A Sony Problem
A Sony Problem
Postby M@m4eto on Sat May 24, 2003 7:15 am
Hi all. Have a little problem and this is the NERO log.
Windows 98 4.10
IA32
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 23.4.1999 г. 22:22:00
Nero Version: 5.5.10.15
Recorder: <SONY CD-RW CRX210E1> Version: 2YS1 - HA 1 TA 0 - 5.5.10.15
Adapter driver: <ESDI_506> HA 1
Drive buffer : 2048kB
CD-ROM: <TEAC CD-532E-B> Version: 1.0A - HA 0 TA 1 - 5.5.10.15
Adapter driver: <ESDI_506> HA 0
TEAC CD-532E-B (Target 1, F:): Autoinsert On, DMA On, Disconnect On, SyncDataXfer Off
SONY CD-RW CRX210E1 (Target 0, G:): Autoinsert On, DMA On, Disconnect On, SyncDataXfer Off
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261588kB)
Free physical memory: 68MB (70648kB)
Memory in use : 58 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: On
24.5.2003
CD-ROM (ISO)
11:59:14 #1 Text 0 File Isodoc.cpp, Line 7495
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
11:59:14 #2 Phase 96 File dlgbrnst.cpp, Line 1655
Buffer underrun error protection activated
11:59:14 #3 Text 0 File Reader.cpp, Line 115
Reader running
11:59:14 #4 Text 0 File Writer.cpp, Line 123
Writer SONY CD-RW CRX210E1 running
11:59:14 #5 ISO9660GEN -11 File geniso.cpp, Line 4546
11:59:14 #6 Text 0 File Burncd.cpp, Line 3717
Turn on Track-At-Once, using CD-R/RW media
11:59:14 #7 Text 0 File ThreadedTransferInterface.cpp, Line 672
original CD pos #0 + 347147 (347147) = #347147/77:8.47
relocatable, CD pos for caching/writing not required/required, no patch infos
11:59:15 #8 Text 0 File DlgWaitCD.cpp, Line 211
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 347146 (77:10.46)
11:59:15 #9 Text 0 File DlgWaitCD.cpp, Line 216
11:59:15 #10 Text 0 File DlgWaitCD.cpp, Line 1630
Recorder: SONY CD-RW CRX210E1;
CDR code: 00 97 27 28; OSJ entry from: Princo Corporation
ATIP Data:
Special Info [hex] 1: F0 00 80, 2: 61 1B 1C (LI 97:27.28), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
11:59:15 #11 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder SONY CD-RW CRX210E1 for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD not fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 711264256
11:59:15 #12 Text 0 File ThreadedTransferInterface.cpp, Line 852
Removed 2 run-out blocks from end of track 1.
11:59:15 #13 Text 0 File ThreadedTransferInterface.cpp, Line 672
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 347145 blocks [SONY CD-RW CRX210E1 ]
11:59:15 #14 Phase 24 File dlgbrnst.cpp, Line 1655
Caching of files started
11:59:15 #15 Phase 25 File dlgbrnst.cpp, Line 1655
Caching of files completed
11:59:15 #16 Phase 36 File dlgbrnst.cpp, Line 1655
Burn process started at 24x (3,600 KB/s)
11:59:15 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
11:59:15 #18 Text 0 File Mmc.cpp, Line 17499
Set BUFE: Buffer under-run error protection -> ON , SMART-BURN : ON
12:02:43 #19 Text 0 File ThreadedTransfer.cpp, Line 219
12:02:48 #20 Text 0 File Mmc.cpp, Line 12534
<SONY CD-RW CRX210E1 > start Close Session
12:02:49 #21 SCSI -1176 File Cdrdrv.cpp, Line 1203
SCSI Exec, HA 1, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x72
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x00
12:02:49 #22 MMC -1176 File ThreadedTransferInterface.cpp, Line 994
Session fixation error
12:02:49 #23 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 994
Could not perform Fixation
12:02:49 #24 Text 0 File Mmc.cpp, Line 12534
12:02:49 #25 Phase 38 File dlgbrnst.cpp, Line 1655
Burn process failed at 24x (3,600 KB/s)
