Another problem with Nero 7.5.1.1 re: updating software
Postby rizlaw on Mon Sep 25, 2006 8:45 am
Purchased Nero 7.5.1.1 upgrade last night 9/24/06 and performed custom install OK. On the chance that there might be newer modules than the ones included in the main installer exe I downloaded, I performed a check for newer files.
Nero reported that one newer file existed: "Nero Product Setup 1.5.13.0" but could not download the file and reported that I should try and download it manually. I saw no way to do that on Nero's website. I then looked at the version of the "Product Setup" I had and saw that it was the same version.
Is this another bug?
rizlaw
Re: Another problem with Nero 7.5.1.1 re: updating software
Postby bigblu91 on Mon Sep 25, 2006 11:02 am
rizlaw wrote:Nero reported that one newer file existed: "Nero Product Setup 1.5.13.0" but could not download the file and reported that I should try and download it manually. I saw no way to do that on Nero's website. I then looked at the version of the "Product Setup" I had and saw that it was the same version.
I saw the same thing but let it go. It wouldn't update the "Nero Product Setup 1.5.13.0" for me either when showing an update was available. I was just glad the updater was a major advance from the previous. Hopefully they will see your post and look into it.
bigblu91
