVD-RW and 75 DVD-R I think it was.).
However DVD-ram which everybody likes as archival thingie is the boxed one. There's a good possibility that the caseing might slightly limit mass transfer of water.
Also the phase change dye's of Ram's are slightly different.
I would have to see if I can dig up any reports on stability of RAM layers.
Currently no time for that one.
frank1 wrote:Bismuth salts were even used in the old days to treat venerial deseases !!
All Content is Copyright (c) 2001-2024 CDRLabs Inc. |
