Problem copying with 411s, help is appreciated!
Postby coadman on Sun Jan 30, 2005 3:19 pm
I have a 411s with firmware FSOH. I have used this same firmware for the past 8 months or so, with no reason to update or change as it has worked for me. Just recently I have tried to copy some DVD's I had taped with my LiteOn 5005 recorder. I was not having any success using DVD Shrink or DVD decrypter, but thought it might have been something with the 5005, as I had read people had been having "some" problems. This morning I tried copying a DVD that we had purchased, to eliminate the 5005 as part of the problem. I used DVD shrink 3.2, and after the "encoding" I selected the "backup", the target and source were as I wanted them, and when I selected to continue, this is the error message I recieved...."DVD Shrink encounted an error and cannot continue, Failed to write file "E.\DVD.VIDEO.ISO".....So does this tell you guys anything I need to check? I have ran so many "spyware" and "virus" programs the past few weeks, I thought perhaps I had deleted some file, that I need for Shrink to work? I also tried to use DVD decrypter, alone, but it failed also(I cannot remember what error message I received). Anybody have any ideas? I would appreciate any help you can render!
thank you,
coadman
coadman
Postby burninfool on Sun Jan 30, 2005 6:47 pm
Reinstall DVDDecrypter and use Nero InfoTool to see if your ASPI layer is working properly.
www.cdspeed2000.com
If that doesn't help try another DVD drive.
Postby coadman on Sun Jan 30, 2005 8:02 pm
burninfool wrote:Reinstall DVDDecrypter and use Nero InfoTool to see if your ASPI layer is working properly.
www.cdspeed2000.com
I uninstalled, and then re-installed Shrink, but didnt do that with Decrypter, as I thought the problem was probably something else. I guess I can try doing the same with the Decrypter program, but that doesnt seem like it could be the problem, but Im open to all suggestions. I dont have another DVD burner, so that's out of the question.
thanks for the response,
coadman
coadman
Postby redk9258 on Mon Jan 31, 2005 12:54 am
Make sure you get the latest versions of shrink and decryptor.
redk9258
Postby coadman on Mon Jan 31, 2005 6:50 am
redk9258 wrote:Make sure you get the latest versions of shrink and decryptor.
I've got the latest version of Shrink, I will check on Decrypter, but I think I downloaded a new version last fall.
coadman
coadman
Postby Wesociety on Mon Jan 31, 2005 10:14 am
Let's see the Decrypter log file.
Postby coadman on Mon Jan 31, 2005 11:10 am
Wesociety wrote:Let's see the Decrypter log file.
Do you want me to try and use decrypter, only, then show you that log file?
thanks,
coadman
coadman
Postby Wesociety on Mon Jan 31, 2005 12:54 pm
Just the burn process log file is fine.
Postby coadman on Mon Jan 31, 2005 2:01 pm
OK, just tried to burn again,,thought it was going to work this time, got all the way to almost done with the burn in decrypter, then got error message, that it couldnt complete...
I 11:49:37 DVD Decrypter Version 3.5.2.0 started!
I 11:49:37 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 1)
I 11:49:37 Initialising SPTI...
I 11:49:37 Searching for SCSI / ATAPI devices...
I 11:49:37 Found 1 CD-RW and 1 DVD±RW!
I 11:51:15 Operation Started!
I 11:51:15 Source File: C:\MOVIES\DVD_VIDEO.ISO
I 11:51:15 Source File Sectors: 2,285,854 (MODE1/2048)
I 11:51:15 Source File Size: 4,681,428,992 bytes
I 11:51:15 Destination Device: [1:1:0] LITE-ON DVDRW LDW-411S FS0H (G:) (ATA)
I 11:51:15 Destination Media Type: DVD+R (Disc ID: RITEK-R03-02) (Speeds: 0x, 0x)
I 11:51:15 Destination Media Sectors: 2,295,104
I 11:51:15 Write Mode: DVD
I 11:51:15 Write Speed: MAX
I 11:51:15 Test Mode: No
I 11:51:15 BURN-Proof: Enabled
I 11:51:16 Filling Buffer...
I 11:51:17 Writing LeadIn...
I 11:51:26 Writing Image...
W 12:03:50 Failed to Write Sectors 2012032 - 2012063 - Write Error
W 12:03:50 Retrying (1 of 20)...
W 12:03:50 Retry Failed - Invalid Address For Write
W 12:03:50 Retrying (2 of 20)...
W 12:03:50 Retrying (3 of 20)...
W 12:03:50 Retrying (4 of 20)...
W 12:03:50 Retrying (5 of 20)...
W 12:03:50 Retrying (6 of 20)...
W 12:03:50 Retrying (7 of 20)...
W 12:03:50 Retrying (8 of 20)...
W 12:03:50 Retrying (9 of 20)...
W 12:03:50 Retrying (10 of 20)...
W 12:03:50 Retrying (11 of 20)...
W 12:03:50 Retrying (12 of 20)...
W 12:03:50 Retrying (13 of 20)...
W 12:03:50 Retrying (14 of 20)...
W 12:03:50 Retrying (15 of 20)...
