LG Super Multi GSA2164D Not recognising DVD R's Blank or Ful
Postby Gmonkey on Tue Mar 07, 2006 5:01 am
Hi all
Please could you help.
This is brand new out of the box.
Before this i had a Freecom external which was working fine with Nero 7 Premium then suddenly stopped recognising DVD media so i took it back got another, exactley the same. Spoke to Freecom tech and they confirmed faulty drive. Money back time.
So i bought the LG exactly the same.
I've heard it could be Nero causing the problems and told to uninstall and try again.
Only this time i keep getting SHELLMANAGER IS CORRUPT OR MISSING.
Now i can't do anything.
Please help
[-o<
Gmonkey
Gmonkey
Postby Scour on Tue Mar 07, 2006 12:18 pm
When you insert a media, did the drive-LED blinking some seconds and then it´s off? If it so, i think the drive recognize it and it could be a software/driver problem. Make sure you use up-to-date USB-drivers.
Do you use the newest Nero 7? When not, upgrade it and try again. Or deinstall Nero complete and re-install it. If that is also not successful, try latest version of Nero 6.6
Postby MediumRare on Tue Mar 07, 2006 5:54 pm
Download and use the Nero Clean Tool: http://ww2.nero.com/nero7/enu/Nero7_CleanTool.html before you reinstall Nero 7. That should take care of the error message.
Postby Gmonkey on Tue Mar 07, 2006 7:00 pm
Hi Guys thanks for your replys but!!
I have just formatted the laptop (only 5 months old) put on every thing
Windows etc.
Before putting on Nero tried the drive exactly the same.
Put on Nero 7 premium exactly the same.
And why would the original drive (freecom) be OK then just stop.
Any ideas the laptop is a Fujitsu AMILO Pro V2030. Also i have noticed
in the system hardware device manager, it used to in the disc drive section now its only a USB mass storage device.
Gmonkey
[-o<
Gmonkey
Postby Gmonkey on Thu Mar 09, 2006 12:12 pm
Could it be NERO 7 that is the problem rather than windows XP
as i've heard that XP doesn't have DVD burner drivers.
Many thanks Please help this is donig my nut :evil:
Cheers
Gmonkey
Gmonkey
