Weird problem of SH-S203D after clean re-install of XP Pro S
Postby Mikey this way! on Thu Aug 28, 2008 11:07 pm
Hi!
I switched back from Vista Business to XP Pro SP2 recently. The XP install is a clean one (from scratch).
Ever since am in XP I notice that DVD Burning was slow never went up above 6~7x speed. Then I realised that the burner is in PIO mode. I don't know how it went into it but, I selected DMA if Available but, it still remained in PIO mode. So, I un-installed the Secondary Channel and restarted XP and then it switched to UDMA5 mode.
After that I burned to coasters and whenever I start a benchmark in Nero CD DVD Speed the Nero App freezes. You can press buttons but, nothing happens. If you start My Computer Windows will not show you the Drive list. If you have to re-start the PC you have to hard reset.
I then found that after sometime the burner automatically switches back to PIO mode. It seems Nero CD DVD Speed runs properly in PIO mode and the system locks when I try to run it when the burner is in UDMA5 mode.
I don't seem to know why this is happening as everything was working fine under Vista Business.
My Hardware/Software Confing is as follows:
Windows XP Pro SP2 (with all updates till date)
Nero 7.11.10.0
AMD Athlon64 3200+
ASUS M2N8-VMX Mobo - http://www.asus.com/products.aspx?model ... 101&l3=349
Transcend 4 GB RAM DDR2-800 in Dual Channel Mode
Samsung SH-S203D SB00
2x Hitachi 160 GB 7200 rpm HDDs
I am using Windows IDE Drivers and not of nVidia. I am not able to understand why this is happening suddenly.
The Nero Logs of 2 coasters I burn't are as below. Please note that I tried burning this two DVDs when the burner was forced into UDMA5 mode.
Code: Select all
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.11.10.0
Internal Version: 7, 11, 10, 0
Recorder:             Version: SB00 - HA 1 TA 4 - 7.11.10.0
Adapter driver:                           HA 1
Drive buffer  :      2048kB
Bus Type      :      default
CD-ROM:               Version: 1.4  - HA 1 TA 1 - 7.11.10.0
=== Scsi-Device-Map ===
DiskPeripheral       : Hitachi HDS721616PLAT80          atapi Port 0 ID 0  DMA: On
DiskPeripheral       : HDT722516DLA380                  atapi Port 1 ID 0  DMA: On
CdRomPeripheral      : TSSTcorp CDDVDW SH-S203D         atapi Port 2 ID 0  DMA: On
CdRomPeripheral      : ELBY    CLONEDRIVE      1.4     VClone Port 4 ID 0  DMA: Off
=== CDRom-Device-Map ===
ELBY CLONEDRIVE            G:   CdRom1
TSSTcorp CDDVDW SH-S203D   F:   CdRom4
AutoRun : 1
Excluded drive IDs:
BUFE           : 0
Physical memory     : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use       : 20 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
27.8.2008
ISO compilation
1:00 AM    #1 Text 0 File SCSIPTICommands.cpp, Line 450
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
1:00 AM    #2 Text 0 File Isodoc.cpp, Line 6711
    Iso document burn settings
    Simulate                : FALSE
    Write                   : TRUE
    Finalize CD             : TRUE
    Multisession            : FALSE
    Burning mode            : DAO
    Mode                    : 1
    ISO Level               : 2 (Max. of 31 chars)
    Character set           : ISO 9660
    Joliet                  : TRUE
    Allow more than 255 characters in path  : TRUE
    Write ISO9660 ;1 file extensions        : TRUE
1:00 AM    #3 ISO9660GEN -11 File Geniso.cpp, Line 3350
1:00 AM    #4 Text 0 File Burncd.cpp, Line 3500
1:00 AM    #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142
    FS Settings: using validator 'CUDFSettingsValidatorDVD'
    ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
    Changing UDF revision from '1.02' to '1.02'
1:01 AM    #6 SPTI -1114 File SCSIPassThrough.cpp, Line 181
    CdRom4: SCSIStatus(x02) WinError(0) NeroError(-1114)
    Sense Key:  0x06 (KEY_UNIT_ATTENTION)
    Sense Code: 0x29
    Sense Qual: 0x00
    CDB Data:   0x51 00 00 00 00 00 00 00 20 00 00 00
    Sense Area: 0x70 00 06 00 00 00 00 0A 00 00 00 00 29
    Buffer x045f9ec0: Len x20
1:01 AM    #7 Text 0 File DlgWaitCD.cpp, Line 307
    Last possible write address on media:  2298495 (510:46.45, 4489MB)
    Last address to be written:            2281663 (507:02.13, 4456MB)
