Problems Overburning With Nero
Postby rriehl on Sat Mar 20, 2004 1:23 am
I am trying to burn a one .cue and one .bin file to a cd-r and before any burning even starts I get an error.
Here is the log, what am I doing wrong?
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 8/14/2002 3:03:36 PM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 7:18:06 PM
Nero version: 6.3.0.3 (Nero Express)
Recorder: <PIONEER DVD-RW DVR-107D>Version: 1.10 - HA 1 TA 1 - 6.3.0.3
Adapter driver: <IdeChnDr> HA 1
Drive buffer : 2000kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <PIONEER DVD-RW DVR-107D>Version: 1.10 - HA 1 TA 1 - 6.3.0.3
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD2500JB-00EVA0 IdeChnDr Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD1200JB-75CRA0 IdeChnDr Port 0 ID 1 DMA: Off
CdRomPeripheral : SAMSUNG CD-ROM SC-148C IdeChnDr Port 1 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-107D IdeChnDr Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
SAMSUNG CD-ROM SC-148C E: CDRom0
PIONEER DVD-RW DVR-107D F: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1022MB (1047528kB)
Free physical memory: 561MB (575392kB)
Memory in use : 45 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
20.3.2004
CD-ROM (ISO)
12:20:56 AM #1 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
12:20:56 AM #2 Phase 90 File dlgbrnst.cpp, Line 1800
12:20:56 AM #3 Text 0 File Reader.cpp, Line 118
Reader running
12:20:56 AM #4 Text 0 File Writer.cpp, Line 124
Writer PIONEER DVD-RW DVR-107D running
12:20:56 AM #5 ISO9660GEN -11 File geniso.cpp, Line 3882
12:20:56 AM #6 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using CD-R/RW media
12:21:06 AM #7 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 404999 ( 90:01.74)
Last address to be written: 392133 ( 87:10.33)
12:21:06 AM #8 Text 0 File DlgWaitCD.cpp, Line 245
12:21:06 AM #9 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: PIONEER DVD-RW DVR-107D;
CDR code: 00 97 24 01; OSJ entry from: Taiyo Yuden Company Limited
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
12:21:06 AM #10 Text 0 File DlgWaitCD.cpp, Line 406
Not enough free discspace.
(Medium in drive: CD-R. Medium required by compilation: CD-R/RW.)
12:21:06 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 779
original disc pos #0 + 392134 (392134) = #392134/87:8.34
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 392134 blocks [PIONEER DVD-RW DVR-107D]
12:21:06 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [PIONEER DVD-RW DVR-107D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 803397632, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
392134 | lead-out | 1 | 0x00 | 0x41
12:21:06 AM #13 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
12:21:06 AM #14 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
12:21:06 AM #15 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
12:21:06 AM #16 Phase 28 File dlgbrnst.cpp, Line 1800
Speed measurement started
12:21:06 AM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2264
12:21:24 AM #18 Text 0 File WriterStatus.cpp, Line 115
<PIONEER DVD-RW DVR-107D> start writing Lead-Out at LBA 392134 (5FBC6h), lenght 0 blocks
12:21:24 AM #19 Text 0 File ThreadedTransfer.cpp, Line 229
12:21:25 AM #20 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
12:21:25 AM #21 Phase 29 File dlgbrnst.cpp, Line 1751
Speed measurement completed: 318.8x (47,822 KB/s)
12:21:25 AM #22 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 8x (1,200 KB/s)
12:21:25 AM #23 Text 0 File ThreadedTransferInterface.cpp, Line 2264
12:21:26 AM #24 Text 0 File Mmc.cpp, Line 14883
StartDAO : CD-Text - Off
12:21:26 AM #25 Text 0 File Mmc.cpp, Line 19487
Set BUFE: supported -> ON
12:21:26 AM #26 SCSI -1067 File Cdrdrv.cpp, Line 1171
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02CD5000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x26
Sense Qual: 0x00
CDB Data: 0x5D 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x26 0x00
12:21:26 AM #27 Text 0 File Mmc.cpp, Line 15170
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 57 0a 22
12:21:26 AM #28 CDR -1067 File ThreadedTransferInterface.cpp, Line 1573
Invalid field in parameter
12:21:26 AM #29 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1573
Could not perform start of Disc-at-once
12:21:26 AM #30 Text 0 File dlgbrnst.cpp, Line 1658
12:21:26 AM #31 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 8x (1,200 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 8/14/2002 3:03:36 PM
File 'Drivers\IdeChnDr.sys': Ver=2.3.0.2160, 10/01/2002, size=101431 bytes, created 10/15/2002 12:00:00 AM (Adapter driver for rec)
Registry Keys:
rriehl
Postby dodecahedron on Sat Mar 20, 2004 10:17 am
this looks real strange:
ATIP Data:
what media are you using? it looks like TY CD-R. wierd.
i don't know how Nero handles .bin/.cue burning and how to do it correctly.
can you burn it in another program?
