145 watt too low for a power supply
Postby liteonrules on Tue Sep 26, 2006 5:07 pm
ok, i just build my mother a AMD SEMPRON 2200,40GB,CD RW,DVD ROM and onboard everything else W/ 145 watt power supply. i believe that she will only use it to surf the web and maybe download music every once in awhile and possible use the cd burner and dvd a couple of times in a year. she will never use it for hard core games or anything that will use up power ..........but should i be afraid that this low wattage powersupply could cause blow out for the motherboard and powersupply?
NEC 2500A $20 10/04
NEC 3500AG for $47 4/05
NEC 3540 for $35 9/05
BENQ 1620 for $36 9//05
liteonrules
Postby MonsterMan on Tue Sep 26, 2006 5:15 pm
Quite possible.
Just get this.
They make great PSUs...
MonsterMan
Postby jjones on Tue Sep 26, 2006 5:27 pm
Check this website to calculate the power supply requirements:
http://www.extreme.outervision.com/psucalculator.jsp
With an AMD 2200 Sempron, 7200rpm IDE HD, CD-RW, DVD-ROM and 1 stick of DDR memory, it shows a recommended power supply of 172W. This doesn't include any video card or any add-on cards or USB devices attached.
jjones
Postby MonsterMan on Tue Sep 26, 2006 6:40 pm
Always go bigger than you think you need. Running a PSU at/near it's max rating is hard on the PSU; kill it, you risk killing the rest of the pc.
MonsterMan
Postby burninfool on Tue Sep 26, 2006 10:35 pm
I wouldn't use anything less than a 300w PSU.
thanks
Postby liteonrules on Thu Sep 28, 2006 11:42 pm
thanks guys, i went out and bought a 400 watt power supply for $18.00
i'd rather spend the 18.00 than lose what i put into it
NEC 2500A $20 10/04
liteonrules
Re: thanks
Postby Bhairav on Mon Oct 02, 2006 8:36 am
liteonrules wrote:thanks guys, i went out and bought a 400 watt power supply for $18.00
What kinda 400W PSU do you get for 18$? Get a name-brand PSU dude..
Re: thanks
Postby LoneWolf on Mon Oct 02, 2006 1:07 pm
With an $18 power supply, you're about as equally likely to lose what you put into it.
I've rarely seen a quality power supply retail for less than $40, and I've never seen an $18 unit capable of delivering 400 watts, no matter what is on the label (note: you'll probably use no more than 200 for what you're doing, but still). And when cheapie units go, there's an even-money chance they'll take the system board with them.
Postby yamawho on Wed Oct 04, 2006 7:55 am
One way to evaluate a power supply is by it's weight.
More weight = better quality.
I use OCZ Powerstream 420 in 3 overclocked gaming rigs without issues.
The more I figure out, the more I realize how little I know.
yamawho
