severe controler problems - need help
Postby vorlon on Fri Apr 18, 2003 3:02 pm
Hi!
After installing Nvidia WDM drivers and restarting the machine (Medion MD 8000 XL; OEM MS-6701 MoBo (648 Chipset), OEM GeForce 4 Ti 4200, PIV 2,66) some (5) new pieces of hardware are found by WinXP Home (4 related to the Graphics Card, SM-Bus-Controler as new device and a defective AXVSCSI-Controler driver(?!))
After deinstalling the WDM drivers the Graphics Card related devices ain't there any more.
The SM-Bus-Controler (as well as AXVSCSI controler) keeps there and WinXP can't find any drivers!
They keep there even after restoring a previous XP restoration point!
I can't find any suitable drivers manually and I don't even have a MoBo drivers CD (Medion won' t give 'em to me!! And MSi, that produced most parts say I should address Medion)
What's that AXVSCSI-Controler??
Ain't any drivers for that one too! Read something about a related problem concerning Win 95 and Alcohol 1.40.
I had Alcohol installed previously but deleted it shortly after. Anything to do with that (is the controller itself installed by Alcohol? I don't know what's exactly in that fucking machine!)
Thanks in advance!
Bye
Understanding is a three-edged sword:
our side, their side and the truth.
vorlon
Postby vbl117 on Fri Apr 18, 2003 5:34 pm
AXV is the virtual CD/DVD ROM drive created by Alcohol . It needs a virtual SCSI controller ( AXV SCSI ) . Uninstalling Alcohol should have uninstalled the virtual SCSI controller . U should be able to uninstall it manually n peripheral/devices list . U dont"t have to worry too much about AXV .
XP creates backup copies of all drivers , so if u don't have/can't find a a driver it can be because it was not installed .
For SM-BUS i don't know ( it's something known but i never needed to correct something there , so i don't have knowledge in it ) . It's true many times some drivers are linked ( especially with integrated motherboards ) but i don't have knowledge in these Nvidia motherboards .
vbl117
Thanks a lot!
Postby vorlon on Sat Apr 19, 2003 5:00 am
Thanks for your answer!
It really helps me a lot!
I'll just delete the AXV than.
Bye
vorlon
