Can you guys say anything about the quality of TDK Speed-X 48x 700MB CD-R's? How long does data stay those, if they are kept in normal conditions?
What about compatibitility with my drive (see avatar)?
ATIP: 97m 15s 05f
Disc Manufacturer: TDK Corp.
Reflective layer: Dye (Short strategy; e.g. Phthalocyanine)
Media type: CD-Recordable
Recording Speeds: min. unknown - max. unknown
nominal Capacity: 702.83MB (79m 59s 74f / LBA: 359849)
Item code: CD-RSX80EA.
Barcode (EAN): 4 902030 179328
The discs are made in Luxembourg (I think).
More info:
http://www.tdk-europe.com/products/uk/recordablemedia/12/Speed-X
http://www.cdr-info.de/detailcdr.php?ID=1611