12:02:49 #26 Text 0 File Scsicmd.cpp, Line 406
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 23.4.1999 г. 22:22:00
File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.99, size=83978 bytes, created 23.12.2002 г. 16:28:26
File 'IoSubsys\CDR4VSD.VXD': Ver=5.3.1.158, size=101616 bytes, created 07.1.2003 г. 13:51:44
File 'IoSubsys\CDRALVSD.VXD': Ver=5.3.1.158, size=20043 bytes, created 07.1.2003 г. 13:51:44
File 'IoSubsys\ACBHLPR.VXD': Ver=1.01, size=40508 bytes, created 07.1.2003 г. 13:47:34
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 23.4.1999 г. 22:22:00
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 23.4.1999 г. 22:22:00
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69570 bytes, created 23.4.1999 г. 22:22:00
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 23.4.1999 г. 22:22:00
File 'IoSubsys\ElbyCDIO.vxd': Ver=4, 1, 0, 0, size=15623 bytes, created 04.11.2002 г. 20:35:48
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 23.4.1999 г. 22:22:00 (Adapter driver for src)
I haven't changed nothing. All was fine yesterday and now this.
I try different media, didn't help. Also i had a writing error. Don't know what to do and the recorder has still warranty.
M@m4eto
Postby banzibaby on Sat May 24, 2003 7:28 am
Is the IA32, the Intel Accelerator?
If so disable this or uninstall it as it is known 2 cause probs with Nero
Iit not then im not sure :roll:
BaNzI :lol:
banzibaby
Postby CDRecorder on Sat May 24, 2003 12:51 pm
You should probably update Nero to the latest version. You can download it at Ahead's Web Site.
Also, try different media. If I remember correctly, Princo media isn't very good.
Taiyo Yuden media (such as Fuji media in the U.S.) is very good.
Postby M@m4eto on Sat May 24, 2003 2:23 pm
I already did that. I tried several medias all the same result.
M@m4eto
Postby CDRecorder on Sat May 24, 2003 4:55 pm
Have you updated Nero yet?
Postby M@m4eto on Mon May 26, 2003 12:58 pm
There is no problem with CloneCD, just with NERO. I Have to dload the new one to see.
M@m4eto
Postby KCK on Mon May 26, 2003 9:42 pm
M@m4eto:
Since your IOSUBSYS directory contains several Roxio's drivers, I wonder whether you have installed Windows Media Player (WMP) 7.x or 9.0 with the Adaptec/Roxio burning plugin, or Roxio's Easy CD Creator?
In general, I don't know if the current versions of Nero and such Roxio's software can coexist under Win98SE. Apparently they can under WinXP, but Win98SE may be another story. What are your experiences, banzibaby and LiteOnGuy? I guess it might depend on the version of Easy CD Creator. Maybe Inertia could shed light on this aspect.
Since the log exhibits a session fixation error, I also wonder if you have problems with DAO (Disc-At-Once) burning.
KCK
Postby CDRecorder on Mon May 26, 2003 11:24 pm
KCK: I don't see why Roxio and Nero couldn't coexist on 98se; I know they can on XP. Unfortunately, I don't have ECDC6 or Win98SE to test. You have a good idea though.
M@m4eto: You could also try a firmware update if one is available for your drive. Backup your old firmware before upgrading.
Postby KCK on Tue May 27, 2003 12:40 am
LiteOnGuy:
Don't you have both Nero and some version of ECDC on your Win98 box? After all, Win98 is not much different from Win98SE, and it would help for other users to clarify the Win98 situation as well.
KCK
Postby CDRecorder on Tue May 27, 2003 12:49 am
No, unfortunately I don't. ATM, I don't have either, but I'll see what I can do!
