LG GCE-8240B,drive faulty?
Postby pranav81 on Mon Jun 30, 2003 1:20 am
Dear all,
Hi there.I have a LG GCE-8240B CD-Recorder.It is 13 months old and out of warranty now.The drive is with firmware 1.07.Now whenever I try burning a CD I get tarck following error on any media that I use.The writer just writes TOC or Lean In and then gives error saying "Track following error".I tried using Roxio,Nero and CloneCD all latest versions.I used 5 different media like Mitsui,Moser Baer India,Princo,MM&M and last a Mitsubishi HS CD-RW media.
Will upgrading the firmware to 1.08 solve my problem?
Waiting for some fast and helpful posts,
Thanks in advance,
::Pranav::
pranav81
Postby TheWizard on Mon Jun 30, 2003 1:26 am
You tried basic stuff like doing a cold reboot, yes?
Does the drive still read CD's? All different kinds?
No, I like women.
Postby pranav81 on Mon Jun 30, 2003 1:46 am
Yes.I tried restarting and then cold booted the system without any effects.
I think there is problem with the writer.I am now downloading firmware 1.08 and then will try flashing it using a Windows ME bootable diskette.
Yes th drive still reads and erases the CD's without any problems.
Waiting....
::Pranav::
pranav81
Postby Inertia on Mon Jun 30, 2003 2:13 am
A hot humid climate might put greater stress on the drive optics. Atmospheric contaminants may also have contributed to the problem.
"Track following error" is usually a media problem, but if all good quality media return this error I would try cleaning the drive as a last resort. Sometimes cleaning the drive will allow the laser and/or moving parts to return to normal function, restoring useful operation to a malfunctioning drive.
For generic cleaning instructions see How to Clean Your CD-RW : a step-by-step guide with pictures!
and Simple Recorder Maintenance - Lens Cleaning and Lubrication.
Inertia
Postby pranav81 on Mon Jun 30, 2003 2:20 am
Dear Inertia,
Thanks for the links.I will try those when I get home.Will flashing the firmware to 1.08 help in any way?
Thanks in advance,
::Pranav::
pranav81
Postby Inertia on Mon Jun 30, 2003 2:29 am
You're welcome, pranav.
pranav81 wrote:Will flashing the firmware to 1.08 help in any way?
I would always try flashing first before going to a "last resort" mode. Frankly though, I doubt that flashing will fix the problem. Flashing usually makes minor performance or media compatibility improvements for burners, but does nothing for malfunctions causing a loss of normal operation. Nevertheless, it's worth a try. :)
Inertia
Postby TheWizard on Mon Jun 30, 2003 2:31 am
Flashing the firmware couldn't hurt...unless you do it wrong. :)
No, I like women.
Postby pranav81 on Tue Jul 08, 2003 3:02 am
Dear all,
sorry for long diaspperance.But the good news is that I changed the IDE cable and flashed the firmware to 1.08,then the writer started writing the disks again.I have as far burned about 12 disks without any problem.But I dont know why,I am having a gut feeling that the writer still has problem.
But I wont buy a new one until this dies on me.
Anyways thanks a lot for the help.
See ya later,
::Pranav::
pranav81
Users browsing this forum: No registered users and 11 guests