1:01 AM    #8 Text 0 File DlgWaitCD.cpp, Line 319
1:01 AM    #9 Text 0 File DlgWaitCD.cpp, Line 2988
    Recorder: TSSTcorp CDDVDW SH-S203D, Media type: DVD-R
     Disc Manufacturer ID:
1:01 AM    #10 Text 0 File DlgWaitCD.cpp, Line 493
1:01 AM    #11 Text 0 File ThreadedTransferInterface.cpp, Line 778
     0: TRM_DATA_MODE1 ()
        original disc pos #0 + 2281664 (2281664) = #2281664/507:2.14
        relocatable, disc pos for caching/writing not required/ required
        -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2281664 blocks [F: TSSTcorp CDDVDW SH-S203D]
1:01 AM    #12 Text 0 File ThreadedTransferInterface.cpp, Line 979
    Prepare [F: TSSTcorp CDDVDW SH-S203D] for write in CUE-sheet-DAO
    DAO infos:
     MCN: ""
     Tracks 1 to 1:                                  Idx 0         Idx 1      Next Trk
       1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    4672847872, ISRC ""
    DAO layout:
     ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
            0 |  lead-in |   0 |    0x41 |        0 |        0 | 0x00
            0 |        1 |   0 |    0x41 |        0 |        0 | 0x00
            0 |        1 |   1 |    0x41 |  2281664 |        0 | 0x00
      2281664 | lead-out |   1 |    0x41 |        0 |        0 | 0x00
1:01 AM    #13 Text 0 File SCSIPTICommands.cpp, Line 240
    SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
1:01 AM    #14 Text 0 File Burncd.cpp, Line 4286
    Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
1:01 AM    #15 Phase 24 File dlgbrnst.cpp, Line 1767
    Caching of files started
1:01 AM    #16 Text 0 File Burncd.cpp, Line 4405
    Cache writing successful.
1:01 AM    #17 Phase 25 File dlgbrnst.cpp, Line 1767
    Caching of files completed
1:01 AM    #18 Phase 36 File dlgbrnst.cpp, Line 1767
    Burn process started at 16x (22,160 KB/s)
1:01 AM    #19 Text 0 File ThreadedTransferInterface.cpp, Line 2726
1:01 AM    #20 Text 0 File DVDR.cpp, Line 3262
    Recording mode: Sequential Recording Mode
1:01 AM    #21 Text 0 File DVDR.cpp, Line 3416
    Start write address at LBA 0
1:01 AM    #22 Text 0 File Cdrdrv.cpp, Line 10161
    ---- Disc Structure: Physical Format Information (00h) ----
    Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
     Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
     Disc Size: 120 mm,      Maximum Transfer Rate:  (F h)
     Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
     Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
     Outer Limit of Data Recordable Area:          0 h
      Revision number of maximum recording speed: 6.0
      Revision number of minimum recording speed: -
      Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
      Class: 0,  Extended part version: 33
      Start PSN of the Extra Border Zone: 0 h
      Start PSN of Physical format information blocks in Extra Border Zone: 0 h
     Media Specific [16..783]:
        00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00    .`...0@P...!....
        00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
        1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
        01 40 C1 FD 9E D8 52 00 - 02 85 0D 10 88 9A 80 00    .@....R.........
        03 4D 42 49 20 30 31 00 - 04 52 47 34 30 00 00 00    .MBI.01..RG40...
        05 88 80 00 00 00 02 00 - 06 09 0D 13 87 78 80 00    .............x..
        07 88 80 00 00 00 00 00 - 08 05 15 0D 10 0B 0A 00    ................
        09 98 08 0F 0B 78 88 00 - 0A 80 00 00 00 00 10 00    .....x..........
        0B 07 19 15 A7 88 75 00 - 0C 99 BC AA A2 20 22 00    ......u.......".
        0D 00 00 D0 00 00 00 00 - 0E 09 25 33 2F 29 1E 00    ..........%3/)..
        0F 50 21 2D 1F 9A B6 00 - 10 88 84 00 04 00 04 00    .P!-............
        11 00 00 00 00 00 00 00 - 12 09 2F 37 2F 29 1E 00    ........../7/)..
        13 50 1F 2D 1F 9A B6 00 - 14 88 C4 00 04 00 04 00    .P.-............
        15 00 00 00 00 00 00 00 - 16 0B 3F 33 2F 29 1E 00    ..........?3/)..
        17 50 21 2D 1F 9A B6 00 - 18 88 84 00 04 00 04 00    .P!-............
        19 00 00 00 00 00 00 00 - 1A 0B 51 37 2F 29 1E 00    ..........Q7/)..
        1B 50 1F 2D 1F 9A B6 00 - 1C 88 C4 00 04 00 04 00    .P.-............
