VEFF wrote:OC-Freak wrote:Got the drive?
Just interested in what firmware it comes shipped with as I have a pre-release sample for review here ( the drive do not even have a sticker on it - just plain grey with a sample sticker telling it has serialnumber "6" and is model 822A with fw B3BC).
It was delivered todayI will play with it when I get home...
Too bad the rest of my weekend wasn't as good, but that's another story.
Kennyshin wrote:VEFF wrote:OC-Freak wrote:Got the drive?
Congratulations.
Ian wrote:These days most of the refurbs are returns. I've ordered a bunch of refurb stuff in the past and have had good luck.
Vanderlow wrote:Pricewatch has the lowest price at $77. Ebay has a couple of cheap 401s coming up. Sometimes you can catch something at slickdeals.net. NewEgg has refurbished 401s for $67.
http://www.newegg.com/app/ViewProduct.a ... 14&order=1
vsekh wrote:Anyone have an idea about how much Benq will charge for the firmware upgrade to make the drive compatible with dual-layered media?
VEFF wrote:My box says the upgrade will be available on 09/30/'04.
That is a long time to wait. I will buy one (or two) 1600A drive(s) long before then, so it doesn't matter to me personally.
In any case, DL media will initially cost more than it is worth to me,
so I will burn SL media at 16X instead, once media capable of 16X burning is available, which might also be a long while.
I specifically bought the 822A to tide me over till 16X DVD burners come out. I figured its resale value would be higher than a non
DL-capable or a non DL-upgradeable DVD burner...
Ian wrote:VEFF wrote:My box says the upgrade will be available on 09/30/'04.
Yeah, I'm sure the DW830 will be out long before then.
| All Content is Copyright (c) 2001-2026 CDRLabs Inc. |