Postby KCK on Tue May 27, 2003 1:39 am
I don't want you to mess up your system unnecessarily! It would be best to ask Inertia, who knows all the intricate details on the interfaces between Ahead and Roxio.
In view of the file dates, I guess M@m4eto has got WMP 9.0. Thus, instead of ECDC, you could install WMP 9.0, and then the latest Nero to see if they can coexist under Win98. In the second step, you could remove the Adaptec burning plugin of WMP 9.0 by running
rundll32 advpack.dll,LaunchINFSection %windir%\inf\roxio.inf,Uninstall
to see whether Nero becomes happy. Finally, you should be able to uninstall the whole of WMP 9.0 via Add/Remove Programs. Even if some Roxio's drivers are not removed, we should be able to clean up your IOSUBSYS directory. On the other hand, Nero does uninstall cleanly, so there is no danger on this side.
KCK
Postby CDRecorder on Tue May 27, 2003 2:12 am
Unfortunately, WMP9 needs 98SE. I tried to install it, but it just won't install on the first edition of 98. BTW, I wouldn't worry about messing up my system; the 98 box isn't my primary system, and I reformat it often. I actually just reformatted it, and I haven't installed much of anything else (besides Windows and drivers) yet.
Postby KCK on Tue May 27, 2003 3:43 am
I've forgotten that 98SE is the minimum requirement for WMP 9.0; sorry! :oops:
Still, if you have time to try some fairly recent version of ECCD... :-?
KCK
Postby CDRecorder on Tue May 27, 2003 11:11 pm
KCK wrote:I've forgotten that 98SE is the minimum requirement for WMP 9.0; sorry! :oops:
That's OK. I didn't try to download WMP 9 now; I had tried it a while ago because it's so nice on my WinXP computers.
Postby CDRecorder on Wed May 28, 2003 6:21 pm
OK, I've got Nero 5.5.10.28 (Demo) and ECDC 5.3.5 Platinum on my 98 box. I'll run some tests and post back.
Postby KCK on Thu May 29, 2003 1:01 am
Thanks in advance! :P
KCK
Postby CDRecorder on Thu May 29, 2003 12:05 pm
OK, here are some results. I ran simulation burns with a 74-minute ISO.
Computer Specs:
Daewoo CB649M-SI motherboard
Celeron Mendocino 366 MHz CPU
256 MB SDRAM
Maxtor 60-GB ATA133 hard drive on Maxtor ATA133 PCI ATA controller
Windows 98 (first edition, no patches)
Easy CD Creator Platinum 5.3.5 (With DirectCD)
Nero 5.5.10.28 Demo (no InCD)
Philips PCRW1208 recorder with firmware 4.0 (used for test)
Creative CD-RW RW1210E (rebadged LTR-12101B) with LTR-12101B firmware LS3J (not used for test, but installed)
I ran the simulation in both ECDC and Nero on an Imation 16x CD-R disc, using DAO mode. It worked fine in both programs.
I have installed the necessary Windows patches since I ran the tests.
If there's anything else you would like me to try, please let me know! :D
Postby KCK on Thu May 29, 2003 1:47 pm
Your results look encouraging! 8)
Could you use Nero to burn (not just simulate) a disc in DAO, and then in multisession mode like M@m4eto? To save on CD-Rs, you could use a CD-RW disc. It's not urgent (since apparently M@m4eto has lost interest) and thus could wait until you really need to burn something on this box (unless Nero's demo expires soon).
To identify the relevant drivers, could you post the final "Existing Drivers" section from your NeroHistory.log (from C:\Program Files\Ahead\Nero)? And, if it's not too much trouble for you, the listing of your IOSUBSYS directory, as explained in S11.1 of the InCD troubleshooting guide
http://www.cdrlabs.com/phpBB/viewtopic.php?t=9597
KCK
Postby CDRecorder on Thu May 29, 2003 2:39 pm
OK. I'll give it a try! :D