1:01 AM    #23 Text 0 File ThreadedTransfer.cpp, Line 268
    Pipe memory size 83836800
1:01 AM    #24 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:45.250 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #25 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:47.859 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #26 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:48.546 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #27 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:48.593 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #28 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:51.078 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #29 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:51.250 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #30 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:51.484 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #31 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:52.812 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #32 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:52.843 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #33 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:53.640 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #34 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:54.265 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #35 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:54.609 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #36 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:54.687 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #37 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:55.515 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #38 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:57.750 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #39 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:57.781 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #40 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:58.328 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #41 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:58.734 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:01 AM    #42 Text 0 File Cdrdrv.cpp, Line 1405
    01:01:59.437 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:02 AM    #43 Text 0 File Cdrdrv.cpp, Line 1405
    01:02:00.484 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:02 AM    #44 Text 0 File Cdrdrv.cpp, Line 1405
    01:02:01.093 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:03 AM    #45 SPTI -1046 File SCSIPassThrough.cpp, Line 181
    CdRom4: SCSIStatus(x02) WinError(0) NeroError(-1046)
    Sense Key:  0x02 (KEY_NOT_READY)
    Sense Code: 0x30
    Sense Qual: 0x05
    CDB Data:   0x2A 00 00 00 03 C0 00 00 20 00 00 00
    Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 30 05
    Buffer x093d07c0: Len x10000
    0x22 00 C0 03 00 00 00 00 03 C0 00 08 00 00 00 00
    0x08 00 6C 08 1A 17 1F 28 14 02 00 00 01 00 00 01
    0x01 00 22 00 BF 03 00 00 00 00 03 BF 00 08 00 00
1:03 AM    #46 CDR -1046 File Writer.cpp, Line 306
    Illegal disc
1:03 AM    #47 Text 0 File DVDR.cpp, Line 3818
    EndDAO: Last written address was 959 (3BFh)
1:03 AM    #48 Phase 38 File dlgbrnst.cpp, Line 1767
    Burn process failed at 16x (22,160 KB/s)
1:03 AM    #49 Text 0 File SCSIPTICommands.cpp, Line 287
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
1:03 AM    #50 Text 0 File Cdrdrv.cpp, Line 11411
    DriveLocker: UnLockVolume completed
1:03 AM    #51 Text 0 File SCSIPTICommands.cpp, Line 450
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
Second Log file
Code: Select all
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Recorder:             Version: SB00 - HA 1 TA 0 - 7.11.10.0
Bus Type      :      default
TSSTcorp CDDVDW SH-S203D   F:   CdRom0
AutoRun : 1
Excluded drive IDs:
BUFE           : 0
Memory in use       : 19 %
Use Inquiry    : 1
27.8.2008
ISO compilation
1:10 AM    #1 Text 0 File SCSIPTICommands.cpp, Line 450
1:10 AM    #2 Text 0 File Isodoc.cpp, Line 6711
    Simulate                : FALSE
    Write                   : TRUE
    Finalize CD             : TRUE
    Burning mode            : DAO
    Mode                    : 1
    Joliet                  : TRUE
1:10 AM    #3 ISO9660GEN -11 File Geniso.cpp, Line 3350
1:10 AM    #4 Text 0 File Burncd.cpp, Line 3500
1:10 AM    #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142
1:10 AM    #6 Text 0 File DlgWaitCD.cpp, Line 307
1:10 AM    #7 Text 0 File DlgWaitCD.cpp, Line 319
1:10 AM    #8 Text 0 File DlgWaitCD.cpp, Line 2988
1:10 AM    #9 Text 0 File DlgWaitCD.cpp, Line 493
1:10 AM    #10 Text 0 File ThreadedTransferInterface.cpp, Line 778
1:10 AM    #11 Text 0 File ThreadedTransferInterface.cpp, Line 979
    DAO infos:
     MCN: ""
    DAO layout:
1:10 AM    #12 Text 0 File SCSIPTICommands.cpp, Line 240