W 12:03:50 Retrying (16 of 20)...
W 12:03:50 Retrying (17 of 20)...
W 12:03:50 Retrying (18 of 20)...
W 12:03:50 Retrying (19 of 20)...
W 12:03:50 Retrying (20 of 20)...
W 12:03:50 Retry Failed! - Invalid Address For Write
W 12:04:27 Failed to Write Sectors 2012032 - 2012063 - Invalid Address For Write
W 12:04:27 Retrying (1 of 20)...
W 12:04:27 Retry Failed - Invalid Address For Write
W 12:04:27 Retrying (2 of 20)...
W 12:04:27 Retrying (3 of 20)...
W 12:04:27 Retrying (4 of 20)...
W 12:04:27 Retrying (5 of 20)...
W 12:04:27 Retrying (6 of 20)...
W 12:04:27 Retrying (7 of 20)...
W 12:04:27 Retrying (8 of 20)...
W 12:04:27 Retrying (9 of 20)...
W 12:04:27 Retrying (10 of 20)...
W 12:04:27 Retrying (11 of 20)...
W 12:04:27 Retrying (12 of 20)...
W 12:04:27 Retrying (13 of 20)...
W 12:04:27 Retrying (14 of 20)...
W 12:04:27 Retrying (15 of 20)...
W 12:04:27 Retrying (16 of 20)...
W 12:04:27 Retrying (17 of 20)...
W 12:04:27 Retrying (18 of 20)...
W 12:04:27 Retrying (19 of 20)...
W 12:04:27 Retrying (20 of 20)...
W 12:04:27 Retry Failed! - Invalid Address For Write
W 12:04:36 Failed to Write Sectors 2012032 - 2012063 - Invalid Address For Write
W 12:04:36 Retrying (1 of 20)...
W 12:04:36 Retry Failed - Invalid Address For Write
W 12:04:36 Retrying (2 of 20)...
W 12:04:36 Retrying (3 of 20)...
W 12:04:36 Retrying (4 of 20)...
W 12:04:36 Retrying (5 of 20)...
W 12:04:36 Retrying (6 of 20)...
W 12:04:36 Retrying (7 of 20)...
W 12:04:36 Retrying (8 of 20)...
W 12:04:36 Retrying (9 of 20)...
W 12:04:36 Retrying (10 of 20)...
W 12:04:36 Retrying (11 of 20)...
W 12:04:36 Retrying (12 of 20)...
W 12:04:36 Retrying (13 of 20)...
W 12:04:36 Retrying (14 of 20)...
W 12:04:36 Retrying (15 of 20)...
W 12:04:36 Retrying (16 of 20)...
W 12:04:36 Retrying (17 of 20)...
W 12:04:36 Retrying (18 of 20)...
W 12:04:36 Retrying (19 of 20)...
W 12:04:36 Retrying (20 of 20)...
W 12:04:36 Retry Failed! - Invalid Address For Write
W 12:04:37 Failed to Write Sectors 2012032 - 2012063 - Invalid Address For Write
W 12:04:37 Retrying (1 of 20)...
W 12:04:37 Retry Failed - Invalid Address For Write
W 12:04:37 Retrying (2 of 20)...
W 12:04:37 Retrying (3 of 20)...
W 12:04:37 Retrying (4 of 20)...
W 12:04:37 Retrying (5 of 20)...
W 12:04:37 Retrying (6 of 20)...
W 12:04:37 Retrying (7 of 20)...
W 12:04:37 Retrying (8 of 20)...
W 12:04:37 Retrying (9 of 20)...
W 12:04:37 Retrying (10 of 20)...
W 12:04:37 Retrying (11 of 20)...
W 12:04:37 Retrying (12 of 20)...
W 12:04:37 Retrying (13 of 20)...
W 12:04:37 Retrying (14 of 20)...
W 12:04:37 Retrying (15 of 20)...
W 12:04:37 Retrying (16 of 20)...
W 12:04:37 Retrying (17 of 20)...
W 12:04:37 Retrying (18 of 20)...
W 12:04:37 Retrying (19 of 20)...
W 12:04:37 Retrying (20 of 20)...
W 12:04:37 Retry Failed! - Invalid Address For Write
W 12:04:38 Failed to Write Sectors 2012032 - 2012063 - Invalid Address For Write
W 12:04:38 Retrying (1 of 20)...
W 12:04:38 Retry Failed - Invalid Address For Write
W 12:04:38 Retrying (2 of 20)...
W 12:04:38 Retrying (3 of 20)...
W 12:04:38 Retrying (4 of 20)...
W 12:04:38 Retrying (5 of 20)...
W 12:04:38 Retrying (6 of 20)...
W 12:04:38 Retrying (7 of 20)...
W 12:04:38 Retrying (8 of 20)...
W 12:04:38 Retrying (9 of 20)...
W 12:04:38 Retrying (10 of 20)...
W 12:04:38 Retrying (11 of 20)...
W 12:04:38 Retrying (12 of 20)...
W 12:04:38 Retrying (13 of 20)...
W 12:04:38 Retrying (14 of 20)...