(i can recommend you try burnatonce www.burnatonce.com )
Postby rriehl on Sat Mar 20, 2004 12:57 pm
I am using FujiFilm CD-R.
rriehl
Postby rriehl on Sat Mar 20, 2004 4:59 pm
Anyone?
Note: I have followed all steps in this post:
http://www.cdrlabs.com/phpBB/viewtopic.php?t=12075&highlight=overburn
rriehl
Postby rriehl on Sat Mar 20, 2004 5:09 pm
I was able to finally get it to work. It seems that instead of using the disc-at-once method, I had to use the disc-at-once/96 method.
What's the difference?
Thanks.
rriehl
Postby rriehl on Sat Mar 20, 2004 5:17 pm
Well I spoke too soon. Now the burn process starts and just before the end I get the error telling me that the burn failed.
Here is the log...
Any help would be GREATLY appreciated:
Windows XP 5.1
IA32
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Free physical memory: 662MB (678060kB)
Memory in use : 35 %
Use Inquiry : 1
20.3.2004
CD-ROM (ISO)
4:10:09 PM #1 Text 0 File Isodoc.cpp, Line 6029
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO/96
Mode : 1
Joliet : TRUE
4:10:09 PM #2 Phase 90 File dlgbrnst.cpp, Line 1800
4:10:09 PM #3 Text 0 File Reader.cpp, Line 118
Reader running
4:10:09 PM #4 Text 0 File Writer.cpp, Line 124
4:10:09 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3882
4:10:09 PM #6 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once/96, using CD-R/RW media
4:10:11 PM #7 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 449998 (100:01.73)
4:10:11 PM #8 Text 0 File DlgWaitCD.cpp, Line 245
4:10:11 PM #9 Text 0 File DlgWaitCD.cpp, Line 2085
ATIP Data:
4:10:11 PM #10 Text 0 File DlgWaitCD.cpp, Line 406
4:10:11 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 779
-> TRM_ULTRARAW96_MODE1, 2448, config 0x4, wanted index0 0 blocks, length 392134 blocks [PIONEER DVD-RW DVR-107D]
4:10:11 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [PIONEER DVD-RW DVR-107D] for write in raw writing
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_ULTRARAW96_MODE1, 2448/0x04, FilePos 0 367200 960311232, ISRC ""
DAO layout:
4:10:11 PM #13 Phase 24 File dlgbrnst.cpp, Line 1800
4:10:11 PM #14 Text 0 File Burncd.cpp, Line 4073
4:10:11 PM #15 Phase 25 File dlgbrnst.cpp, Line 1800
4:10:11 PM #16 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 24x (3,600 KB/s)
4:10:11 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2264
4:10:11 PM #18 Text 0 File Mmc.cpp, Line 14883
4:10:11 PM #19 Text 0 File Mmc.cpp, Line 19487
4:10:11 PM #20 Text 0 File Cdrdrv.cpp, Line 1277
16:10:11.718 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:31 PM #21 Text 0 File Cdrdrv.cpp, Line 1277
16:10:31.656 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:31 PM #22 Text 0 File Cdrdrv.cpp, Line 1277
16:10:31.718 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:31 PM #23 Text 0 File Cdrdrv.cpp, Line 1277
16:10:31.750 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:31 PM #24 Text 0 File Cdrdrv.cpp, Line 1277
16:10:31.781 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:31 PM #25 Text 0 File Cdrdrv.cpp, Line 1277
16:10:31.812 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:31 PM #26 Text 0 File Cdrdrv.cpp, Line 1277
16:10:31.843 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:31 PM #27 Text 0 File Cdrdrv.cpp, Line 1277
16:10:31.875 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:31 PM #28 Text 0 File Cdrdrv.cpp, Line 1277
16:10:31.906 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #29 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.031 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #30 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.062 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #31 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.093 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #32 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.125 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #33 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.156 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #34 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.187 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #35 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.218 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #36 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.328 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #37 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.359 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #38 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.390 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #39 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.421 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #40 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.453 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #41 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.484 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #42 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.515 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #43 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.546 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #44 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.656 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #45 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.687 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #46 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.718 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #47 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.750 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #48 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.781 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #49 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.812 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #50 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.843 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #51 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.875 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:32 PM #52 Text 0 File Cdrdrv.cpp, Line 1277
16:10:32.984 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #53 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.015 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #54 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.046 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #55 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.078 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #56 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.109 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #57 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.140 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #58 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.171 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #59 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.203 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #60 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.328 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #61 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.359 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #62 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.390 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #63 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.421 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #64 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.453 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #65 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.484 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #66 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.515 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #67 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.625 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #68 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.656 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #69 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.687 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #70 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.718 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #71 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.750 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #72 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.781 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #73 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.812 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #74 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.843 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #75 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.953 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:33 PM #76 Text 0 File Cdrdrv.cpp, Line 1277
