rodheb wrote:dhc014 wrote:Would you please send me the CRX215 firmware as well?
dhc014@firmware-flash.com
I tried. It got returned. ??
--Rodheb
Yeah, there are some problems with email on the new server, try sending it to [email], thanks.
--Rodheb
Fuct wrote:dhc014 or Ian (or anyone else who might know), is the CRX210A(48x/12x/48x) overclockable to the CRX215A (48x/24x/48x) by flashing the drive with the now-available Sony CRX215A firmware? I suppose this would allow the use of the Turbo-Boost feature to be kept but would also enable 24x rewriting speeds... something that could come in handy
Fuct wrote:2 questions though about the CRX215A: Is the Turbo-Boost feature still used to go from 40x -> 48x for writing and reading? and is there Mount Rainier support on this drive? (the CRX210A was supposed to have it but is in fact lacking that too). Thanks for your help
Fuct wrote:Cool rodheb, I appreciate the info. The CRX215A firmware should be available if you have the drive... it's the original firmware that came with your drive! If you happened to have made a backup copy of your original firmware (from when you got the drive) BEFORE making any firmware changes or flashing it at all... basically, the firmware that will change my CRX210A to a CRX215A and display it as a CRX215A with 48/24/48x speeds.
(I think this is possibly the firmware you sent to dhc014? Could be mistaken...)
mcmail wrote:my sony 48x24x48 speed shows Ultra DMA Mode 2 in xp maybe your bios needs to be checked ? is your CDR the only thing on a primary or secondary channel?
Users browsing this forum: No registered users and 15 guests
All Content is Copyright (c) 2001-2024 CDRLabs Inc. |