W 12:04:38 Retrying (15 of 20)...
W 12:04:38 Retrying (16 of 20)...
W 12:04:38 Retrying (17 of 20)...
W 12:04:38 Retrying (18 of 20)...
W 12:04:38 Retrying (19 of 20)...
W 12:04:38 Retrying (20 of 20)...
W 12:04:38 Retry Failed! - Invalid Address For Write
W 12:04:39 Failed to Write Sectors 2012032 - 2012063 - Invalid Address For Write
W 12:04:39 Retrying (1 of 20)...
W 12:04:39 Retry Failed - Invalid Address For Write
W 12:04:39 Retrying (2 of 20)...
W 12:04:39 Retrying (3 of 20)...
W 12:04:39 Retrying (4 of 20)...
W 12:04:39 Retrying (5 of 20)...
W 12:04:39 Retrying (6 of 20)...
W 12:04:39 Retrying (7 of 20)...
W 12:04:39 Retrying (8 of 20)...
W 12:04:39 Retrying (9 of 20)...
W 12:04:39 Retrying (10 of 20)...
W 12:04:39 Retrying (11 of 20)...
W 12:04:39 Retrying (12 of 20)...
W 12:04:39 Retrying (13 of 20)...
W 12:04:39 Retrying (14 of 20)...
W 12:04:39 Retrying (15 of 20)...
W 12:04:39 Retrying (16 of 20)...
W 12:04:39 Retrying (17 of 20)...
W 12:04:39 Retrying (18 of 20)...
W 12:04:39 Retrying (19 of 20)...
W 12:04:39 Retrying (20 of 20)...
W 12:04:39 Retry Failed! - Invalid Address For Write
W 12:04:40 Failed to Write Sectors 2012032 - 2012063 - Invalid Address For Write
W 12:04:40 Retrying (1 of 20)...
W 12:04:40 Retry Failed - Invalid Address For Write
W 12:04:40 Retrying (2 of 20)...
W 12:04:40 Retrying (3 of 20)...
W 12:04:40 Retrying (4 of 20)...
W 12:04:40 Retrying (5 of 20)...
W 12:04:40 Retrying (6 of 20)...
W 12:04:40 Retrying (7 of 20)...
W 12:04:40 Retrying (8 of 20)...
W 12:04:40 Retrying (9 of 20)...
W 12:04:40 Retrying (10 of 20)...
W 12:04:40 Retrying (11 of 20)...
W 12:04:40 Retrying (12 of 20)...
W 12:04:40 Retrying (13 of 20)...
W 12:04:40 Retrying (14 of 20)...
W 12:04:40 Retrying (15 of 20)...
W 12:04:40 Retrying (16 of 20)...
W 12:04:40 Retrying (17 of 20)...
W 12:04:40 Retrying (18 of 20)...
W 12:04:40 Retrying (19 of 20)...
W 12:04:40 Retrying (20 of 20)...
W 12:04:40 Retry Failed! - Invalid Address For Write
W 12:04:41 Failed to Write Sectors 2012032 - 2012063 - Invalid Address For Write
W 12:04:41 Retrying (1 of 20)...
W 12:04:41 Retry Failed - Invalid Address For Write
W 12:04:41 Retrying (2 of 20)...
W 12:04:41 Retrying (3 of 20)...
W 12:04:41 Retrying (4 of 20)...
W 12:04:41 Retrying (5 of 20)...
W 12:04:41 Retrying (6 of 20)...
W 12:04:41 Retrying (7 of 20)...
W 12:04:41 Retrying (8 of 20)...
W 12:04:41 Retrying (9 of 20)...
W 12:04:41 Retrying (10 of 20)...
W 12:04:41 Retrying (11 of 20)...
W 12:04:41 Retrying (12 of 20)...
W 12:04:41 Retrying (13 of 20)...
W 12:04:41 Retrying (14 of 20)...
W 12:04:41 Retrying (15 of 20)...
W 12:04:41 Retrying (16 of 20)...
W 12:04:41 Retrying (17 of 20)...
W 12:04:41 Retrying (18 of 20)...
W 12:04:41 Retrying (19 of 20)...
W 12:04:41 Retrying (20 of 20)...
W 12:04:41 Retry Failed! - Invalid Address For Write
E 12:04:42 Failed to Write Sectors 2012032 - 2012063 - Invalid Address For Write
I 12:04:42 Synchronising Cache...
I 12:04:42 Closing Track...
I 12:04:42 Finalising Disc...
E 12:04:42 Failed to Write Image!
E 12:04:42 Operation Failed! - Duration: 00:13:27
I 12:04:42 Average Write Rate: 5,055 KB/s (3.6x) - Maximum Write Rate: 5,591 KB/s (4.0x)
coadman
Postby burninfool on Mon Jan 31, 2005 3:52 pm
It could be two reasons:
1.Bad media,try another brand(pref.Made in Japan).
2.Your drive is fried,can you write CD's?
If you can write CD's then I think it's the media,some DVDR have problems writing past 4.2GB.In DVDShrink make the target size <4,200MB,if that doesn't help it's probably a bad batch of DVDR.
