Inertia wrote:Go to File | Create CD Hard Disc Image and save a hard disc image of the compilation. Then use Record CD from CD Image to burn the disc using DAO mode.
Inertia wrote:Buffer underrun protection is useful for preventing inadvertant buffer underruns, but I would not choose to use it as a method to purposely suspend a burn with a technology that produces inaudible "gaps" as most BU technologies still do. In other words, I accept it when it happens, but I would try to avoid it when possible.
<snip>
Given the choice of an interrupted burn with artifacts (although inaudible) or a burn without interruption or artifacts I would choose the latter.
Inertia wrote:DAO burning may not be an issue with buffer underrun protection if you don't mind stopping a burn while changing CD's. It is a major issue for the many people who are still using older burners without buffer underrun protection. Caching definitely helps but as burning speed increases it won't prevent problems without buffer underrun protection. Caching has been around much longer than buffer underrun protection, and it hasn't been reliable for preventing coasters.
Inertia wrote:In the Nero Audio CD | CDA Options, choose Tempfile strategy.
Inertia wrote:From the Nero help:
Diskspace strategy: A cda file is treated as tempfile, if there is enough diskspace in the Nero cache path of the harddisk. Otherwise track references are used.
Track references don't require harddisk space and are read only at burn time. They can be read only from CD-ROM/DVD-ROM drives, but not from CD recorders. This representation of cda files cannot be written in disc at once mode.
Temporary track files are stored as files on harddisk. They can be written in disc at once mode, but require harddisk space in the Nero cache path. This cda representation can be read both from CD recorders and CD-ROM/DVD-ROM drives.
Tempfile strategy: Each cda file is stored as temporary track file on harddisk.
All Content is Copyright (c) 2001-2024 CDRLabs Inc. |
