CD-RW and Car CD Player
Postby RBKearnsJr on Fri Mar 04, 2005 8:56 am
Hi all,
I can play Maxell CD-R and various other brands in my car player. I am searching for advice as to whether or not I may run into issues with the CR-RW format (specifically with Maxell for now)
Thanks in advance!
RB
RBKearnsJr
Postby hoxlund on Fri Mar 04, 2005 1:26 pm
it just depends on weather your player supports cd-rw playing
but remember whenever you are burning audio and intend on using it in your car stereo, BURN SLOW!!!!
i usually do 8x, sometimes 16x if im in a hurry
Postby RBKearnsJr on Fri Mar 04, 2005 2:46 pm
Thanks for the reply. I 'xpect I will need to do some 'sperimenting anyhow. Also, I burn ususally at 4x :P
thanks agin
RBKearnsJr
Postby burninfool on Fri Mar 04, 2005 8:29 pm
Most car players do not support CD-RW,if it can play MP3/WMA it probably will.
