WD Blue 3D NAND 500GB SSD - $77 Shipped @ Amazon
Postby Ian on Tue Aug 21, 2018 12:10 pm
Amazon has theWD Blue 3D NAND 500GB SSD (WDS500G2B0A) on sale for $77. Shipping is free.
WD Blue 3D NAND 500GB PC SSD - SATA III 6 Gb/s 2.5"/7mm Solid State Drive - WDS500G2B0A
The WD Blue 3D NAND SATA SSD utilizes 3D NAND technology for capacities up to 2TB with enhanced reliability. Featuring an active power draw up to 25% lower than previous generations of WD Blue SSDs, you’re able to work longer before recharging your laptop, while sequential read speeds up to 560MB/s and sequential write speeds up to 530MB/s give the speed you want for your most demanding computing applications. Combined with the free, downloadable WD SSD Dashboard software and a 5-year limited warranty, you can confidently upgrade your system to the WD Blue 3D NAND SATA SSD. As used for storage capacity, one terabyte (TB) = one trillion bytes. Total accessible capacity varies depending on operating environment. Active power draws are up to 25% lower during sequential reads than previous generations of WD Blue SSD at the 500GB capacity point.
Return to Hot Deals
