Aopen cdrw media problem
Postby ijaz on Fri Oct 03, 2003 2:26 pm
Hi,
i have problem with aopen's cdrw disk.in nero the following error stop the whole process "focus or tracking error" the recorder crw5224 LED is flashing forever........ than i bought verbatim cdrw disk it worked fine.i bunt mix cd with nero both with data track and audio tracks but now i can only see the data on it, not the audio tracks in windows xp :o .nero shows both data and audio tracks fine.i can't find the multi mounter any where as in nero pdf file to read multisessions cds or what ever on the disk.
any suggestions thanks.
ijaz
Postby CDRecorder on Fri Oct 03, 2003 3:01 pm
Welcome to CDRLabs, Ijaz! :D
It sounds like your AOpen CD-RW disc is just poor quality, or your drive just doesn't work well with that type of media. As you have found, Verbatim discs are quite good.
Regarding your data/audio mix CD, you won't be able to see the audio tracks in Windows Explorer or My Computer. However, you should be able to play the audio tracks with your audio CD playing software, such as Windows Media Player.
