Problems: BenQ DW1620 with fake TY discs
Postby traian2003 on Thu Jun 16, 2005 5:41 pm
Hey guys,
This is my problem, maybe you guys can figure if it's the DVDs or the burner.
I just bought a DW1620 OEM. Now, I also had some fake TY discs from before. When I used disc interpreter it told me that they're TYs but I highly doubt it.
Now when I burned these DVDs, my Philips DVP642 burner will not read them, but the DW1620 would read them with no problems. The firmware that I'm using is G7V9. When burned with my Pioneer 104, the discs are read flawlessly by my DVP642. I tried burning the media at 8X, 4X, and 2.4X, and none of them worked. Also when I checked for errors the disc had none.
Now for more detailed information:
DISC INFORMATION:
Media Information
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID TYG02
Format Capacity 1.51GB(1.62GB)
Book Type DVD-R
Media Type DVD-R
Manufacturer Rated Speed 8.0x 11080KBps
Available Write Descriptor CLV 16.0x 22160KBps
Available Write Descriptor CLV 12.0x 16620KBps
Available Write Descriptor CLV 8.0x 11080KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Write Strategy Speed 4.0x 5540KBps
2x Speed OPC beta 08
2x Speed OPC power 0E
2x Write Strategy field 1 11 87 78 80
2x Write Strategy field 2 88 80 00 00 00 00
4x Speed OPC beta 06
4x Speed OPC power 13
4x Write Strategy field 1 0D 10 0E 07
4x Write Strategy field 2 97 07 0D 0B
4x Write Strategy field 3 80 00 00 00
4x Speed OPC beta multi-pulse 06
4x Speed OPC power multi-pulse 18
4x Write Strategy field 4 17 85 78 75
4x Write Strategy field 5 D6 89 A8 92 01 20
4x Write Strategy field 6 10 00 D0 00 00
Data area starting sector 30000h
Data area end sector C0C9Fh
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
Complete Media Code
00000000 00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 87 0D 10 .l...@....R.....
00000010 66 78 80 00 03 54 59 47 30 32 00 00 04 00 00 00 fx...TYG02......
00000020 00 00 00 00 05 AA A2 22 22 20 02 00 06 08 0E 11 ......."" ......
What can I conclude from this? Is it the drive or the discs?
Any help will be much appreciated.
traian2003
Postby dolphinius_rex on Thu Jun 16, 2005 6:04 pm
what are the serial numbers printed on the disc? (not the MID)
Postby traian2003 on Thu Jun 16, 2005 6:10 pm
This is what is written on the inside of the disc: OL25MH0406250315C, thus no GG. :cry:
traian2003
Postby dolphinius_rex on Thu Jun 16, 2005 7:21 pm
that's made by Optodisc... most likely it's a downgrade Optodisc. What you need is a Pioneer DVR-109 to burn those (with firmware 1.50). Not worth more then $0.32 CAD at most.
Try using B7S9 and burn them at 4x.
Alternatively, you can hack the firmware, and switch the firmware's write strategy's for TYG02 with OPTODISCR008.
Postby traian2003 on Thu Jun 16, 2005 11:12 pm
dolphinius_rex wrote:that's made by Optodisc... most likely it's a downgrade Optodisc. What you need is a Pioneer DVR-109 to burn those (with firmware 1.50). Not worth more then $0.32 CAD at most.
I'm a big newb, so you should be more specific for me to understand. I don't care much about them, because I just bought 200 real TYs from NCIX, all I want is to know if the drive is faulty.
traian2003
Postby traian2003 on Thu Jun 16, 2005 11:17 pm
Also whenever I want to try to upgrade my firmware, it tells me that it won't want to.
traian2003
Postby dolphinius_rex on Fri Jun 17, 2005 2:14 am
traian2003 wrote:Also whenever I want to try to upgrade my firmware, it tells me that it won't want to.
Looks like you have the G7x9 series for firmwares (the OEM version), so either use the OEM firmwares from the BenQ site, or hack the retail firmware.
BenQ hacks can be found here:
http://dvdpro.club.st/firmware/BenQ_FW.htm#DW1620