1:10 AM    #13 Text 0 File Burncd.cpp, Line 4286
1:10 AM    #14 Phase 24 File dlgbrnst.cpp, Line 1767
1:10 AM    #15 Text 0 File Burncd.cpp, Line 4405
1:10 AM    #16 Phase 25 File dlgbrnst.cpp, Line 1767
1:10 AM    #17 Phase 36 File dlgbrnst.cpp, Line 1767
1:10 AM    #18 Text 0 File ThreadedTransferInterface.cpp, Line 2726
1:10 AM    #19 Text 0 File DVDR.cpp, Line 3262
1:10 AM    #20 Text 0 File DVDR.cpp, Line 3416
1:10 AM    #21 Text 0 File Cdrdrv.cpp, Line 10161
1:10 AM    #22 Text 0 File ThreadedTransfer.cpp, Line 268
1:10 AM    #23 Text 0 File Cdrdrv.cpp, Line 1405
    01:10:42.531 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:10 AM    #24 Text 0 File Cdrdrv.cpp, Line 1405
    01:10:43.515 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:10 AM    #25 Text 0 File Cdrdrv.cpp, Line 1405
    01:10:45.109 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:10 AM    #26 Text 0 File Cdrdrv.cpp, Line 1405
    01:10:45.156 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:10 AM    #27 Text 0 File Cdrdrv.cpp, Line 1405
    01:10:46.015 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:10 AM    #28 Text 0 File Cdrdrv.cpp, Line 1405
    01:10:48.250 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:10 AM    #29 Text 0 File Cdrdrv.cpp, Line 1405
    01:10:49.203 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:10 AM    #30 Text 0 File Cdrdrv.cpp, Line 1405
    01:10:49.953 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:10 AM    #31 Text 0 File Cdrdrv.cpp, Line 1405
    01:10:51.218 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:10 AM    #32 Text 0 File Cdrdrv.cpp, Line 1405
    01:10:53.328 - F: TSSTcorp CDDVDW SH-S203D : Queue again later
1:11 AM    #33 SPTI -1114 File SCSIPassThrough.cpp, Line 181
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1114)
    Sense Code: 0x29
    Sense Qual: 0x00
    CDB Data:   0x5C 00 00 00 00 00 00 00 0C 00 00 00
    Buffer x08c58340: Len xc
1:11 AM    #34 SPTI -1064 File SCSIPassThrough.cpp, Line 181
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1064)
    Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x21
    Sense Qual: 0x00
    CDB Data:   0x2A 00 00 00 02 80 00 00 20 00 00 00
    Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 21
    Buffer x09320540: Len x10000
    0x22 00 80 02 00 00 00 00 02 80 00 08 00 00 00 00
    0x08 00 6C 08 1A 12 27 17 14 02 00 00 01 00 00 01
    0x01 00 22 00 76 02 00 00 00 00 02 76 00 10 00 00
1:11 AM    #35 CDR -1064 File Writer.cpp, Line 306
    Invalid block address
1:12 AM    #36 Text 0 File DVDR.cpp, Line 3818
    EndDAO: Last written address was 639 (27Fh)
1:12 AM    #37 CDR -1114 File WriterStatus.cpp, Line 292
    Reset occurred
1:12 AM    #38 TRANSFER -24 File WriterStatus.cpp, Line 292
    Could not perform end of Disc-at-once
1:12 AM    #39 Phase 38 File dlgbrnst.cpp, Line 1767
1:12 AM    #40 Text 0 File SCSIPTICommands.cpp, Line 287
1:12 AM    #41 Text 0 File Cdrdrv.cpp, Line 11411
1:12 AM    #42 Text 0 File SCSIPTICommands.cpp, Line 450
Existing drivers:
Registry Keys:
I have used MBI discs and I know they are not that good but, that's the ones that are available where I live and I have burnt 100s of them till date without any prob.
Please help.
Scan in PIO mode.gif (39.61 KiB) Viewed 6829 times
Mikey this way!
Re: Weird problem of SH-S203D after clean re-install of XP Pro S
Postby Ian on Fri Aug 29, 2008 1:47 pm
Yeah, XP will set it to PIO mode if it encounters a certain number of errors. It can be a bit annoying.
You've already done most of the stuff I'd suggest. On top of what you've done, I'd check the BIOS to make sure UDMA is enabled there and try another IDE cable.
Postby Mikey this way! on Fri Aug 29, 2008 2:08 pm
Ian wrote:Yeah, XP will set it to PIO mode if it encounters a certain number of errors. It can be a bit annoying.
Yup it is enabled. The screen after POST also confirms that the drive is in UDMA 5 Mode. :(
Thanks for your PM BTW.
Mikey this way!
Postby Mikey this way! on Fri Aug 29, 2008 2:41 pm
Just installed the latest nVidia IDE Drivers (MCP61) in place of default MS ones and voila Nero CD-DVD Speed has started functioning in UDMA 5 Mode. Lets see the rest.
Mikey this way!
Postby Mikey this way! on Fri Aug 29, 2008 2:51 pm
A Burn Simulation @ 16x completed flawlessly :D
Mikey this way!
Postby Mikey this way! on Fri Aug 29, 2008 3:42 pm
Hurray! :D :D
Burn completed in Nero 7 flawlessly @ 16x in about 5.40 mins. LOL
This time the opposite was the solution. I had to install nVidia IDE Drivers in place of MS ones.
Mikey this way!
Postby Ian on Fri Aug 29, 2008 4:50 pm
That's good news.
Postby Mikey this way! on Sat Aug 30, 2008 12:54 am
Ian wrote:That's good news.
It definately is. I thought I have to re-install Windows XP and all Apps again :(
I also nearly installed XP SP3 but, didn't at the last moment. Thought I should try nVidia drivers first :D
Mikey this way!
