LIte-on LTR-52327s wont read cd's
Postby andylogan on Sat Nov 15, 2003 12:17 pm
Since upgrading to windows XP home I can't install anything from my cd-rw. When I try I get the error " "is not a win32 application. Autoplay doesnt work either. Any suggestions would be great!
andylogan
Postby rdgrimes on Sat Nov 15, 2003 8:24 pm
Remove the IDE controller in device manager and reboot, see if that helps.
rdgrimes
Postby andylogan on Sun Nov 16, 2003 2:12 am
I have just tried but no luck
andylogan
Postby rdgrimes on Sun Nov 16, 2003 2:20 am
Well you've got some kind of corruption in the drivers or software, beats me. You might look around in event viewer to see if there's any clues.
rdgrimes
Postby andylogan on Sun Nov 16, 2003 3:19 am
Event viewer shows hundreds of errors. They are all event 11 (The driver detected a controller error on \device\cdRom0) Microsoft support says there is no more info on these errors
andylogan
Postby UALOneKPlus on Sun Nov 16, 2003 11:55 am
rebuild your computer part by part ;)
-Danny Kaye
UALOneKPlus
Postby rdgrimes on Sun Nov 16, 2003 12:04 pm
Well we can assume that since it was all working prior to your "upgrade", that the hardware is OK. Did you do an upgrade install over Win98? If so, you need to wipe the HD and start fresh. You can still do this with the upgrade version of XP, as long as you have a Win98 CD around to insert when prompted. This install of XP is FUBAR and needs to be re-done, which is often the case with upgrade installs.
Backup everything and start over.
rdgrimes
Postby integspec on Sat Nov 22, 2003 5:40 am
Overwriting OS over OS is easiest way to mess up everything. I'm yet to see anyone doing this and being content with the results. If you cant format, make a boot floppy with smartdrv and copy deltree to it. Boot from floppy, deltree both windows and Progra~1 (Program Files)directories and do a fresh installation. Make sure you backup necessary stuff from those dirs first.
Cheers.
Nor iron bars a cage;
Minds innocent and quiet take
That for an hermitage;
If I have freedom in my love,
And in my soul am free,
Angels alone that soar above
integspec
Users browsing this forum: Majestic-12 [Bot] and 8 guests