16:10:33.984 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #77 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.015 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #78 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.046 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #79 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.078 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #80 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.109 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #81 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.140 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #82 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.171 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #83 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.281 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #84 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.312 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #85 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.343 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #86 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.375 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #87 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.406 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #88 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.437 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #89 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.468 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #90 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.500 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #91 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.609 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #92 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.640 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #93 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.671 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #94 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.703 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #95 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.734 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #96 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.765 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #97 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.796 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #98 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.828 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #99 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.953 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:34 PM #100 Text 0 File Cdrdrv.cpp, Line 1277
16:10:34.984 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #101 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.015 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #102 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.046 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #103 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.078 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #104 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.109 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #105 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.140 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #106 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.234 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #107 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.265 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #108 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.296 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #109 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.328 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #110 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.359 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #111 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.390 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #112 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.421 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #113 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.453 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #114 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.562 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #115 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.593 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #116 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.625 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #117 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.656 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #118 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.687 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:10:35 PM #119 Text 0 File Cdrdrv.cpp, Line 1277
16:10:35.718 - PIONEER DVD-RW DVR-107D\H1 T1 : Queue again later
4:14:24 PM #120 SCSI -1064 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03350000
Sense Code: 0x21
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x05 0x98 0x8A 0x00 0x00 0x1A 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x21 0x02
4:14:24 PM #121 CDR -1064 File Writer.cpp, Line 301
Invalid block address
4:14:24 PM #122 Text 0 File ThreadedTransfer.cpp, Line 229
4:14:38 PM #123 Text 0 File dlgbrnst.cpp, Line 1658
4:14:38 PM #124 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 24x (3,600 KB/s)
Existing drivers:
Registry Keys:
rriehl
Postby CCampbell on Mon Mar 22, 2004 7:27 pm
You are getting a Queue Again Later error message, which indicates the recorder is busy with the last command given to it, so your new write command goes into a que. If the drive fails to return from the busy status, our software will time out and report an error message.
in your case, the most likely suspect is the setting for the IDE BUS that you have the recorder connected too. It reports that DMA is disabled, and this is more than likely the cause of your QUEUEING errors.
Also, make sure you have the latest drivers for your "IdeChnDr" IDE controller, as this can have an affect here as well.
Postby rriehl on Mon Mar 22, 2004 7:44 pm
My DMA is set at UDMA2 but Nero is reporting that it is disabled. Is this bad?
Also, I am using the Intel Application Accelerator....- is this needed?
Thanks.
rriehl
Postby CCampbell on Mon Mar 22, 2004 7:56 pm
rriehl wrote:My DMA is set at UDMA2 but Nero is reporting that it is disabled. Is this bad?
Thanks.
Yes, this indicates that you more than likely have old drivers loading for your IDE controller. If Nero is reporting that DMA is disabled, then it's disabled.
But the strange thing is that you have two other drives that show DMA is enabled. It looks like they are all on the same IDE controller, so it's strange that 2 report as DMA enabled, and 2 report as disabled.
This needs to be resovled, as this is more than likely the cause of your troubles.
Do you have an Add-ON IDE controller you can test with?
Postby rriehl on Mon Mar 22, 2004 8:06 pm
No I do not. Would you reccomend that I uninstall the Intel Application Accelerator?
rriehl
Postby CCampbell on Mon Mar 22, 2004 8:16 pm
rriehl wrote:No I do not. Would you reccomend that I uninstall the Intel Application Accelerator?
YES! :)
That has been known to cause problems with write speeds in Nero in the past. Though normally it only caused you to be able to select only the Maximum write speeds for your recorder, and nothing slower. But to be safe, you should uninstall it just in case.
Postby rriehl on Mon Mar 22, 2004 9:56 pm
I uninstalled IAA and then uninstall the primary and secondary IDE controllers, re-booted and let WinXP re-install the drivers. DMA is now enabled on all!
One thing though, on my DVD and CDROM drive I am still only getting UDMA2... is this a problem?
Thanks!
rriehl
Postby CCampbell on Tue Mar 23, 2004 2:06 pm
rriehl wrote:I uninstalled IAA and then uninstall the primary and secondary IDE controllers, re-booted and let WinXP re-install the drivers. DMA is now enabled on all!
Thanks!
It should not be a problem, but the only true way to be sure is to test it. :)
Do you still have the same issues you were having?
Postby rriehl on Tue Mar 23, 2004 7:56 pm
It works perfectly! Thanks so much for your help Craig!!!!!!
rriehl
Postby CCampbell on Wed Mar 24, 2004 2:04 pm
rriehl wrote:It works perfectly! Thanks so much for your help Craig!!!!!!
Your Welcome Rriehl! :)
Just glad your issue is resolved.
