Memorex 15 Pack 8.5GB 8x DVD+R DL Discs - $12.98 @ Staples
Postby Ian on Sun Jan 17, 2010 11:54 am
Staples has 15 packs of Memorex 8x DVD+R DL discs on sale this week for $12.98. The last I checked, these were RITEK S04, which aren't as good as say Verbatim's, but at less than $1 a disc, its a pretty good deal.
http://www.staples.com/Memorex-15-Pack- ... uct_616635
Re: Memorex 15 Pack 8.5GB 8x DVD+R DL Discs - $12.98 @ Staples
Postby Dartman on Sun Jan 17, 2010 11:56 am
They seemed to burn pretty well in my LGh22n burner but not so good in my others so depends on the burner you use and your luck. I might have to go pick some up again and see how they do in the 7240 as well, thanks.
Postby Ian on Sun Jan 17, 2010 12:22 pm
Actually, this is a much better deal. Buy.com has a 50 pack of Memorex 8x DVD+R DL discs for $29.79 shipped free.
http://www.buy.com/prod/memorex-50pk-dv ... 47220.html
Postby Dartman on Sun Jan 17, 2010 3:56 pm
Well I went out today and did a blank media run. I bought the 15 pack of Memorex DL and my 7240 claims 8x burns, plus I got another pack of the Verbatim 100 pack plus media that's also on sale at Office Max this week. It should be MCC-004 and burns at 20x in the 7240 with usually good results. The 100 pack was 19.99 again, I bought a pack last time they had that price and have burned through about 60 so far.
I haven't found any of the UAE made disk yet, but they are the same folks that make the falcon media that many of us liked. I'm doing a burn at 8x to the Memorex DL right now with the 7240 and we'll see how the new drive likes it.
Ritek SO4 Memorex DL at 8x17-January-2010_12_34.png (52.33 KiB) Viewed 2454 times
Postby Ian on Sun Jan 17, 2010 4:46 pm
Dartman wrote:I haven't found any of the UAE made disk yet, but they are the same folks that make the falcon media that many of us liked.
Anything has gotta be better than the Made In India stuff.
Postby Dartman on Sun Jan 17, 2010 4:54 pm
All the media I have gotten last few times was made in Taiwan including the DL of course. I guess that burn isn't hideous though the PIE is pretty high. It seemed to play fine in power dvd when it was in the 1655 so as long as it works I think it's be OK for folks doing giveaways and non critical stuff.
Return to Hot Deals
