Problem with LiteOn 1693S CDRW mostly
Postby plodz1 on Sat Aug 13, 2005 4:12 am
I have a problem with LiteOn 1693S CDRW disks mostly
it records a cdrw and than I can't read it on another cd drive.
sometimes it helps to full erase CDRW and then record, but it takes to much time, and I use quit good disks like basf or dysan etc.
Does anyone have similar experience and maybe solution?
Thx
Plodz
plodz1
Postby Scour on Sat Aug 13, 2005 1:10 pm
What speed the media is rated? Have you ever tried Verbatim?
Postby plodz1 on Sat Feb 04, 2006 8:44 am
I tried tdk mostly couse I bought 10 pack :(
I think my computer is too slow or not enough power.
Plodz
plodz1
Postby dodecahedron on Sat Feb 04, 2006 12:58 pm
hello plodz1, welcome to CDRLabs.
try using Verbatim CDRWs, they are considered the best CDRWs.
make sure you burn No Multisession, DAO (Disc-at-Once), and make sure you Finalize the CD.
Postby Ian on Sat Feb 04, 2006 1:57 pm
Lite-On's DVD writers are notoriously bad with RW media. It doesn't help that TDK's CD-RW discs are usually from questionable manufacturers.
Users browsing this forum: No registered users and 17 guests
